Finally got the new 20mm for my epl5.
Started Apr 14, 2014 | User reviews
GeorgeZZ New Member • Posts: 3
I upgraded from a P&S to the epl5 half a year ago. Being a student, I don't want to spend too much on fancy lenses without the skill to make the most out of them. So I started with the kit lense and Oly40-150R. Now that I've learned the basics I decided it's time to own my first prime. I bought a de-kitted 20mm II for 1800RMB, or 290USD. It's not the cheapest prime or pancake, but it serve the most purposes. It's going to be my walk-around pancake, my low-light lens and my environmental portrait lens.
I don't think I need to comment on the IQ, so here's some thoughts on other aspects:
1. The focus is slow, but not slower than my old P&S, which I've used for years and not once complained about its focus speed. It hunts slower than the kit lens, but not more. So it requires a bit of patience, but at least the experience is not frustrating.
2. The aperture clicks loudly. Turning flicker reduction to off/auto for some reason solves this problem. Can anyone give me an explanation?
3. The lens mount is uncomfortably tight. I've heard this happens with em-10 but not with epl5. At least nothing seems to be scratched yet.
4. There is some banding at ISO3200 and above. But I wouldn't worry about it. It's only slightly more distracting than the noise at such ISO. Maybe I got lucky. Besides, with IBIS such high ISO is not needed if there is any light at all.
5. With the kit lens I mostly shoot at 14mm, but the 20mm felt natural too. It helps me to focus on the subject instead of just getting everything in. With a two time crop I can also use it as a 40mm f1.7 portrait lens that's good enough on my 1080p screen.
 GeorgeZZ's gear list:GeorgeZZ's gear list
Olympus PEN E-PL5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic 20mm F1.7 II
Panasonic Lumix G 20mm F1.7 II ASPH
Prime lens • Micro Four Thirds • H-H020A
Announced: Jun 27, 2013
GeorgeZZ's score
4.5
Average community score
3.9
Olympus PEN E-PL5 Panasonic 20mm F1.7 II
Impulses Forum Pro • Posts: 10,039
Re: Finally got the new 20mm for my epl5.
My Oly 45/1.8 actually feels tighter on my GF6 than the 20/1.7, go figure. I really like the solid build of the 20mm, the silver metal just looks cool, totally inconsequential and cosmetic but what the heck (not like version I was much cheaper when I got it in November)...
My GF6 isn't much to look at but the 20mm classes it up little.
On a more serious note, the praise, size, and specs of the 20mm were one of the big attractions to M43 for me; specially the possibility of pairing it with a pancake zoom for an ultra portable setup.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
ulfie Veteran Member • Posts: 3,299
Got IQ? The P20/1.7 certainly does!
Regardless of its (fairly minor) drawbacks, the bottom line is that the P20/1.7 can and does deliver excellent IQ (Image Quality).  After all, the final image is what really counts, no?
krugman Contributing Member • Posts: 957
Re: Got IQ? The P20/1.7 certainly does!
Well yes, it is an outstanding lens, but a secondary issue arises if you can't get the lens on and off the camera.  I had to return this fine lens because it was almost impossible to remove it once I managed to get it on the camera. I replaced it as best I could with the Sigma 19mm, which Lens Rental testing shows to be very nearly as good as the 20mm and much better than the kit zoom or Pana 14-45 zoom or the Oly 17 f2.8. I believe that it tested better than  the 17 f1.8 also but I don't recall that comparison clearly. Anyway the Sigma arrives Friday and I will know more after that. B and H doesn't have any of the 19mm available, and Amazon had only one or two left when I ordered mine. I would prefer to  use the 20mm but not if I can't get it off the camera.
Severa suggestions have been made about lubrication the camera flange or the lens mount, and if the 19, which should arrive soon, proves difficult to get on and off the camera,  I may try one of these out of desperation, and in that case I would post my results here. The suggestions include WD-40, white lithium grease, and sebum. They all sound risky to me. Many posters strongly advise not lubricating.
Krugman
Lube it with syr--
Because the 20 is a pancake lens, you need to apply maple syrup to lubricate it.
Seriously, lubing may not be the solution if either the camera flange or the lens flange mount is off specs, i.e. too large.  Thus the fit may be just too tight.
baxters Veteran Member • Posts: 5,319
Compared to your two zooms with plastic mounts, the metal mount 20mm will feel tighter.
I remember thinking my Oly 45mm was pretty tight when I first got it, but maybe I am used to it as it feels the same as my 20mm now.
I have had four M43 cameras to try, EPL1, EPM1, EPL5, and EM5. They all look to me to use the same metal mounting plate on the camera.  Unless they changed the part recently, I believe they should all act the same.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
tjdean01 Senior Member • Posts: 2,255
Both of my 20s were tight
I bought both of my 20s from Amazon.  Buying from Amazon is something I've learned not to do as I've had nothing but problems with their electronics--PL2 had faulty sensor, PM2 had sticky buttons and shutter that needed replacing, 14-42 made grinding noise, MP3 players were scratched...
And both 20s I got (old version) would not fit on my camera.  I got one one but it literally felt as if I was going to tear the lens apart.  I'm sure some people would not have been strong enough to put it on.  2nd one was the same problem.  I used it and while it was on the camera it was great but I'm reluctant to buy another.  I have 3 other lenses and a few adapters with metal mounts too so that isn't the issue.
s_grins
s_grins Forum Pro • Posts: 14,011
Krugman
Do not lubricate. Eventually you will find lubricant and abrasives on the sensor
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
s_grins
Can you post ISO 3200 shots which shows banging, please?
Ulric Veteran Member • Posts: 4,559
Banding in the shadows in broad daylight does get a bit annoying.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Re: Both of my 20s were tight
Yes, this kind of tightness and binding was precisely my experience with the 20mm I had to return to my  local photo store. Thanks for posting this, it will help call attention to this problem.
Krugman
LaMesa Senior Member • Posts: 2,370
About the crop factor
Using the lens as a 40mm means a four time crop, which turns your 16MP into 4MP - not really bad, either.
Herbert
OP GeorgeZZ New Member • Posts: 3
Sorry but I formatted my card as I'm about to leave for my Easter vacation. Will be using 20mm a lot at night and post some example after I get back.
Re: About the crop factor
Herbert
I thought that from 20mm to 40mm is 2 time crop and the size is reduced to 1/4th? You got what I meant anyway. 4MP at ISO200 is plenty enough for portrait on web, people don't want to see every single speck on their faces anyway.
