Panasonic 12-32 on Olympus bodies
Started Mar 17, 2014 | Questions
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
Hi,
I just ordered the 12-32 for my wife's E-PM2 - the 17/2.8 is out, tried it and sold it. It's ok, and quite decent in the centre, but I noticed it often missed focus with the touchscreen. She wants a zoom, and I like the 12mm of the Panasonic, and do NOT like the EZ only Oly 4-42EZ. By most accounts, the 12-32 matches the 14-42IIR pretty closely for IQ, which should be fine.
Can the OIS be disabled on an Oly camera, or is disabling the IBIS the only option? Any other feedback on this lens specifically on Olympus bodies?
Thanks.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
Olympus PEN E-PM2 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS
bgalb
bgalb Senior Member • Posts: 2,179
Re: Panasonic 12-32 on Olympus bodies
Your answer is HERE
 bgalb's gear list:bgalb's gear list
Panasonic Lumix DMC-GM5 Olympus E-M1 II Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Panasonic 20mm F1.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +4 more
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
zuikowesty wrote:
Hi,
Thanks.
I think you will find that the OIS is superior to the IBIS on the EMP2.
I have this lens on my EPL5 and have it set for OIS rather than IBIS.
To use OIS, you must have an EPM2/EPL5 or newer. This will not work with the EM5 or older.
Allan
frankmurphy Junior Member • Posts: 38
How is the purple with this lens on Olympus bodies? I know that the Panasonic UWA zoom has significant purple blobs. Does that show up with this lens?
 frankmurphy's gear list:frankmurphy's gear list
Olympus OM-D E-M10 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
W A Stewart Senior Member • Posts: 1,025
I think this is about the 12-35mm. If so, no blobs of any color. Excellent lens.
W Alex Stewart
 W A Stewart's gear list:W A Stewart's gear list
Olympus OM-D E-M5 Olympus E-M1 Nikon D810 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
LMNCT Veteran Member • Posts: 4,908
No, it appears to be about the 12-32 (from the GM1).  I have that lens plus the 12-35 f 2.8 and they are both fine on the EM5 and EPL5.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Let's get stabilised
bgalb wrote:
Your answer is HERE
Yes, those are the stabilisation rules as per Guy. Hey! That's me.
On E-PM2 use the Custom menu to turn on Lens IS Priority, then in the SCP turn on IS1 (IBIS), then the much preferred OIS works instead of the IBIS.
If you swap to a lens that has no OIS then the IBIS works, no need to fiddle with the Lens IS Priority setting at all, just leave it on.
If you want no stabilisation at all then just turn off IBIS in the SCP, it is the master switch for all stabilisation.
Regards..... Guy
Allan Brown
No purple blobs with the 12-32. PF is much about the same as I get with my mZ 9-18 - not really an issue.
Allan
zuikowesty
OP zuikowesty Veteran Member • Posts: 4,158
Thanks Guy & bgalb!
Looking forward to trying this little guy.
zuikowesty
Allan Brown wrote:
zuikowesty wrote:
Hi,
Thanks.
Allan
Really, it won't work with the E-M5? Is it that ancient already? Or is this just the first OIS lens without a physical switch?
zuikowesty
Thanks everyone for the feedback - much appreciated!
ristar Regular Member • Posts: 338
The OM-D E-M5 was the last Olympus camera released without the ability to switch on OIS from in camera. However, the Panasonic 12-32mm is not the first lens without a physical switch for OIS. For example, the Panasonic 14-42mm (original) and the 14-42mm PZ were released before the E-M5 and do not have physical switches for OIS either.
Panasonic's high end lenses (e.g. constant aperture zooms, 42.5mm f/1.2) and their earlier lenses (e.g. 14-45mm) have physical switches. Not sure which was the first lens to eschew the physical switch.
 ristar's gear list:ristar's gear list
Olympus OM-D E-M10 Olympus E-M1 II OM-1 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +11 more
PDavis Regular Member • Posts: 475
The 12-32 works amazingly well on an EM5 and EM1.  At f/4 I could barely tell it from the 12-40 at the wider end.  Even at 100% crop it really holds up to the corners.  MUCH sharper than my 9-18 in the overlap range.  It did have a little PF (12-40 is auto corrected) but it came out nicely using the LR5 tool.
 PDavis's gear list:PDavis's gear list
Sony a7R IV Tamron 20mm F2.8 Di III OSD Tamron 28-200mm F2.8-5.6
Ron Outdoors Senior Member • Posts: 1,168
The Panasonic 45-150 also has no switch. On the E-M5, the camera defaults to IBIS.
www.ronhartman.net
 Ron Outdoors's gear list:Ron Outdoors's gear list
Olympus E-M1 II Sony a7R IV Olympus Zuiko Digital ED 50mm 1:2.0 Macro Sony FE 90mm F2.8 macro Panasonic 100-300mm F4-5.6 II +7 more
Perhaps my previous message was not clear. It was not meant to be an exhaustive list of lenses with no switch, hence the use of "e.g." Besides, the 45-150mm is newer than the E-M5 so I do not consider it to be an "earlier" lens and it is definitely not a "high end" lens. I guess I should emphasize I am satisfied with my copy of the 45-150mm.
Allan Brown
zuikowesty wrote:
Allan Brown wrote:
zuikowesty wrote:
Hi,
Thanks.
Allan
Right, the OIS will not work on an EM5. I don't know if this feature was added with the new firmware update. If not, it should have been.
Otherwise, the lens works just fine on the Oly bodies.
Allan
zuikowesty
Thanks again...
Thanks for the info! I am not too familiar with Panasonic gear, but am looking forward to trying the 12-32 even more.
thxbb12 Senior Member • Posts: 2,211
I guess I must either have a poor 12-32 sample or an awesome 12-40.
My 12-40 is really tack sharp at all focal lenghts straight from f/2.8. Even in the extreme corners.  Truly amazing!
However, my 12-32 is nice and sharp in the center, but the corners never truly sharpen up, even closed down. I did some comparison tests at 12mm between it and the 12-40 and the difference is significant.
 thxbb12's gear list:thxbb12's gear list
Fujifilm X-T20 Fujifilm X-S10 Fujifilm X-E4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +5 more
zuikowesty
Best IS setting for E-M5 & 12-32?
I have started carrying the 12-32 on my E-M5 to make it more pocketable, but I am not sure if I should turn IS off (which means both IBIS and OIS I believe), or leave it at IS-1 and let the two systems sort it out. I guess I will need to test it.
What have others found? Is dual IS better or worse than no IS? Does it depend on conditions? btw, I have switched to 1/4s anti-shock after seeing SS at 1/8s and 1/125s exposures. Not sure if this made worse by having two IS systems working at once.
Guy Parsons
Some stabilisation truths.
The E-M5 has the early firmware that cannot control unswitched OIS so the 12-32mm OIS defaults to always off. Using IS-1 will only control the body stabilisation.
Later bodies have a Custom Menu item of "Lens IS Priority" so can they use unswitched OIS.
So, only the body stabilisation can work, and that would be preferable to lens OIS because OIS is always only 2 axis correction, and the E-M5 is 5 axis correction, that adds the roll correction as the third axis. The remaining two axes are parallel body shift up/down/left/right which matters more for macro. I would say the 3/5 axis stabilisation would be way preferable for extreme cases, such as a video while walking.
If you could have two stabilisation systems working together then the results would be a disaster. (possible with E-M5 and earlier bodies and a switched OIS lens, impossible on later cameras as they interlock to one only functioning).
Regards..... Guy
