Cord for Flash Synch
Started Mar 2, 2014 | Discussions
GTD5200 New Member • Posts: 19
Can someone please suggest me a 3rd party cheaper equivalent of Nikon SC-29 cable (to be used with D5200 and SB800).
 GTD5200's gear list:GTD5200's gear list
Nikon D5200 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Nikon 35mm F1.8G ED
Nikon D5200
Crashton
Crashton Senior Member • Posts: 1,646
Re: Cord for Flash Synch
Here you go.....
Flash sync cable
 Crashton's gear list:Crashton's gear list
Fujifilm X-E1 Nikon 1 V3 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
John Ponting Regular Member • Posts: 218
I've not used the Vello but I had a few fails before I got one to work with D7000 and Nissin Di866.   The Nikon cable wouldn't recognise the flash was there and wanted to popup the camera flash.   A Lastolite did the same.   Eventually I sourced a Nissin cable and that works every time.   No reason at all why the others shouldn't have worked.
Nikon to Nikon should pose no problems - why not just buy the Nikon cable?
 John Ponting's gear list:John Ponting's gear list
Nikon D7000 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Sigma 70-200mm F2.8 EX DG OS HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 1.4x EX DG Tele Converter +7 more
Rockwallaby Regular Member • Posts: 480
Go wireless
I had and then sold a SC-29, too restrictive for creativity and is limited to just one flash unit.
I suggest you investigate getting Yongnuo's YN622N-TX controller and YN-622N triggers. Much more convenient and relatively low cost. Here is some info - http://flashhavoc.com/yongnuo-yn-622n-tx-for-nikon-now-available/
OP GTD5200 New Member • Posts: 19
Re: Go wireless
@John, looking for non-Nikon 3rd party to hopefully reduce the cost.
@Rockwallaby, thanks for the link. I will check.
