α6000 & α7R ISO100-6400 JPG+RAW
Started Mar 24, 2014 | Discussions
WSLam Veteran Member • Posts: 4,208
8
It's been at least 10 years since I last tried to do any sort of 'test shots', so please pardon me if the setup is not ideal.
I used the FE55/1.8 for all the photos, at f2.8. Both α6000 and α7R were set on a tripod and with 2-sec self timer engaged.
All shots were focused on the Rabbit's left (right on screen, the one nearer the center) eye.
α6000, AF-A, RAW+JPG
α7R, AF-S, RAW+JPG
Both set to Evaluative Metering.
I physically moved the α7R to get in closer to roughly match the framing of the α6000.
Shot at full ISO stops, so, ISO100, 200, 400, 800, 1600, 3200, 6400, 12800 and 25600.
α6000_ARW.zip 206.3MB:
https://mega.co.nz/#!mIxjAI6L!dPj2FMnmSO_oiUkyZFxMe2VjJOpBgFgAO3rNT1t-d8A
α6000_JPG.zip 48.0MB:
https://mega.co.nz/#!uBoljKiD!Q1qmYIatVgu9LPWMJxh9RrnBus56st1c0VdVo69Dwy4
α7R_ARW.zip 309.2MB:
https://mega.co.nz/#!TJhg3DpL!MrE8hkG_rpKaK8pU4jUh9MaGiVQR8NtxdY-RsdOXdck
α7R_JPG.zip 58.3MB:
https://mega.co.nz/#!TQYEDK4T!k5lS1fYMjoOlzErwl03NNvp185bRKILD9jhKbWWu17E
I have also uploaded the JPG here:
α6000: http://photos.lam.ws/Hobbies/Camera-Equipment/Sony-%CE%B16000
and
α7R:
http://photos.lam.ws/Hobbies/Camera-Equipment/Sony-%CE%B17R/
And a 100% side by side of the JPG from both cameras at ISO6400
L: α7R @ ISO6400, R: α6000 @ ISO6400 100% Crop
too many cameras...
 WSLam's gear list:WSLam's gear list
Olympus TG-5 Sony RX100 V Nikon D800E Leica M Typ 240 Olympus E-M1 II +46 more
Del Pierro
Del Pierro Regular Member • Posts: 189
Re: α6000 & α7R ISO100-6400 JPG+RAW
Thank you very much! Very helpful and impressive performance of the A6000.
 Del Pierro's gear list:Del Pierro's gear list
Leica Q Sony a7 II Sigma 35mm F1.4 DG HSM Art
miro3 Veteran Member • Posts: 3,048
but the size is different for the 100% crops, so not clear how that factors in.
Photostyle Contributing Member • Posts: 710
It seems a very close call here, it's almost the same, just a small advantage for the A7 which is remarkable, thanks
José B
José B Forum Pro • Posts: 18,557
A6000 images look pretty good to me! Thanks for sharing.
José
 José B's gear list:José B's gear list
Sony a6000 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Carl Zeiss Touit 1.8/32 Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Sony FE 55mm F1.8 +13 more
Keit ll Veteran Member • Posts: 4,323
What program can be used for opening the RAW files ?
OP WSLam Veteran Member • Posts: 4,208
I know I won't be able to please everyone. I already clearly described how the test shots were taken. I am not going to match the 100% view. Even dpreview does not do that. So I am afraid my 'help' stops here. Hopefully you will still find them useful.
too many cameras...
I use the latest DNG Converter Beta to convert to DNG, then open up in LR5.3
too many cameras...
To me, when Sony manages to combine the EVF from the Fuji XT1, the AF from the a6000 and the FF from the a7R, and of course flesh out the lens line up with HIGH quality lenses, then I will be ready to sell my D800e.
too many cameras...
ijustloveshooting
ijustloveshooting Senior Member • Posts: 2,997
many thanks!
im really surprised too see how a6000 petforms at iso6400 comparing to A7R...really great performance.
 ijustloveshooting's gear list:ijustloveshooting's gear list
Fujifilm X-A1 Sony a7 II Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +10 more
Re: many thanks!
Yes it seems a big improvement on the NEX 7's high ISO performance.
Chad Hardy
Chad Hardy Senior Member • Posts: 1,192
Very useful, many thanks.
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 56mm F1.2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Sony RX100 III Sony a7R +16 more
academytim Regular Member • Posts: 206
Pretty amazing. Has me debating on selling my NEX7 to pick one up. Thanks for doing this.
 academytim's gear list:academytim's gear list
Sony a6300 Sony E PZ 18-105mm F4 G OSS Sigma 16mm F1.4 DC DN (Sony)
I should compare it to the Fuji ct1.
too many cameras...
New: Added Fujifilm X-T1 with 56/1.2 for comparison
X-T1_JPG.zip 40.1MB: (ISO100 to 25600)
https://mega.co.nz/#!jUwUzCBS!jRxtmhUTNF6TuTYrl-0sDP7kwj7w3oX0K36CiSTCbEA
X-T1_RAF.zip 151.6MB: (ISO200-6400 only, X-T1 does not allow RAW at ISO100, and above 6400)
https://mega.co.nz/#!fchVQbqA!ESt_ovmor6wcVK4C1-7u6ofD_41vg7unIr9H3xQs1oQ
too many cameras...
DimitriDV Regular Member • Posts: 361
Just for the sake of it, here is the iso 6400 shot developed in RawTherapee with all neutral settings, with only the preset high noise reduction option and +40 contrast:
iso 6400, high noise reduction, +40 contrast
For anybody using this tool (RawTherapee), for the A6000, under the "raw white & black points" label I have set all the black levels to 512. I read somewhere online that 512 was the value for another Sony camera, I think the Nex-7; looks fine to me also for the A6000.
Iso 6400 looks very usable to me, cannot wait to get my A6000...
Adding the pp3 profile I used: pp3
Some photos taken since I bought my Nex-6&7: http://www.flickr.com/photos/dimitriv/
Re: New: Added Fujifilm X-T1 with 56/1.2 for comparison
Looking at the RAW files, the a7R is actually quite a bit cleaner than the a6000, especially in terms of Chroma noise. Not difficult to remove.
The X-T1 ISO6400 RAW looks really impressive.
too many cameras...
davidstock Regular Member • Posts: 412
ISO6400 X-T1 vs a6000
Screen Cap of Lightroom. No adjustments in LR. The entire Details Tab is turned OFF (No Sharpening, No NR)
too many cameras...
cxsparc
cxsparc Veteran Member • Posts: 3,430
Fujifilm X-T1 comparison - it ain't the (full) truth :-)
6
Yes, but you overlooked the fact that ISO6400 for the Fuji is - again - not ISO6400 of the Sonys.
Fuji "cheats" compared to Sony, if you take a look at the exposures for ISO3200 1/250 Sony, 1/160 Fuji XT1; ISO6400 1/500 Sony, 1/320 Fuji, thats about 2/3 of a EV.
So the Fuji runs at about ISO4000 instead of the displayed ISO6400. If you now compare ISO3200 Fuji with Sony ISO6400 (slightly unfair to the Fuji), then the results look very similar.
This is one thing which really turns me off with the Fuji cameras, same thing with the X-E2 which I tested in parallel to my aging Sony 5N, full stop difference at otherwide identical conditions (e.g. f8, ISO400, doubled exposure times with E2).
Since many people do not have the opportunity to directly compare, but instead just see "ISO6400" and marvel how good the picture looks, this seems an effective way to enhance Fujis market opportunities with - in my view - dishonest methods.
No offense meant to you of course, thanks a lot for sharing your experiences here
But possible add another crop comparison of ISO3200 to ISO6400 to show the audience what impact this has.
Another thing to note: The Fuji shots are focussed further back then the Sony.
 cxsparc's gear list:cxsparc's gear list
Sony a6000 Sony Alpha NEX-5N Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS +3 more
