Flash on T4i clicks but doesn't pop up
Started Feb 19, 2014 | Discussions
Crotonmark Contributing Member • Posts: 933
This is new
The latch is trying to open but it doesn't
After three clicks I get an error message on the screen and need to turn the camera off
I have tried compressed air but that is a temporary fix
Any suggestions?
Mark
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
WilbaW
WilbaW Forum Pro • Posts: 11,643
Re: Flash on T4i clicks but doesn't pop up
The usual answer to flash-won't-pop-up questions is flick the springs in the hot shoe to free the switch that tells the camera there is a flash attached, but this doesn't sound like that (try flicking the springs anyway).
This  sounds more like the the flash is trying to release but can't. Are you able to apply some gentle lift to the flash as you press the button?
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
OP Crotonmark Contributing Member • Posts: 933
yes I can lift it if I apply subtle lift to the flash
How do you flick the springs?
WilbaW
Crotonmark wrote:
This sounds more like the flash is trying to release but can't. Are you able to apply some gentle lift to the flash as you press the button?
And it goes all the way up and it works fine? If so the flash release isn't working properly, which would be a warranty/repair job.
Thumbnail, toothpick, paperclip... see http://www.justanswer.com/video-camera-repair/4epfw-canon-eos-7d-will-not-allow-pop-flash-set.html for example.
Re: Flash on T4i clicks but doesn't pop up - SOLVED I THINK
91% alcohol on a Q-Tip
seems to have solved the problem
Let's see what happens over time
WilbaW
Funny... I've never heard of the clicking and error messages you experienced, but if it seems fixed we'll call that an easy win.
It works and then it doesn't
Should I get an external flash???
Recommendations?
Rgali323 New Member • Posts: 1
The clicking just started on mine as well camera wasnt dropped or anything...... How can i repair it?
Lemming51
Lemming51 Forum Pro • Posts: 15,278
re-read this thread. http://www.dpreview.com/forums/post/53155072
There may be some stickiness on the top of the camera (dried sweat, spiilled soft-drink, etc.) that keeps the flash from popping up.   Press the flash button and help it up when it clicks, then clean the edges of the flash and the area beneath it.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
AronQZ Forum Member • Posts: 75
On a 70D the usual fixes found on net did not work (cleaning, wd40, hot shoe contacts etc). Mine had the 3 clicks and then error but could be opened manually with a little assisted push. All else looked ok too (arms / screws / release hook).
The solution was to unscrew the 2 screws on the underside of the top section (next to bulb) which releases the cover (on 70D needed to also release/assist pressure clips on either side under lid. Once pop up flash cover is off there is a pressure screw on one side with the lever spring attached. A minor anti-clockwise turn to reduce the pressure on the screw  was enough to resolve the problem.
One could go further if still not working properly and lessen the screw pressure even more. The screw will eventually come right out with the spring and could be cleaned and lubricated before putting back on to get a really sticky one working again (perhaps screw is rusted or too much dirt buildup).
dzba Senior Member • Posts: 1,680
Yes, this is a 4 yr old thread, but I dealt with this problem this past week.
the on board flash on my Canon t4i (as described previously by other posters) would make the 3 clicking sounds, and not pop up.
I seldom use the flash, so I blew that off as an inconvenience.   Prior to visiting the zoo this week I got the flash to pop like it should
My solution was to get the flash popped up and then turn off the camera main switch so as to not flash me.  Then I used an ear cleaning swab, (Q tip type) and nothing else to wipe both the pop up part's outer perimeter and the inner part that it fits into.  Also used the plain q tip to clean where the recessed slot for the catch for the flash what I could reach.  Seems to have helped this problem quite a bit.  Now that I have regular access to the flash, I may try to use it more frequently.
Mike
please do not edit or repost any of my images without my permission
 dzba's gear list:dzba's gear list
Panasonic Lumix DMC-FZ30 Canon EOS Rebel T4i Nikon D7500 Canon EF-S 18-55mm f/3.5-5.6 II Canon EF-S 55-250mm f/4-5.6 IS STM +2 more
