Milkyway photos with the NX300
Started Mar 15, 2014 | Discussions
farmersride Junior Member • Posts: 35
So my next goal with this camera is to take a photo of the milky way.   My understanding of this type of photo is that you must follow the 500 rule to prevent streaking while at the same time getting enough light on a VERY DARK night to bring out all the stars.  With my kit lens at 18mm this is a 27mm equivalent so in order to prevent streaking I'd have to limit the shutter to 18.5 seconds.  In my experience so far with astrophotography this will not produce a bright star shot with f3.5 and ISO less than 3200.
So here's my question - I know it's possible to align photos with hugin (thanks for the hint ttbek) but I've never done this for the purpose of cropping all the photos to the same frame and then stacking them.  Has anybody on here done this in order to take milky way photos? any tutorials you know of?
I'm going to make the drive to my nearest dark sky area on the next clear new moon and I want to make sure I have the processing part of it figured out before I go.
Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX300
ttbek Veteran Member • Posts: 4,869
Re: Milkyway photos with the NX300
Hmm, you know, I haven't tried to do the exact overlay in hugin, just the panorama overlaying the edges.  There is another program though, Luminance HDR, that makes use of the Hugin code that I think makes it pretty straightforward.  I'll poke around a bit later to see if there are any good tutorials for this with either program as I'm not really up for making a tutorial right now.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
sixfootzero
sixfootzero Contributing Member • Posts: 674
You could check the astrophotography forum at cloudynights.com...
 sixfootzero's gear list:sixfootzero's gear list
Samsung NX100 Fujifilm X-E1 Fujifilm X-H1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +4 more
OP farmersride Junior Member • Posts: 35
I found instructions for this operation with hugin. It also can be used to do focus stacking for macro! Are there any free programs that do focus stacking for you?
http://hugin.sourceforge.net/docs/manual/Align_a_stack_of_photos.html
Ah, sorry I didn't get around to finding some sooner.  I've been arguing with a broken Canon lens... I know the problem, just now quite how to fix it, as the issue is little bits of plastic that have snapped -_-.  I use GIMP to focus stack, but it's a fairly manual operation of applying a layer mask to each layer with a largish soft brush.  Maybe a plugin will give the nice auto stacking Photoshop does, I haven't really looked.
