Soon to be released super fast SD cards and the D7100?
Started Mar 25, 2014 | Discussions
mikew Contributing Member • Posts: 632
I see B&H are selling a new Sandisk SD card that will read at 280mbs and write at 259mbs. Will the D7100 be able to take advantage of these soon to be released SD cards? I am hoping these cards will help with the small buffer problem of the D7100.
Mike
 mikew's gear list:mikew's gear list
Nikon D4 Nikon D800 Nikon D810 Nikon AF-S Nikkor 600mm f/4G ED VR Nikon AF-S Nikkor 50mm f/1.4G +11 more
Nikon D7100
mosswings Veteran Member • Posts: 8,954
Re: Soon to be released super fast SD cards and the D7100?
Mike
This has been discussed here previously. The D7100 is a UHS-1 class device, which means that it can drive SD cards rated at up to 100MB/sec at their full speed.  The new 259/280MB/sec cards are UHS-II or UHS-III devices, and the D7100 doesn't support the signalling protocol that permits those cards to be written at those speeds. UHS-II/III was created to support 4K/60 video.
Bottom line, the cards that will max out the D7100's write speed are the 95MB/sec UHS-I SD cards. You will not see a speedup when using the UHS-II/III cards.
Sorry.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR +5 more
TranquilityBase
TranquilityBase Regular Member • Posts: 438
Mike
No, not fully. The D7100 internal bus caps off at significantly less, but I don't remember the spec at the moment. Google around, but I believe the 95MB cards already exceed that limit.
Luck favors the prepared...;-)
http://photobucket.com/albums/y36/pro1/
 TranquilityBase's gear list:TranquilityBase's gear list
Nikon D7200
Steve Bingham
Steve Bingham Forum Pro • Posts: 25,815
Won't help one bit. 95 is max for your D7100.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D Nikon AF-S DX Nikkor 18-140mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +22 more
OP mikew Contributing Member • Posts: 632
Thanks to all posters for your informative responses
It is replies like these that make this site and this forum such a valuable resource.
Thnak again,
Mike
RobByePhoto
RobByePhoto Regular Member • Posts: 276
Re: Thanks to all posters for your informative responses
Even if a current camera can't make full benefit of this new generation of high speed cards, the next generation of cameras likely will. Since cards have a substantial lifespan, I buy the biggest and fastest available, passing it from one generation of camera to the next.
Rob Bye
 RobByePhoto's gear list:RobByePhoto's gear list
Nikon D300 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Tokina AT-X Pro 12-24mm f/4 (IF) DX +3 more
TranquilityBase
Yes, but by the time you can take advantage of that extra speed/capacity, generally an equivalent card will cost much less. They don't call it the Bleeding Edge for nothing
Nikon D7200
