An image captured with the X-T1 and the 60mm f2.4 macro
Started Apr 4, 2014 | Discussions
pinnacle Senior Member • Posts: 2,625
9
Here is a link to some images from a session at Silver Falls State Park in Oregon.
https://www.flickr.com/photos/delphititan/with/13589575344
Life is good.
 pinnacle's gear list:pinnacle's gear list
Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +3 more
Fujifilm XF 60mm F2.4 R Macro Fujifilm X-T1
EugeneC Regular Member • Posts: 483
Re: An image captured with the X-T1 and the 60mm f2.4 macro
Beautiful photos. I have the 60 and really haven't used it as much as I should. Anyway, nice!!!
Gene
 EugeneC's gear list:EugeneC's gear list
Fujifilm X-H1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Sony FE 55mm F1.8 +8 more
ryan2007 Forum Pro • Posts: 12,001
What Film Simulation mode did you use
How did you set your white balance
How did you set the Dynamic Range
What Metering Mode did you use
What was your ISO set to
fotophool Veteran Member • Posts: 4,340
You can go to his Flickr link and figure some of that out for yourself.
The EXIF is there.
If you know how Flickr works.
fotophool
My Flickr Pics
OdzBodkinz Senior Member • Posts: 1,438
Really the only reason I havent grabbed the 56mm 1.2 yet. Great images. I need to do some portraits with Mine.
Money can't buy happiness....It has to be converted into photo equipment first.
Matz03 Regular Member • Posts: 186
great shoot, thanks for sharing.  Did you use natural light and am I just seeing a reflector as the catch light?  I just picked up a 60mm an looking to do a portrait sessions soon.
OP pinnacle Senior Member • Posts: 2,625
It was all natural light with a 40" x 60" reflector. In hindsight the reflector may have been a little too big. I have another session with a different model coming up soon. I think I am going to mix in use of the EF42 Fujifilm flash with a soft box and a reflector.
I am still getting use to the various settings and capabilities of the X-T1 but, I am finding it to be a wonderful camera overall.
Dan
Life is good.
VertigonA380 Senior Member • Posts: 1,133
Lovely composition and picture however where was the focus point? The eyes need to be razor sharp, either you captured the eyebrows or the lens is front focussing.
The focusing variation has to do with my inexperience with the focusing system and how to adapt to the way it works. Over time I will be able to yield a higher rate of success with my captures. There is no issue with front focus. In this instance, the lens to subject distance was quite short and the aperture in many cases was wide open amd so I needed to be more careful of where the actual point of focus was. I should have stopped my aperture setting down another half or full f-stop. That would likey have enabled me to extend the depth of field enough to ensure getting both eyes sharply in focus.
It just takes time getting used to using a new piece of technology and becoming intuitive with the controls, menu system, and ergonomics.
Dan
Life is good.
ThachLy Regular Member • Posts: 264
Can't believe its so sharp !
Some on the most detailed and sharpest portraits I ve seen.
I heard the 60mm is sharp but didn't think it was this sharp.
I thought I wouldn't need it , but now I m tempted.
Did you shoot JPEG SOOC or RAW and PP? If raw, what did you use for your PP ?
Thanks for sharing
 ThachLy's gear list:ThachLy's gear list
Fujifilm XF 60mm F2.4 R Macro Panasonic Lumix DMC-LX3 Olympus OM-D E-M5 Fujifilm X-A1 Fujifilm X-T1 +7 more
baobob
baobob Forum Pro • Posts: 18,248
Lovely model and photo, a lot of mood !
If I may : there is definitly some highlights clipping on the middle of the face
To cope with that 2 ways  :
PP the RAW and adjust levels
Or in JPEG use DR 400 and S-2 or -1 and same for H since ther is obviously a lot of contrats This will help to capture all subtle tones of the carnation
Cheers
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
ejw07
ejw07 Regular Member • Posts: 469
Love it,   very well done..
Dan
I think your aperture selection was ideal, the lovely soft focus on the rest of her is ideal. Perhaps investigating the focus peaking feature is an idea.
Dan
I think that is an excellent suggestion. Thank you for the idea!
Dan
Life is good.
A lot of good suggestions. The images are pretty much OOC. I need to play around with DR200 and DR400 settings. I am also going to try using Photo Ninja on the RAW files and see how that may help.
Thanks Bob.
Dan
Cheers
Bob
Life is good.
Re: Can't believe its so sharp !
The images are pretty much OOC with a very slight white balance correction of the jpeg files. I am going to do a complete post processing job using the RAW files which I have not used as yet from this session. I hope to do the PP this weekend.
Dan
Thanks for sharing
Life is good.
Sonyshine
Sonyshine Veteran Member • Posts: 9,087
Lovely work!
I have just splashed the cash on a 60mm macro!
I'm looking forward to it!
 Sonyshine's gear list:Sonyshine's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +4 more
Sonyshine wrote:
Lovely work!
Thank you for the kind words. The lens is wonderful. I know that you will enjoy it.
Dan
