New starter
Started Feb 17, 2014 | Discussions
jambon84 New Member • Posts: 1
New starter
Hi everyone.
I have been looking at buying a camera for the first time I want a nikon I think and I want one I can change the lense on I also don't want a bridge camera I want a digital slr. I don't have a big budget and would buy second hand I can't spend any more than £250 I know this is quite low that's why I am thinking second hand is best. But I want some advice on a good starter model to get to grips with.
Thanks in advance.
thebustos Veteran Member • Posts: 3,315
Re: New starter
Why do you want a Nikon? Have tried out several?
Good luck and happy shooting!
 thebustos's gear list:thebustos's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 50mm F1.8 SAM Sony DT 30mm F2.8 Macro SAM Sony DT 16-50mm F2.8 SSM +17 more
Limburger
Limburger Veteran Member • Posts: 7,837
Re: New starter
A used D5000 with 18-105 should be doable.
I am not saying this you should get, I am saying this you should concern.
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony Alpha a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
SMPhoto
SMPhoto Senior Member • Posts: 1,024
Re: New starter
jambon84 wrote:
Hi everyone.
Thanks in advance.
With those parameters, honestly I'd probably look for a used D90 in good shape. Yes the sensor is not up to the latest models, but it's more than adequate for anything you'll need, and the camera is better built and has a better viewfinder than the D3xxx, 5xxxx series, and unlike those you can pick up older, cheaper, non-AFS lenses that will work with it since it has a focus motor like the current higher end Nikons.
 SMPhoto's gear list:SMPhoto's gear list
Nikon 1 AW1 Nikon D810
