35mm equivalent not good for portrait ?
Started Mar 5, 2014 | Discussions
Bouddha Regular Member • Posts: 349
Hi all,
I am using my X100s and my d600....
one says that usually for portrait 85mm or more is the way to go.
Is the 35mm of the X100s that bad for portrait of head and shoulders ?
rgds
Fujifilm X100S Nikon D600
57even Forum Pro • Posts: 11,428
Re: 35mm equivalent not good for portrait ?
Bouddha wrote:
Hi all,
rgds
Its not so good for a close up, but its great for a more relaxed composition. Hard to isolate background though if that's what you want.
Whether it suits a particular subject rather depends on their face.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
OP Bouddha Regular Member • Posts: 349
Thanks.
Do you think the 50mm teleconverter will solve that ?
John Gellings Senior Member • Posts: 3,167
Why not just try using the lens to see if you like the results?
 John Gellings's gear list:John Gellings's gear list
Fujifilm X100F Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm XF 35mm F2 R WR +4 more
I did that and am fine with the 35mm equivalent.
honestly other than out of focus background, I don't really see the difference with my 85mm 1.8.
also I find the 35mm f2 brings enough isolation but still keeps the possibility to understand the environment in which it was taken, which I find IMHO cool.
Brad Evans Contributing Member • Posts: 616
Re: it's great if you lik context
5
If you like  context with your portraits, 35mm is ideal.
These street portraits  were all taken with a 35mm lens, in one San Francisco neighborhood (the Tenderloin).
Brad
Urban photoblog: http://www.citysnaps.net
LaFonte Senior Member • Posts: 2,790
Bouddha wrote:
Thanks.
That would be one of the main reason for the 50mm Tele.
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic FZ1000 Fujifilm X-Pro1 +2 more
Brad
superb portraits Brad!
Thanks, nice shots.
a few of yours are portraits head and shoulders, so should I assume a 35mm is still ok for that ?
headofdestiny Veteran Member • Posts: 9,226
Bouddha wrote:
Hi all,
rgds
Ultimately, the closer you stand to the subject, the more bulbous facial features become, and, the further you stand from the subject, the more compressed features become.  It's up to you to decide the look that you prefer, and it may vary, depending on the subject.
A lot of people like shooting wide angles up close on kids, because it makes them look a bit more cherub-ish.  Heck, Platon uses wide angles up close for portraits of adults all of the time. When I use a 35mm lens, I tend to stay far enough away from a subject that I still see their bellybutton or chest area, but it depends.
mr moonlight Senior Member • Posts: 1,789
It's fine for waist up portraits, but if you want close ups (head and shoulders or closer) you're going to run into compression issues. 35mm is a bit wide so you end up have to be quite close to your subject. This will create often unflattering distortions of the face such as a larger nose and fatter cheeks. A longer lens like an 85mm will flatten out these features making your subject look thinner and less distorted. So if you're going for a headshot with a 35mm lens, pull back a little and crop in if you want to avoid facial distortions.
t3htriste
t3htriste Regular Member • Posts: 107
Whoa, those are some really cool photos you got there!
 t3htriste's gear list:t3htriste's gear list
Fujifilm X100S Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 14mm F2.8 R +5 more
ketsang
ketsang Regular Member • Posts: 236
It depends on your subject too. Some people looks nicer with a bit of distortion
You know those selfies you see on Facebook taken using iPhone? Some of them looks quite nice. IPhone 5s has a 29.7mm equivalent focal length.
Ket Sang Tai
http://www.flickr.com/photos/ketsang/
www.kstphotography.net (under construction)
 ketsang's gear list:ketsang's gear list
Fujifilm XF 10-24mm F4 R OIS Fujifilm X-T2 Fujifilm X-E3 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +11 more
Thanks!
Brad
Bouddha wrote:
Thanks, nice shots.
You do need to exert a little caution. A subject's hands held out in front when shooting that close with a 35mm lens can appear unusually large. Also, shooting closer, depending on face orientation can result in largish noses.
If all you are going to be making are head and shoulders shots, a 50 or 85mm would probably be better. But... If environmental context is important to your portraiture (important to me- helping release narrative in a viewer's mind), then a 35 is a good choice. A 50mm would work fine, too. You just need to be further away. For my kind of street portraiture, many times that would put me off the sidewalk and into the street - not a place I want to be considering traffic! A 35mm lens is also a good choice for candid street shooting.
One more thought... For me, good portraiture comes from the relationship you establish with your subject; i.e. conversation, humor, trust flowing in both directions. Shooting closer rather than farther away helps establish that.
Brad
esmall Contributing Member • Posts: 653
Brad Evans wrote:
Bouddha wrote:
Thanks, nice shots.
Brad
Brad your street portraits are amazing.  I'm working up the courage to attempt this style of photography my self.  Do you have any other tips to share for a newbie to street photography.  By the way, I'm in San Jose and I'm hoping to make may way to San Francisco to try my hand at some street shooting so if you have any suggestions on places to visit in the city that would be great!
Thanks!
Ernest
a77/a300/CZ 24-70 f2.8/Tamron 10-24mm/Tamron 70-200 f2.8/Sony 35mm f1.8/Tamron 17-50 f2.8/Minolta 24-105/Minolta 100-200/Minolta 50 f1.7/Tamron 90 SP Macro
http://www.ernestsmallphotography.com
See my PhotoStream
http://www.flickr.com/photos/ernestsmall/
 esmall's gear list:esmall's gear list
Fujifilm X-E1 Fujifilm X-T10 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18mm F2 R +4 more
rjx
rjx Contributing Member • Posts: 917
Watch this video -- Effects focal length has on the face
https://www.youtube.com/watch?v=ZRoqNx9rlVA
Video shows the effects different focal lengths have on the face.
 rjx's gear list:rjx's gear list
Sony Alpha a7 II Sony FE 28mm F2 Sony FE 85mm F1.4 GM Sony FE 70-200mm F2.8 GM OSS Zeiss Loxia 50
Lisa O
Lisa O Senior Member • Posts: 2,499
35mm focal length is good for environmental portraits and perhaps small group portraits. 85mm to about 135mm is classic portrait focal length. The longer lenses compress space a bit making for a more pleasing look with no foreshortening of features you get with a wide angle lens. With a wide lens features that are closer to the lens often appear much larger, so if you ltook a head and holder port rail with a 35mm the nose or the forehead could be out of proportion.
see about me in my profile for more info
http://500px.com/LisaOsta
http://www.flickr.com/photos/losta
 Lisa O's gear list:Lisa O's gear list
Fujifilm X-T1 Leica Q Panasonic FZ1000 Sony RX1R II Olympus E-M1 +29 more
allineedislight Regular Member • Posts: 359
Re: Watch this video -- Effects focal length has on the face
it is not the focal length that cause the distortion, but rather it is the distance of the camera from the subject that is crucial.
if you get to close then the face is distorted (long nose etc).
so don't get to close to your subject, then everything is fine.. and if you don't like the surroundings - crop!
 allineedislight's gear list:allineedislight's gear list
Fujifilm X100F
slimandy Forum Pro • Posts: 17,071
For head & shoulders I would say 'yes' 35mm is too short. It won't give you a nice perspective. You'll get distorted features simply because you'll be too close to your subject.
You mention 85 as being ideal. I would put that at minimum. 105 or even 135 are the classic portrait focal length for head & shoulders. 85 is good for upper body. 35 for full body or environmental portrait.
It comes down to personal preference though, so try it and see for yourself.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Fujifilm X-T1 Fujifilm X-E1 Nikon D700 Nikon D200
