Damage on E-PM2 lens mount
Started Feb 14, 2014 | Discussions
highwave Senior Member • Posts: 1,298
Hi,
A friend of mine bought an E-PM2 about 10 months ago and now he's seeing this damage on the lens mount I'm showing in pictures bellow. Anyone had this? I can't really tell if it's mechanical or rust? anyone had a similar problem? recommend repairing under warranty? or just forget about it?
Damage on lens mount
1:1 blow out of damage
 highwave's gear list:highwave's gear list
Olympus PEN E-PL1 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
Olympus PEN E-PM2
berni29 Veteran Member • Posts: 3,119
Re: Damage on E-PM2 lens mount
Hi
That looks like corrosion to me. Has it been used in a salty environment and not been wiped down afterwards? Personally I would send the photo to the service department and see if it is covered?
Berni29
EM-5, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm, 14-45mm Oly 45mm, 50mm F2 macro, (prev GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Ricoh GR II Olympus E-M1 Sony a7R II Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +13 more
baxters Veteran Member • Posts: 5,319
Looks like sand was stuck on the back of a lens when he mounted it.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
s_grins
s_grins Forum Pro • Posts: 14,011
If you can mount a lens, and everything will work, you can use the camera. No worries.
If you can't mount the lens, or lens does not work after you mount her, it is bad.
Do not pay attention to minor wear (it could be bad adapter)
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
OP highwave Senior Member • Posts: 1,298
berni29 wrote:
Hi
No, no salty environment that I'm aware of. However perhaps the salt put down on snow got in? Unlikely I would personally say.
That's a good point. I didn't think about it before but I could imagine trapped sand particles doing damage. My friend is an avid hiker who hikes practically daily and snaps hundreds of pictures. Not unlikely that some dirt particles made their way in there.
The mount and the camera work flawlessly. I would say it's minor but I just wanted to check if it was common or major or anything.
Thanks everyone
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
Looks to me more like it was dinged - poor lens mount handling, a screw or two loose on a lens or adapter, or dropped?
Whatever -  as was said, as long as the lens mounts and everything works I wouldn't be concerned.  Well - I'd want to take a look at whatever he's been mounting to that camera, for peace of mind.   Otherwise it falls under 'stuff happens'.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
Thanks Bob
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
highwave wrote:
Hi,
To me it looks exactly like the corrosion seen on my spare (old) set of alloy wheels for my car.
I think it significant that it is on the top part, it looks maybe as if salty water or at the very least rain water snuck in there at some stage and stayed there to "rot" the alloy.
Certainly would lower any resale value, would be worth trying to see if a warranty fix is available but I suspect they would say it was a user problem and charge to replace the mount.
Also check the back of the lens(es) to see if corrosion on the mating art. If a plastic lens mount of course there would be no problem.
But if the camera was going to be used until it dies or until it is worth nothing then I guess it would not matter about leaving it as-is.
Regards...... Guy
Ulric Veteran Member • Posts: 4,559
What is the material that flange is made of? It sure looks like corroded aluminium, but I thought the flange was chrome plated brass.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Guy Parsons
Anodised aluminium is way cheaper and lighter than plated brass, also consider that probably the chemical processes involved with anodising are also more planet friendly than that nasty chrome plating process.
Regards...... Guy
Regards...... Guy
Thanks Guy. Your explanation is very plausible. It's just that I have an E-M5 and I've had it for much longer a period than he had his E-M2. My E-M5 has no mount issue whatsoever. I think the mounts are made from the same material and process and I tend to get my camera wet all the time with lenses that are not weather sealed (20mm & 14-150mm) because I'm obsessed with taking pictures in damp rainy or snowy conditions. No damage to my mount so far, or any damage whatsoever for that matter, my E-M5 is practically as good as new.
Guy Parsons
Regards...... Guy
It's the care afterwards that matters, don't just plonk a wet camera back in the bag and forget it. Take it apart (that is, lens off) and wipe everything dry, then back together and leave in front of a warm flow of air (both camera and bag) for an hour or so.
When my E-PL5 got extremely wet I did that wipe off and then some time in front of a warm (not hot) air-con vent and all fine.
Regards...... Guy
Regards...... Guy
That makes sense. I usually just leave my E-M5 out on the open (nice to stare at when you're not using it) so water never condenses on it. My friend on the other hand, I do recall off the top of my head that he had moisture condensation on one of his Canon lenses so it is probably that he lets condensation take its toll where I wouldn't.
I'll be sure he gets a hold of this thread for future camera handling.
Thanks again
nkbj
nkbj Regular Member • Posts: 263
I had the same problem on my first E-PL1. Got the lens mount changed under warranty by Olympus Europe.
Niels Kristian Bech Jensen
Thanks Niels
TomFid Veteran Member • Posts: 4,000
I just bought a used E-PM2 that has what looks like the same issue (it's going back, I think).
I notice that the IIR kit lens has kind of a double flange on the mount, which creates an airspace against the camera mount plate. Perhaps sweat or humidity gets in there, and then just sits and works away at the metal plating. If you didn't change lenses, you'd never even know it.
veroman Veteran Member • Posts: 4,904
Really hard to tell from the photos, but are the "damaged" areas on the surface or are they chips of metal (or coating) that came off of the surface, leaving pits in the surface?
SteveG
'When love and skill work together, expect a masterpiece.'
— Found in a Chinese Fortune Cookie
www.stephenmichaelgarey.com
 veroman's gear list:veroman's gear list
Leica X Vario Ricoh GR II Panasonic Lumix DMC-GF1 Pentax K-01 Pentax K-5 II +2 more
