E-PM2 + Olympus 12-40 f/2.8 Pro
Started Feb 12, 2014 | Questions
Kenster New Member • Posts: 24
I'm looking to purchase a Olympus 12-40 f/2.8 Pro.  I have a E-PM2 body.  From what I read, E-PM2, OMD EM-5 and OMD EM-10 all have essentially the same sensor.  Would E-PM2 + Olympus 12-40 have comparable image quality as OMD EM-5 or EM-10 + Olympus 12-40?  Or should I invest in a new camera body to complement the Olympus 12-40?
Olympus PEN E-PM2
taz98spin Contributing Member • Posts: 533
Re: E-PM2 + Olympus 12-40 f/2.8 Pro
As a fellow E-PM2 user, have you used larger lenses on your camera before?
If you're comfortable with a larger body on your E-PM2 without blurred images, I would say keep your body.
EM-5, EM-10 both have better stabilization than our cameras.
 taz98spin's gear list:taz98spin's gear list
Fujifilm X-Pro1 Olympus PEN E-P5 Fujifilm X-T1 Sony a7S Fujifilm X-Pro2 +12 more
Willing Contributing Member • Posts: 772
I guess the lens weighs more than the e-pm2, it means it will be front heavy using with e-pm2. The quality will be same but the larger body plus 3or 5 axis IBIS is much more efficient than the old 2-axis.
 Willing's gear list:Willing's gear list
Panasonic G85 Nikon Z5 Rokinon 7.5mm F3.5 UMC Fisheye CS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +4 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
That lens is worth owning even if you have no camera
Basically it gets down to how you hold a camera, with a lens like that the left hand holds the lens and body and the right hand does the usual thing.
Any of the 16MP sensors are just great (and all have much the same image quality) compared to the old 12MP sensor.
I find the 12-40mm is fine on my not much bigger E-PL5. Makes a nice combination and the extra bulk and better hand holding makes for less shake problems.
I think maybe the custom made wrist strap is about 80% of the answer though.
Regards...... Guy
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
Regards...... Guy
I need to make one of those wrist straps for the E-PM2 - the shoulder strap is really overkill. I need that lens too...
ps: There must be some good quick release shoulder straps out there - any tips on some that won't scratch the body?
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
grey0135 Regular Member • Posts: 229
NO.  I briefly owned the EPM-2.  I found the IBIS on the E-PM2 so useless I ended up turning it off.  I suppose it's better than nothing, but not very effective and prone to shutter shock.  And the results are even worse for video (all you have is some sort of electronic stabilization).
Unless you really need the extra 5mm or closer focusing distance, you're better off with the 12-35mm.  It's a smaller, lighter lens, and it will give you much better stabilization.  Just be ready to tick the CA box in lightroom.
RV Abbott
