Re: I broke my 22mm lens!
6
Mahmoud, there is no depression on the lens. It was really an innocuous fall onto carpet but just enough to knock loose that internal piece in the lens.
I didn't even consider the possibility that I could take part and repair such this lens. But with nothing to do on a Sunday morning and nothing to lose, that's what I did. I took pictures along the way to document the process and to help me remember how to reassemble the lens if I magically could fix it. Here's a couple of initial shots of the disassembly.
4 ribbons cable needed to be removed from the circuit board. 2 of the ribbons have a spring clip release, the other two just slide out.
About 1/3 of the way through the disassembly of the 22mm lens.
Unfortunately the loose piece required the entire lens to be taken apart down to its core; some of that I had to do with brute force. Being realistic, there was practically zero chance that I could reassemble everything in reverse order. Here's the loose lens piece and another random loose part that I have no idea where it came from.
Offending loose lens piece and another mystery loose part.
Here's how that piece attaches to the underside of the lens assembly. I can see why it fell loose because it's just held on by a bit of friction, a strip of tape around the perimeter of the piece and two way too small dabs of glue.
Here's where the loose lens piece goes.
At this point, I start to reassemble knowing that the lens would never work again because of an accident with superglue and way too many tiny parts that I took apart. After awhile, I chucked everything in the garbage can and decided that I'll just have to spend another $100 for a replacement 22mm lens.
