Beautiful LR profile for D800 (included)
Started Feb 27, 2014 | Discussions
OP Chron Forum Member • Posts: 80
BETA 2 (included)
8
Thanks everybody.
I've been changing the profile following your comments and some comments from other forums.
This is beta 2 which the following changes:
  • Vastly improved color separation
  • Improved blues and reds
  • Improved foliage colors
  • Slightly less contrasty tone curve in the shadows
Remember this is not intended to be a neutral / flat profile.
D800 Profile
D800E Profile
Robin Casady Forum Pro • Posts: 12,898
Re: Thanks for the effort
rubank wrote:
If one likes contrasty and punchy images "out of the box" I´d rather recommend Nikons D2x v.4 profiles.
Where did you find a D2x profile for the D800 and D800E? I thought they didn't go past the D700.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
fuzznut Regular Member • Posts: 102
You can "steal" another camera's profile by using dcptool to modify the .dcp to point to your particular camera.
 fuzznut's gear list:fuzznut's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon 85mm F1.8G Nikon 200-500mm F5.6E ED VR Nikon D7000 +2 more
I've borrowed a couple, lol
RudivanS Veteran Member • Posts: 4,480
Re: BETA 2 (included)
Chron wrote:
Thanks everybody.
D800 Profile
D800E Profile
Thanks for the effort.
Somehow the D800E profile is clipping the shadows/blacks a little too much for my liking.
Yes, I know it's not a flat profile.
Are the reds, greens and blues ment to be color accurate (and hue and luminance for that matter), or is it the amount of saturation that is the goal?
Thanks again
Rudi - freelancer
'15 years in bladerunner Tokyo - back in sunny Sydney now'
 RudivanS's gear list:RudivanS's gear list
Nikon D4 Nikon D810 Nikon D5 Olympus PEN-F Canon Pixma Pro-10
ZionImage Regular Member • Posts: 330
Does it work on Camera Raw too? Or just LR only?
Just trying to improve my draft one image at a time
You could check our more of my photos at http://www.joshuaphotographystudio.com
 ZionImage's gear list:ZionImage's gear list
Nikon D810
plaiditude Junior Member • Posts: 45
any chance you could make a profile for a d600?
www.anthonymarkphotography.net
 plaiditude's gear list:plaiditude's gear list
Nikon D7000 Nikon D600 Nikon D500 Nikon D7500 Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +12 more
Pandaemas Contributing Member • Posts: 554
Re: Beautiful LR profile for D800 (included)
Anyone care to post a result to it? And does it work for LR4? Thanks!
www.memorialucis.blogspot.com
Mitrajoon Senior Member • Posts: 1,996
I like it! (D800e)
Now a problem
I loaded the profile and it worked well.  Shut down CS6 to take a break.  When I came back the profile had disappeared.  It's still in the Camera Profile folder on my C Drive, but doesn't show up when I select Camera Profile in Camera RAW.
Any suggestions?
Doh!
My bad.  Just realized that the images I was trying to work with were taken with a borrowed D7100.  Profile works fine as advertised.
cm71td Regular Member • Posts: 464
I Like It!
I have many profiles now, and this is one of my favorites.
Thanks!
afterburn Senior Member • Posts: 1,079
Very similar...
The Beta 2 is extremely similar to the Huelight Standard V25 profile I use. It appears to be just a little darker. That is not a bad thing though, I love my Huelight profiles and use them as default when I start processing.
Gijs from The Netherlands
Nikon D800
 afterburn's gear list:afterburn's gear list
Nikon D800 Fujifilm X-T1 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 50mm f/1.8G Fujifilm XF 35mm F1.4 R +5 more
I'm loving this profile. In many cases I even prefer it to the one my passport color checker generates.
Can you provide more information as to how you generated it? I'd like to try and create one for my D3s.
Thanks for the info.  This is awesome.  Just tried dcptool and it works great.  This opens up lot's of possibilities.
SpartanWarrior
SpartanWarrior Senior Member • Posts: 2,974
Chron wrote:
Thanks everybody.
D800 Profile
D800E Profile
It's great thanks for this, any updates coming up?
 SpartanWarrior's gear list:SpartanWarrior's gear list
Nikon D3S Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-120mm F4G ED VR +3 more
robolepa New Member • Posts: 15
Thank you!
gregee Junior Member • Posts: 36
I have been using DXO Pro and just started to use LR. I am looking to try our the D800E camera profile. I followed the instruction of pasting the file in the camera profile folder. Can someone be kind enough to let me know how to utilize the file? I have tried numerous searches for instruction however I still can not find it?
thanks,
greg
Anyone?
Mac or PC?
thanks,
greg
Mac: Finder: Go menu: Go to Folder...
~/Library/Application Support/Adobe/CameraRaw/CameraProfiles/
Robin Casady
—Mark Twain
