NX1100 back from it's hols in St. Lucia
Apr 1, 2014
First time my wife and I have had a beach holiday and we went to St. Lucia in the Caribbean together with the NX1100, 16mm, 30mm and 50-200mm NX lenses.
Most of the time when outside of the resort I just took the 16 and 30mm lenses in a small pouch.
I'm generally very impressed with the output. The only real problem I had was night photography where I just couldn't get a focus lock (the NX100 was far better at that). I took quite a bit of video as well and I'm quite impressed with that.
To go even lighter than usual (and I like to back up photos when I am away from home) I took a cheap 7" android tablet with me and loaded it with Rawdroid Pro. I recorded RAW images on a micro SD card so I could plug it into my android and the backup to two separate 64gb USB sticks. I then kept one of those in hand luggage and the other in hold luggage. Glad I was also doing this for my wife's Panasonic TZ7 as the card in that got corrupted, but at the time I only lost one day of photos from that card (and subsequently recovered all but a couple of those using SD recovery software when I got home). I processed the photos from RAW to JPG using RAWdroid pro and the pics below are the output from that. I thought it was extremely good for such a lightweight piece of software with the only significant drawback being it can't handle any camera/lens specific distortion or keystone correction and it does loose the Exif data by the looks of things. Nonetheless I was impressed with it. (I'll probably load some more later after I have time to work through several hundred photos in Capture One Pro.
Bananaquit on Banana plant (with 50-200mm lens)
Purple-Throated Carib (Hummingbird) - (with 50-200mm lens)
Soufrier 16mm F8
Anse La Raye 16mm F7.1
Castries Lighthouse 16mm F8
Locals playing football near the resort 16mm F4.5
Couldn't end except with this... 16mm F4.5
Neil....
The Sky is a Beautiful Place
