canon fd 500mm on eos
Started Feb 24, 2014 | Questions
mjkshots
mjkshots Regular Member • Posts: 140
so I just ordered a beat up fd 500mm 4.5 lens it was at a ridiculously low price, I plan to shoot with this lens on my 1d bodies. I use a fd-eos adapter that works great with other fd lenses on my 1d and 1dII, I will use this adapter at first to shoot with the 500mm. but I plan to build an adapter like the edmika or buy one if I can. I just cant seem to find any .75mm around
I want an adapter that gives me the true IQ of the lens, without adding the 1.25x and non L glass.
so has anyone used the eos mount off a broken lens, added a bit of meat to it to create a fd-eos adapter? on my next day off If I can't find the adapter I am looking for I will try some experiments, see what happens and get back to everyone on what I come up with.
thanks a bunch!
-mike
mjkshots.com
 mjkshots's gear list:mjkshots's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon Pixma Pro-100
Canon EF 500mm f/4.0L IS II USM Canon EOS-1D
msowsun
msowsun Contributing Member • Posts: 740
Re: canon fd 500mm on eos
Here is an expensive .35mm adapter: CIRRUSADAPTER 0.35MM Canon FD to EF Adapter,
This one is less than $20 and is actually much thinner than the usual FD to EF adapters you see on ebay.
Macro Canon FD Lens to Canon EOS EF Mount Adapter
It is only about 2-3mm thick while most ebay adapters about about 10mm. Because it has no glass it acts like a very short Macro extension tube. It won't focus very far with my 50mm lens, but it might let you focus far enough with your 500mm lens. I would guess maybe 15 feet?
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
M Stewart Contributing Member • Posts: 985
Get yourself an Eos M, and an FD to Eos M adapter (a few dollars from ebay).  This will allow you to check out the full performance of your 500mm lens.  The Eos M has x5 and x10 views to aid focusing manually.  If the Eos M isn't possible for you, other mirror-less CSCs are, and adapters may be available.
I'm using mine to check out my collection of FD lenses.
M. Stewart
Milton Keynes, UK
 M Stewart's gear list:M Stewart's gear list
Canon EOS M Canon EF 15mm f/2.8 Fisheye Canon EF 20mm f/2.8 USM Canon EF 24mm f/2.8 Canon EF 35mm F2.0 +15 more
mjkshots
OP mjkshots Regular Member • Posts: 140
Thanks everyone for the help on getting my fd 500mm lens up and running on my dslr bodies. I am considering all the suggested options I am researching everything and will get back to this post with the techniques I go with and how they work, I really like the idea of the eos m, I have been eying those cameras for a while now. But I really would prefer to be shooting with my older more familiar bodies. I will get back and add my new ideas and info soon.
thanks again,
-mike
mjkshots.com
