Considering the Panasonic 20mm with GF6 but concerned about lack of OIS
Started Mar 2, 2014 | Discussions
jimmyleeds New Member • Posts: 4
Hi all,
I've recently bought a Panasonic GF6 (my first step up from a point and click), I fancy getting the Panasonic 20 mm II lens for it's size and it also seems good at getting that nice bokeh look.
I'm just a little concerned as my GF6 doesn't have stabilisation built in to the body and the lens doesn't have any stabilisation either. I've looked for alternatives but it seems only the larger zoom lenses have the OIS feature. I'd hope I could use it in both day and evening and although I have a mini tripod almost all of my photos are shot with the camera in hand.
Does anyone have any experience of what using this lens will be like without any stabilisation? Would many shots (especially in the evening) be often blurry? Any advice/experience would be greatly appreciated!
Thanks,
Jimmy
p.s out of curiosity why did Panny release cameras without stabilisation in their body then also launch lovely lenses that don't have stabilisation in? I would have thought that they would have chosen either to put it in the lens or body and been consistent across their range?
s_grins
s_grins Forum Pro • Posts: 14,011
Re: Considering the Panasonic 20mm with GF6 but concerned about lack of OIS
OIS will make this lens bigger - something that you would not appreciate, I think.
Based om my experience, you may be safe with shutter speed 1/20 (or faster) which means that you can take night shots having F 1.7 - F2.0 and ISO 1250-1600.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
robonrome
robonrome Senior Member • Posts: 2,334
its a fast(ish) prime and fast primes rarely have IS because it isn't as needed as faster shutter speeds are more viable. this is nothing new. there are millions of dslr's out there with no in body IS an where very few of their primes have IS. IS may be nice to have but just isn't that important. If there is anything moving in your shots IS won't help you anyway…you need to use faster shutter speed.
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
Nippero Contributing Member • Posts: 746
Never bothers me
Out of all the things I own (see gear list below), I've never used my primes and wished that I had OIS or IBIS. Doesnt bother me.
I find myself wishing for faster apertures a lot when I'm using my stabilized zooms though...
This isnt to say a fast prime + stabilization wouldnt be great, but I've just never needed it.
 Nippero's gear list:Nippero's gear list
Panasonic Lumix DMC-GM5 Sony a7C Panasonic Leica DG Summilux 15mm F1.7 ASPH Samyang AF 35mm F2.8 FE Sigma 28-70mm F2.8 DG DN +2 more
JeanPierre Martel Veteran Member • Posts: 3,304
The Lumix 20mm was my favourite lens on my GF1 (that doesn't have IS neither). I took hundreds of shots with it. I don't remember getting a single blurred picture with it.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
Ulric Veteran Member • Posts: 4,559
Stick to the old rule of thumb and you'll be fine. On MFT that's a minimum shutter speed of 1/(2*focal length). In low light, set the mode dial on S and shutter speed to 1/40.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Think again. (OIS is not the issue here...)
jimmyleeds wrote:
Hi all,
There is one thing the 20mm is NOT so good for and that is getting nice bokeh. Pancake lenses are not known for their "creamy" bokeh. It has nothing to do with the focal length (of course you get more background blur with a longer lens). The 20mm simply produces what people would call a "busy" look. Here is an example (look at full size).
20mm at f/1.7
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Robert Deutsch Forum Pro • Posts: 10,229
If you're shooting non-moving subjects in low light, then image stabilization (in the lens or in the camera) is useful.  If you'se shooting moving subjects (people, pets), then IS becomes irrelevant: any blurring is likely caused by subject movement, not camera movement, so you have to keep up the shutter speed to minimize blurring.  In this type of situation, it doesn't help to have IS that allows you to hand-hold the camera at 1/5 sec..; subject movement--even of a minor sort, like a person not standing absolutely still--at that shutter speed you're going to get some blurring.  A fast lens allows you to have a faster shutter speed.
Bob
 Robert Deutsch's gear list:Robert Deutsch's gear list
Olympus E-M5 II
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Never worried about it nor had a problem with my v1 200mm/F1.7
You need to choose your shutter speed in accordance with subject movement and magnification -  the 20mm is equivalent in magnification to a 40mm lens in Full Frame, hence I try to stick to a minimum shutter speed of 1/40s - a bit slower shutter speed can be used if your subject is stationary and you have good hand-holding technique.
Eric
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Re: Think again. (OIS is not the issue here...)
Paul De Bra wrote:
There is one thing the 20mm is NOT so good for and that is getting nice bokeh. Pancake lenses are not known for their "creamy" bokeh. It has nothing to do with the focal length.
As far as I know, a creamy bokeh is impossible to get with a wide-angle or a normal prime. I'm willing to change my mind if you have an example to share with us that shows the contrary...
jeffharris
jeffharris Forum Pro • Posts: 11,411
Try any one of the native M4/3 Voigtländers. They can deliver beautiful bokeh.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
Anders W
Anders W Forum Pro • Posts: 22,144
Paul De Bra wrote:
jimmyleeds wrote:
Hi all,
Although the 20/1.7 is not ideal for subject isolation by means of background blur, I'd primarily chalk that up to the focal length along with the max aperture and the sensor format. Not so easy to get a lot of blur with a lens that is equivalent to a 40/3.4 on FF. While the quality (as opposed to quantity) of the blur is not ideal, it is no worse in that regard than most other lenses with similar specs. And I don't know at all what the degree of pancakiness has to do with it. The non-pancake 25/1.4 is no better (I'd rather say a tad worse) with regard to the quality of the OOF rendering. But it can of course generate more blur due to the slightly longer FL and slightly wider max aperture.
I rarely go for subject isolation by means of background blur with the 20. I'd normally use my 45/1.8 or 75/1.8 for that (both of which capable of delivering more as well as better blur). But when I use the 20 wide open and get some blur with it, it usually does OK for my standards. A couple of examples below.
20mm at f/1.7
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
Beautiful, yes. But a creamy bokeh, that should be possible only with the 42,5mm and not with the 25mm (which I own) nor with the 17,5mm. Herewith is an example of the bokeh of the Voigtländer 25mm:
Rose grandifolia "Rainbow Sorbet"
So unless you have some specific examples (that I would be glad to see), I still think that a creamy bokeh is simply impossible for any wide-angle or normal prime.
jeffharris
Yes. And if you use tricks like leaning yourself or the camera against solid objects, you can shoot with even longer shutter speeds. Sometimes I'll set my camera down and use the self timer and much longer shutter speeds.
