Quick bokeh comparison 56mm vs 60mm
Started Feb 28, 2014 | Discussions
Chris Dodkin
Chris Dodkin Veteran Member • Posts: 8,361
6
As it's raining in biblical amounts outside, you'll have to make do with a robot and some cameras!
X-T1 full size JPEGs - generated from RAW files in ACR 8.4 - same PP applied to all 3 files.
ISO 200 - AF box on the robot's chest plate - camera fixed on a tripod.
56mm @ f/1.2
56mm @ f/2.5 (Closest I could get to f/2.4)
60mm @ f/2.4
AF speeds - 56mm was faster - more of a progressive slide to focus, where as the 60 did a quick yoyo around focus sometimes.
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Fujifilm X100F Canon EOS-1D Canon EOS-1D Mark II Fujifilm X-Pro1 +38 more
Simon Elwell Contributing Member • Posts: 507
Re: Quick bokeh comparison 56mm vs 60mm
The 56 looks a little softer at 1.2 but you'd expect that and for portraits it may even create a flattering effect!  At 2.5 it's sharp
I was impressed by how sharp the 60mm is wide open.
Not a huge difference in bokeh but enough to see that the 56mm has the edge slightly.
Can't wait to get mine...
 Simon Elwell's gear list:Simon Elwell's gear list
Fujifilm X100S Fujifilm X-Pro1 Fujifilm X-Pro2 Leica Macro-Elmar-M 90mm f/4 Fujifilm XF 35mm F1.4 R +6 more
Phil Levy Contributing Member • Posts: 634
Thanks for this Chris - I finally succumbed and ordered an X-T1 today, and after much deliberating also got a 60mm to supplement my lens collection. I decided that with the £100 cash back offers at the moment along with the desire to keep things as compact and light as possible that the 56mm didn't make for a sensible buy at the moment. I hope  that I don't regret the decision later!
www.phillevy.co.uk
 Phil Levy's gear list:Phil Levy's gear list
Fujifilm X100T Fujifilm X-E1 Fujifilm X-Pro2 Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 16mm F1.4 R WR +12 more
gerard boulanger Senior Member • Posts: 2,262
60 mm is very good, even fully open n/t
No text.
 gerard boulanger's gear list:gerard boulanger's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8
Mike in Kansas
Mike in Kansas Contributing Member • Posts: 794
The bokeh at f/1.2 on the 56 is beautiful.  However, at f/2.8 they look pretty darn similar.  The 60mm clearly is good for portraits, assuming you can work around the slower AF.  Thanks for posting - the 60mm may be my next lens!
 Mike in Kansas's gear list:Mike in Kansas's gear list
Fujifilm X-E1 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
deednets Veteran Member • Posts: 8,031
I am going to get the 56 as well, but must say that at 2.5/2.4 I actually like the bokeh of the 60 much better. Not sure whether this can be explained by the difference in focal length or simply because the 56 stopped down a bit. Since I take portraits in the studio and am aware that you do need at least some DOF, never really like the images were the tip of the nose was in focus and the rest was not, if you get my drift, so since bokeh starts to get nervous around 2.5 and up, maybe wait for a while to see how things pan out.
Deed
 deednets's gear list:deednets's gear list
Fujifilm X-Pro2 Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16mm F1.4 R WR +3 more
Daniel from Bavaria Contributing Member • Posts: 861
Hi Chris,
thanks for that comparision, it is very usefull. I also have the 2.4 60 and it really is a lovely lens in terms of IQ and also bokeh. It's still my sharpest lens and I love to use it for portraits.
However, I am also waiting for a call from my dealer to get the 1.2 56. I have to admit that they are very close at 2.4, but I'll buy the 56mm lens for f1.2
Daniel
 Daniel from Bavaria's gear list:Daniel from Bavaria's gear list
Leica M Typ 240 Leica Summilux-M 50mm f/1.4 ASPH Leica Super-Elmar-M 21mm f/3.4 ASPH Carl Zeiss Distagon T* 1,4/35 ZM +1 more
pkincy
pkincy Contributing Member • Posts: 808
Certainly having a very fast lens (f1.2) is very neat.  But I have had the 60 mm since it came out and it is phenomenal.   So I don't believe I will be adding the 56.
X100; WCL-100
XPro1; 60mm Macro f2.4, 35mm f1.4; 14 mm f2.8; 23 mm f1.4
XE1; 18-55 Zoom, Samyang 8 mm
New X-T1
X100; WCL-100
New X-T1
I also have the 60mm since it is out, and yes and I admit it is a tough run to spend that amount of money "just" for the 1.2. The 60mm is small ans has great IQ. The AF is soso, also on the X-T1, but improved.
It is more reasonable to to just keep the 60mm, but luckily I don't have to be reasonable with my hobby . For sure I will keep my 60mm - but will sell my 1.4 85mm Sigma for my Canon , so at least I am bit reasonable.
Daniel
BrianBrianBrian Junior Member • Posts: 40
Chris, this type of comparison is great. Is there any chance you (or others) could do more comparisons between these two lenses wide open? Particularly, it would be great to see some comparisons of people pictures - headshots, head & shoulders, and full body. It would also be great to see some shots that could only be done well at f/1.2 due to lack of light, where camera shake due at f/2.4 would ruin the photo.
My personal concern with the 56mm is that it is large & expensive and I'm not sure how often I'd actually shoot a *decent* picture at f/1.2 because the depth of field is so shallow. Chris's initial shots in this thread, combined with the price difference, convinced me to reconsider the XF60mm. In particular, XE-2 + XF60mm is back in contention now, whereas previously I was considering going the XT-1 + XF56mm route or waiting for the a8r.
Brian Caslis
Brian Caslis Senior Member • Posts: 2,930
Thanks for the comparison. I'm very interested in a portrait lens but I also want a macro. The 60 is only a 1:2, correct? Is it useful as a macro lens?
 Brian Caslis's gear list:Brian Caslis's gear list
Sony Alpha a7R III Sony FE 70-200 F4 Sony FE 85mm F1.8 Sony FE 24-105mm F4 Epson Stylus Pro 3880
Chris Dodkin
OP Chris Dodkin Veteran Member • Posts: 8,361
More close up than true macro
http://f-sunny.com
xt1isdabomb Senior Member • Posts: 1,509
56mm @ f/1.2
60mm @ f/2.4
Wow! They all look good. I suppose the  60 would be more useful as you can get closer.
http://f-sunny.com
Group4 Regular Member • Posts: 457
Thank you Chris for sharing these. I see that the image wide open with the 56 does effectively mute the background and therefore better isolates the subject. Overall (and I am guessing price point taken into consideration), the 60 comes out looking pretty good against the 56 at 2.4 as several people here have already stated; maybe besting the newer lens slightly.
For me the background is problematic given the intensity of the lighting. There is lots of electricity/movement in the bokeh. I love the results I get with my Summicron 50 at f2 and will be keeping that but also think that the lighting here would pose a similar problem for any lens in terms of taming the background.
Grp4
khollister Regular Member • Posts: 152
I also slightly prefer the bokeh of the 60 to the 56 @ f/2.5. The other interesting thing about the 60 (which I use) is that the bokeh (quality, not quantity of OOF) remains pretty constant as you stop the lens down. It really is a rather special lens optically for a very reasonable price.
Keith
 khollister's gear list:khollister's gear list
Olympus E-M1 Fujifilm X-E2 Fujifilm X-T1 Olympus E-M5 II
After the £100 cash back I paid £339 for the the 60mm which made it really hard to consider the 56.
www.phillevy.co.uk
StevenScholten Regular Member • Posts: 292
Thanks fortaking the time Chris. The 56mm is the clear winner, but at f2.5 the 60mm is better imho. I hope a friend will bring me one from NY. It's a bargain at 399.
You discribed the difference in focussing on tha xt1. What about om the xpro1? I'll be using it for portraits.
 StevenScholten's gear list:StevenScholten's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 70-200mm f/2.8L IS II USM Fujifilm XF 35mm F1.4 R Canon EF 24-70mm f/2.8L II USM +6 more
psxdadz Regular Member • Posts: 245
My wife brought me one back from New York on a recent trip  worked out at £270 also had to get the 27 at $200. The 60 is my go to lens.
 psxdadz's gear list:psxdadz's gear list
Fujifilm X-M1 Nikon AF-S Nikkor 50mm f/1.8G Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Sigma 50mm F1.4 DG HSM | A +1 more
marco1974 Senior Member • Posts: 1,770
But then again...
http://f-sunny.com
A "true" 1:1 macro lens on a "Full Frame" camera lets you fill the frame with a 36x24mm subject.
The Fuji 60mm at 1:2 lets you fill the (APS-C) frame with a 48x32mm subject.
So for all practical intents and purposes, the difference in framing between the two alternatives above is 48/36 = 1.33, or 33%.
Marco
 marco1974's gear list:marco1974's gear list
Fujifilm X20 Fujifilm X-Pro2 Voigtlander 50mm F1.1 Nokton Fujifilm XF 23mm F1.4 R XF 90mm
So, to sum up... (IMHO)
Keith
Totally agreed, based on my experience also.
The 60 is really a great lens, period. And the AF is also really now OK with the latest firmware.
The super-shallow DOF you can obtain at f/1.2 is nice to have as an option, and it certainly has its uses. But in many cases f/2.4 is plenty shallow already, and any more becomes a bit of a cliché 'show trick' that can get repetitive pretty quickly, IMHO.
So that, for me, leaves the ability to keep shooting hand-held in very low light.
But, for really low light situations where camera shake is an issue, I think the 35/1.4 may be an even better option overall, since it is only 1/2 a stop 'slower' (f/1.4 vs. 1.2), but it lets you get away with a full stop slower shutter speed (e.g. 1/60s vs. 1/125s) because of the shorter FL...
Again, thank you Chris for taking the time to contribute this very nice comparison!
Marco
