OT JVC 3D camcorder Anyone have one ,like it or not , Still images .
Started Mar 21, 2014 | Questions
LDS Scoutmaster Junior Member • Posts: 26
Thanks am looking to get one now that the price is low but wondered about the still images compared to Fujifilm 3W
Thanks in advance again.
crunchy_3d Regular Member • Posts: 149
Re: OT JVC 3D camcorder Anyone have one ,like it or not , Still images .
I have the "Pro" version (GY HMZ1). Picture quality is not spectacular (I've tried time-lapse function and ordinary video quality seems higher). Note that video at 60i is sharper than at 24p. Video quality is OK, but don't use shutter speeds lower than 1/60s. Otherwise you'll loose resolution and will get some artifacts.
3dreal Senior Member • Posts: 2,271
Lower than 1/60 shutterspeed: 1/30 1/15?
Which model do you mean?
For NTSC model GY HMZ1 all shutter speeds below 1/60s (e.g. 1/30s, 1/15s,...) result in lower-resolution picture and for PAL model GS-TD1 the same holds for shutter speeds below 1/50s (e.g. 1/25s, etc.).
Therefore it seems that no matter which camcorder you use (consumer or prosumer), lower shutter speeds result in not so sharp picture (of course, it holds for static pictures as well). This is based on my observations.
For GY HMZ1 the same is valid for 24p video (if shutter speed is dropped below 1/48s). Moreover, counter intuitive (counter common sense), the picture is sharper in 60i mode than in 24p mode.
I've described the problem on another forum some time ago:
http://www.avsforum.com/t/1453179/the-difference-in-pq-between-jvc-gy-hmz1-and-gs-td1
See post #20 and the link to files on the server.
D.
