E-M5 and 60mm Macro: How to manally focus?
Started Mar 22, 2014 | Discussions
Oli4D Contributing Member • Posts: 530
Hello everybody
I own a OM-D E-M5 and the 60mm 2.8 macro lens.
What I don't get is how to use the ring on the lens.
I suppose it's for manual focus... but when I use the ring, the camera switches to 14x magnification.
That's probably not what it is supposed to do?
How do I use the ring to manual focus, especially when the lens is set to 1:1?
Thanks a lot
Oliver
Here some shot's I did so far with this combo:
http://www.flickr.com/photos/oli_4d/8994582049/
http://www.flickr.com/photos/oli_4d/10379646265/
http://www.flickr.com/photos/oli_4d/10481474423/
http://www.flickr.com/photos/oli_4d/8150189862/
 Oli4D's gear list:Oli4D's gear list
Panasonic Lumix DC-G9 Olympus E-M5 III Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus OM-D E-M5
RoelHendrickx
RoelHendrickx Forum Pro • Posts: 28,473
Re: E-M5 and 60mm Macro: How to manally focus?
Turn off auto-magnification (I believe it is called focus aid or something like that in the menus).
If you have it "on", magnification kicks in as soon as you turn the focus ring.
You can map the magnify function to a button.  That way, you can choose not to have the auto-magnify in every case, but still have quick access to magnification if you want it.
Roel Hendrickx
lots of images: www.roelh.zenfolio.com
my Olympus user field report from Tunisian Sahara: http://www.biofos.com/ukpsg/roel.html
sinkas Senior Member • Posts: 1,609
You can change the magnification from 14x to 10x to 7x to 5x by rotating the front dial while manually focussing. You can turn off MF assist in Menu, Cogs, AF/MF, Mf Assist Off.
For macro photography at 1:1 turn off AF and you should move the camera not try and focus.
Regards Daryl
Hobbes: You're ignorant, but at least you act on it.”
Bill Watterson, The Authoritative Calvin And Hobbes
 sinkas's gear list:sinkas's gear list
Nikon D7200 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Teleconverter TC-14E II +5 more
JeanPierre Martel Veteran Member • Posts: 3,304
To do (strictly speaking) macrophotography, the steps are:
— put the camera in manual mode (4th item, at left, in the menu/AM-MF/AF mode/Still Picture/MF)
— Set the priority to Aperture Mode ("A" on the dial)
— Select the aperture needed (for the Depth of Field that you want)
— (_Don't_ turn the Focus ring): set focus by moving the camera toward the subject or vice-versa
The focus ring is used in manual close-up photography, not macrophotography.
For detailed instructions, use Google to load that text (in French) in order to get a rough English translation:
http://jpmartel.wordpress.com/2013/01/06/m-zuiko-60mm-macro/
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
uRebel Rob Senior Member • Posts: 1,537
Oli4D wrote:
Hello everybody
I own a OM-D E-M5 and the 60mm 2.8 macro lens....
Thanks a lot
Oliver
Most of this has been mentioned, but with that lens, macro photography is easy:
  • Put camera in manual focus
  • rotate the four position focus range dial (to the left of the magnification gauge) to the 1:1 postion, wait for it to go to 1:1 (it's quick, though), let go (it will go back to to the "0.19-0.4m" position. (if it magnifies, wait a little, or half press the shutter button to make the biew return to normal)
  • move camera until what you want in focus is in focus.
If you use the focus ring when in 1:1 mode, you can only focus in one direction: less than 1:1. If you look at the lens, focusing on something 0.2m instead of 0.19m, you get a 1:1.3 not quite macro instead of true 1:1 of 0.19m with this lens.
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
Phil Rose Veteran Member • Posts: 3,912
To add a bit to what has already been mentioned, it's useful to know that one can assign the "focus magnification" mode to a button (I use Fn2); so--without needing to touch the manual focus ring--I can activate the enlarged view and then half-press the shutter button and move the camera back-and-forth to establish my desired focus. Works well to have the OIS turned on (with half-press of shutter) to avoid jitter while viewing the focus.
Phil
 Phil Rose's gear list:Phil Rose's gear list
Olympus E-10 Olympus E-1 Olympus E-3 Olympus E-M1 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +7 more
jlehet Regular Member • Posts: 131
Three things with this camera and this lens for macro photography:
1) This is a pretty-much unbeatable combination, though other mft bodies with this lens will of course work well.
2) The usefulness of tap-to-focus-and-expose on the rear LCD can't be overstated for macro work. It's the best thing ever.
3) A good setup if you want to focus manually with the ring is to de-couple the focusing and the shutter button. I have fn2 as the focus button, not the shutter button. That way you can use the ring but not press fn2, or focus with fn2 and then the shutter button doesn't refocus.
krugman Contributing Member • Posts: 957
This is extremely helpful. In the hope that my own experience might be helpful to someone, I will briefly state it here.
I am about to undertake the digitization of thousands of slides, and I have discovered 3 ways of doing it rapidly in large numbers, using a camera. (A scanner takes 4 minutes a slide; commercial digitization costs $.69 per slide or only $.22 if I am willing to send my precioius slides to Bhutan).
My tests so far show that the Oly 60mm macro is superb for this purpose as well as being a fine portrait lens. This is consistent with the reviews of SLRGear, Ming Thein, and others, who find this lens superb. I am using an Oly EM-10.
Formerly I tried slide digitization with a Nex 5n and the Sony 30mm macro. The Oly 60mm is far superior; I returned the 30mm.
I have been using ShotCopy so far, to hold the slide and move the camera on the ShotCopy base. A very good system.
Recently I acquired from Dodd's Camera in Ohio, a Kiwi macro sliding rail for about $80, a small fraction of the price of similar units, and it turns out to be a precision instrument, calibrated, very well made.
I wish to work on a desktop rather than a tripod, so I will mount the Kiwi unit on the ShotCopy base and I will be able to move the camera a fraction of a millimeter in each of 4 directions: forward and back, or side to side. The ShotCopy slide holder can be moved up and down, or rotated on a vertical axis.
It is very helpful to know that for macro, the idea is to move the camera, not use autofocus or manual focus. I didn't know that.
The OM-10 has focus peaking, so that should be a major help as well.
The Kiwi unit will be helpful in the other two methods I have in mind, which are even faster and easier than ShotCopy (which can copy 12 slides in 2 minutes).
I also acquired for about $49 a very good light box, 10" x 12," with two internal lights, by PortaTrace, from Amazon, for use in a second even faster method of digitization. It looks to be of very high quality.
I hope this information will be helpful to other forum members.
(I have no connection with any of the firms mentioned here.)
Krugman
Thank you, very clear and helpful, I am saving it.
Krugman
Thanks for your tips about copying slides. I will book mark your info.
To clarify what I said previously, using the Oly 60mm you don't actually need to turn AF off before turning the dial to 1:1. The idea is to turn the dial to 1:1 and move the camera backwards and forwards to obtain focus. At all other ratios (other than 1:1) the AF is actually quite useful.
Regards Daryl
Joseph T Lewis III Veteran Member • Posts: 3,594
Post deleted / I misunderstood what was said / sorry
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus PEN-F Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
As a correction, I don't own  Kodak PixPro 1 and I don't know how it got on my gear list.
Krugman
