AdamT
Bargain Gem oft passed over
This is a Hidden Gem mirrorless with even more hidden and Gemlike 20-50 kit lens (Sharp edge to edge with little CA, far better than the 18-55 and most Mirrorless kit lenses) , In RAW it shames cams costing far more . Decent handling, fast accurate AF, totally superb sensor which holds up better than the canon 18Mp unit , the samsung 20Mp has a Weak AA filter, great Dynamic range and very decent & competitive High ISO performance.....
The cam has Decent build too despite being all plastic and feels a lot better in the hand than a NEX3 series. the whole plot is let only down by lack of EVF option, underused Ifunctionality (Forces you to press a button before using the lens ring - not set and forget like an S90 or RX100), massive RAW files and lacklustre JPG engine, the range of flashes could do with updating........ . Avoid 2000 model, it takes Micro SD and is run almost solely by touchscreen.
The NX1100 apears to be the same as the 1000 but with the QC bugs fixed (Dry joint issues causing WiFi malfunction and even worse, Lens communication failure in some samples) and with the 1100, Adobe Lightroom is thrown in. the NX210 added bling and an extra command dial but very little else to the 1000 series, even the build isn`t really any better despite the metal front, the 300 seems to offer little more too ....
IMO The real star NX is the 20 (or 30 if you`ve got money to burn), it`s smaller than you`d think and the EVF Rocks . funny how you don`t see many secondhand - loadsa the others even the 300 but not the 20 ....
This cam gets 5 stars because of the optically superb kit lens, the fantastic lens selection, the excellent sensor and the silly low price .
