Nx300 with external display
Started Mar 3, 2014 | Discussions
SirPent New Member • Posts: 1
Hi all
I am trying to use an external display with my nx300 and every time i plug in the hdmi cable the camera goes into playback only mode...any ideas how to get the external display working?
Samsung NX300M
Coldamus Senior Member • Posts: 2,281
Re: Nx300 with external display
SirPent wrote:
Hi all
The NX300 can only send output via hdmi in playback mode.  i.e. you can play your videos and display your photographs on an hdmi tv or monitor but you cannot use such a display in shooting mode.
The new NX30 does support hdmi output in both shooting and playback modes.
(unknown member) Contributing Member • Posts: 947
So does the NX20.
'If the enemy is in range..so are you!
JohnnyN93 New Member • Posts: 2
SirPent ha scritto:
Ciao a tutti
Sto cercando di utilizzare un display esterno con il mio nx300 e ogni volta che collego il cavo hdmi la fotocamera entra in modalità di sola riproduzione ... qualche idea su come far funzionare il display esterno?
Hi, did you find a solution, alternative?
