XF60mm, aperture issue
Started Mar 22, 2014 | Discussions
MarinoDiMare Contributing Member • Posts: 504
Hi, new to the X System forums, not new to DPreview. I've been seriously loving my Fuji X machines, first the X100, which I have replaced with an X-pro1. I have a kit with three primes, the 18mm, 35mm and 60mm XF lenses.
Just today as I was shooting some further away subjects I mounted the 60mm, but quickly noticed there was a problem. At any aperture above f/3.6 everything is fine, but if I go wider, i.e., what should be f/3.2, the camera reports it's at f/6.4. Any wider and it jumps to P mode (the shutter dial is at A). The other lenses don't have this problem.
Is this a known issue? Does anyone know of a solution? And, before anyone asks, yes, I cleaned the lens' contacts.
Many thanks for your input!
 MarinoDiMare's gear list:MarinoDiMare's gear list
Fujifilm X-Pro1 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +7 more
Fujifilm XF 60mm F2.4 R Macro Fujifilm X-Pro1
