SEF-580A
Started Feb 25, 2014 | Questions
Bryan M
Bryan M Contributing Member • Posts: 956
SEF-580A
Does anyone happen to know if this upcoming flash will be triggered optically or by other means such as radio? I just found out my trusty Yongnuo triggers that I have used forever do not work properly with the NX30. They work fine with the NX210 and NX300.
Bryan
www.bcmcue.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
Samsung NX210 Samsung NX30 Samsung NX300M
ttbek Veteran Member • Posts: 4,869
Re: SEF-580A
I think at least by radio, since the number of channels and groups is given in the specs. I'm not sure if it will by flash or not, but you can always buy some cheap optical triggers to help out with that.
Weird that the Yongnuos don't work with the NX30 for you, maybe give that another go for us to double check.  Are the pins not quite lining up now or something?
Has anyone posted this video on here before?
https://www.youtube.com/watch?v=ZM1_bzyKY6s
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Mr.NoFlash Senior Member • Posts: 2,374
Re: SEF-580A
It is my understanding that the 580 flash can be triggered by the Nx30-built-in-flash, via a kind of "flash morse code".
But i do not have one of these.
I assume you have to dig into the operating manuals.
cheers
Mr.NoFlash
 Mr.NoFlash's gear list:Mr.NoFlash's gear list
Fujifilm FinePix Real 3D W1 Leica Digilux 3 Samsung NX300 Fujifilm X-M1
Bryan M
OP Bryan M Contributing Member • Posts: 956
Re: SEF-580A
I tried a lot of different things to get them to work and while they do fire they don't contribute to the exposure. The triggers require the same adjustment on the NX30 as they did on my NX210/NX300.
Bryan
www.bcmcue.com
viking79
viking79 Forum Pro • Posts: 14,157
Try disabling electronic first shutter.... (more)
Try disabling the electronic first curtain shutter, it might be too short for shutter lag or might not trigger the same way.  Also try different trigger modes (leading vs trailing curtain etc under flash menu).
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Bryan M
Re: Try disabling electronic first shutter.... (more)
Eric
Great suggestion, I gave it a try but no success. The timing is way off. I appreciated the suggestion Eric.
Bryan
www.bcmcue.com
