d7000 as my first DSLR?
Started Feb 26, 2014 | Discussions
futureishere New Member • Posts: 1
Hi,
I am planning to get my first DSLR and I have the budget of around 1000 USD. After looking around a bit, I was thinking about following configuration:
- Nikon D7000
-Nikon 35 mm f/1.8G AF-S DX
-Nikon 55-200mm AF-S DX VR
Depending on the prices in May (that's when I will be in US), I may buy one or more of the items above as refurbished to keep it within my budget.
I don't think I am going to shoot a lot of video. Mostly landscapes and portraits. Do you guys think this is a reasonable configuration? Thanks!
Nikon D7000
Footski
MOD Footski Senior Member • Posts: 2,116
Re: d7000 as my first DSLR?
That sounds good to me. You might want to add the 18-105 kit lens to that. It is reasonably priced and is a very good lens. You will then have most situations covered. I love my D7000.
 Footski's gear list:Footski's gear list
Leica V-Lux 4 Nikon D7000 Fujifilm MX-700 Fujifilm FinePix F601 Zoom Samsung NV10 +15 more
Klaus dk
Klaus dk Veteran Member • Posts: 4,910
With that configuration, I would miss the short end, even 35 mm is quite narrow for APS-C. If the Nikon 16-85 is anything near the Canon 15-85, I would recommend that for the first lens, but it depends on your needs, not mine.
Buying second hand/refurbished gear is a great way to save IMHO.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm F2.0 Canon EF 50mm f/1.8 II +12 more
TTMartin
TTMartin Veteran Member • Posts: 7,304
KEH is a good source for used gear in the US. As are larger camera stores like Adorama, B&H and MPEX.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
TH - NikonStrobist
TH - NikonStrobist Regular Member • Posts: 391
Seems like a solid plan.
“There are no bad pictures; that's just how your face looks sometimes.”
~ Abraham Lincoln
 TH - NikonStrobist's gear list:TH - NikonStrobist's gear list
Nikon D610
WryCuda Senior Member • Posts: 7,663
futureishere wrote:
Hi,
  • Nikon D7000
  • Nikon 35 mm f/1.8G AF-S DX
  • Nikon 55-200mm AF-S DX VR
You might find the an 18-105mm or 18-140mm preferable to the 55-200mm; new users often go "too long" with their first lenses. You could use one of those zooms at around 70mm for portraits, with reasonable success.
The 35mm f/1.8 is a good general lens, but for landscapes, you might also consider something wider; the Sigma 10-20mm for example:
Waikiki Beach. Sigma 10-20mm
Central crop of first image.
 WryCuda's gear list:WryCuda's gear list
Nikon D7100 Sony a6000 Sony Alpha a7
