Any telephoto zoom 4/3 Lenses for E-M1 that are much better than similar m4/3?
Started Mar 9, 2014 | Discussions
(unknown member) Senior Member • Posts: 1,803
Here's a new angle/question. First, the basic facts:
1) EM-1 will natively use older 4/3 lenses.
2) E-M5 will not use older 4/3 lenses without adapter kludge.
3) The m4/3 lens lineup for zoom telephotos is somewhat different than the older 4/3 lineup.
4) General consensus is that the advantage of the E-M1 over the e-m5 is not image quality, but somewhat better autofocus for moving objects. On the other hand, the E-M1 is bigger.
Question: For people who have both the e-m5 and e-m1, and familiarity with the speed of focusing and image quality of zoom telephotos for both 4/3 and m4/3, are there any zoom telephoto lenses FOR 4/3 that are better than, for example, the Olympus 75-300 II?
Olympus E-M1 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II
liviutza Contributing Member • Posts: 502
Re: Any telephoto zoom 4/3 Lenses for E-M1 that are much better than similar m4/3?
5
Oly 50-200 2.8-3.5. Legendary, it seems.
 liviutza's gear list:liviutza's gear list
Canon EOS 6D Olympus OM-D E-M10 Canon EF 50mm F1.4 USM Canon EF 100mm f/2.8 Macro USM Canon MP-E 65mm f/2.5 1-5x Macro +6 more
OP (unknown member) Senior Member • Posts: 1,803
How is the focusing speed on an e-m1?
Bob657 Veteran Member • Posts: 3,486
I have both and should correct one thing, the EM1 and EM5 both need an adapter to use 4/3 lenses, the major difference is the EM1 effectively auto focuses them and the EM5 doesn't. While I have a Panny 100-300, I generally use the 50-200 plus EC14 teleconverter because of its' higher quality. The penalty is a much heavier lens though.  Focus speed is acceptable for all but the fastest action.
Olympus has announced a 300 f4 prime will be released in 2015 for micro 4/3, which likely will be the best solution.
Bob G
 Bob657's gear list:Bob657's gear list
Sony a6400 Sony a7R IV Sony FE 100-400mm F4.5-5.6 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD
Godfrey Forum Pro • Posts: 29,636
More than satisfactory for my use. Not fast enough for some others' needs. It's as fast in use as it was on my E-5 and certainly faster than it is on my E-1.
The Olympus M.Zuiko 75-300 Mark II seems to have very nice image quality too, and probably slightly faster focusing action, but it's a slower lens. It's also much smaller and lighter.
Trade offs... I have the ZD 50-200/2.8-3.5 because it fits both my E-M1 and my E-1, and it makes beautiful photographs. And because it works well with the EC-14 teleconverter, and has a sturdy tripod mounting foot of its own. It's also weather sealed.
I suspect the ZD 35-100/2 and ZD 90-250/2.8 are also better quality telephoto-zoom lenses than anything in Micro-FourThirds mount at the moment too, but these are full-on professional grade lenses with lens speed and prices to match.
I should clarify my last post, auto focus is fine on the EM1 only.--
Bob G
Wallybipster Senior Member • Posts: 1,668
Any of the HG or SHG 4/3 lenses are better than anything native MFT
As far as I know, all the 4/3 lenses work decently well with the E-M1.  And since there are no alternatives with similarly bright apertures, you could argue they are all better than any native MFT lenses, before you even get to a discussion of image quality or focus.
I personally shoot the old 150mm F2 with both teleconvertes, and I find it works fine on the E-M1.  Since there isn't any sort of equivalent until the 300mm F4 for MFT comes out, I have nothing to compare it to.  I hope to get my hands on a 50-200 at some point as well, since it'll be a stop faster and sharper at 283 mm with the teleconverter when compared to the 75-300, which is an ok lens for what it is.
Just my two cents, there aren't many options currently for MFT once you go beyond 150mm.
Wally
 Wallybipster's gear list:Wallybipster's gear list
Olympus E-M5 II Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 75mm F1.8 +6 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
E-M1 also requires "adapter kludge".
Yes
Yes. The 50-200 is a very good lens (High Grade in Olympus' terms). This will be better than any existing M4/3 tele for IQ, but not as fast for focussing. It's very bad for focussing on the E-M5, but most people find it usable on the E-M1. With a 1.4 teleconverter it gets out to 283mm.
Above that is the 90-250 f2.8. This is a Super High Grade lens. It will cost several thousand dollars, and weigh several pounds. IQ is exceptional. Focussing is slower than M4/3 lenses, but, as above, apparently usable on the E-M1.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Bob G
Thank you for the correction.
I had thought the E-M1 did not need an adaptor. This makes all the difference, at least to me. It makes the whole contraption cross my "There's a reason I bailed out of Canon" line.
FWIW, I had the Panasonic 100-300 also, and on both my former GH2 and current e-m5, it focused much slower than the Olympus 75-300.
I agree it's nice and light. I've found the IQ of the 14-150 to be almost comparable to the 75-300, and so in some cases have an incredibly light 28-300 camera combo.
But better IQ is desired. I recently shot a whole bunch with my 45mm 2.8, and 75mm 1.8, and am starting to have worse feelings for both the 75-300 and 14-150.
Anders W
Anders W Forum Pro • Posts: 22,144
Have you actually shot side-by-side test images with the 100-300 versus the 50-200 with TC? Even if the 50-200 would be a better lens wide open than the 100-300 wide open, it would surprise me if the difference is such as to make up for the use of the TC. Using the TC means that you will be left with only about 70 percent of the lens resolution that the 50-200 is capable of when used without add-ons.
Bob G
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
DonSC Senior Member • Posts: 1,032
Not convinced
that the 50-200 + TC is better than the m.43 zoom. I'd love to see some side by side shots. If it were appreciably better I'd pick up the m.43 zoom. Unfortunately I think Anders is right that the TC will degrade the quality.
gandalfII Senior Member • Posts: 1,952
Re: Not convinced
There is no noticeable image degradation with ec14 and 50-200.  There is some using it with the 50 macro at infinity but none in the macro range.
Anders W
Re: Not convinced
A 1.4 TC takes the resolution down to about 70 percent of what it originally was (if the TC is very good). In a side-by-side test with and without TC at the same subject magnification, that's likely to show. Have you done any such testing? If so, are you willing to share the visual evidence with us?
drj3 Forum Pro • Posts: 12,632
Re: Not convinced
Any lens is has better image quality without a TC.  However, the 50-200mm SWD with EC14 still gives very good results at all focal lengths.  It is exceptional without the TC.  I cannot compare it to the 75-300, since I do not have that lens.  I can compare the combination EC14+50-200 to the FTs 70-300 which appears to be similar in quality to the 75-300 and the 100-300 Olympus and Panasonic mFT lenses.  The  EC14+50-200 is considerably better than the FTs 70-300 at any aperture or focal length (better contrast and sharper - 70-300 loses some quality at 300mm).  However, the largest difference is in the ability to use the EC14+50-200 wide open.  The 70-300 must be stopped down at least to f6.3 and better to f8.  The EC14+50-200 can be used at f5.  This allows one to keep the shutter speed higher and/or have a lower ISO and thus get better image quality than one would get with a slower lens.  Unfortunately, I cannot show you any direct comparisons between the two with the E-M1, since I have only used the 70-300 once to see how it worked with the EC14 since I got the E-M1 (70-300 +EC14 not great, but does give you 850mm equivalent).  Attached are a couple of images with the EC14+50-200, the first with the junco wide open (f5 with bright backlighting - sun and snow) and a bee stopped down (f9) to give some idea of what you could expect.  However, there are penalties in terms of size, weight and price compared to either of the current Olympus and Panasonic mFTs telephoto zoom lenses.  These problems were not important for me, since I already had the lens and EC14 and the combination is much lighter with the E-M1 than the E5.  MFTs users may find the combination too large and heavy and I personally would advise using them with the grip.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
offtheback
offtheback Senior Member • Posts: 1,100
I use a 50-200 and 75-300 with EM-1.50-200 is noticeably sharper.50-200 focuses decently on static subjects.If there is no vertical line in field of view you can twist camera slightly and lock focus.The 75-300 focuses noticeably faster in most conditions.The slow aperture of 75-300 is a drawback.
offtheback
I recently got the 1.4 TC for the 50-200 and the combo seems slightly sharper than the 75-300 but not by much.The combo is still faster aperture wise.I use the combo with a pistol grip.
Would be great
if you could take a few back to back shots with the 5-200 + TC and the 75-300. At the long end of course.
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Re: Not convinced
I can even say you don't need the TC to replace the 75-300mm lens:
If you stop down the 50-200 to its sweet-spot 200mm/f5.6 it this much sharper than the 75-300Mk2 I owned, that you can upscale the picture 150% and it is still sharper than the at its sweet spot 75-300mm @f8.
But if you use the FT lens wide open, you get a fast tele (200mm f3.5) and a very sharp portrait lens (100mm f3.1).
And the 50-200mm shows less shutter shock due to uts weight.
I sold my 75-300mm after comparing it to the 50-200mm ...
OM-D + Sam7.5, PL25, O60, O75
P12-35, O75-300
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
Re: Not convinced
I wondered whether just uprezzing the image from the 50-200 might be better. However, there are two issues. One is how much better? if it's marginal then it's not worth the trade-off. This is why side by side examples would be nice. Second is whether the C-AF for the 50-200 SWD is on a par with the m.43 75-300. Static images I can manually foucs but BIFs and/or action are a different story.
I'm really only interested in the long end.
