Canon f/2.8 300 IS USM II - CPL vs. No CPL w/1DX
Started Feb 12, 2014 | Discussions
tvstaff
tvstaff Veteran Member • Posts: 3,264
I'm using a Canon f/2.8 300 IS USM II with a 1DX to shoot water sports and optimizing shots by reducing glare on backlit subjects, over bright water, with bright blue sky, "could be ideal".
Has anyone out there had experience with the Canon 52mm drop in CPL on the 300?
I'd like to see some shots or get your opinion on the exp.
And... has anyone noticed enhanced issues with shadows, banding or noise in PP with PS or LR with the CPL.
Thank you,
TV
http://mediamaze.tumblr.com/
http://www.pixoto.com/filcro.mediastaffing
 tvstaff's gear list:tvstaff's gear list
Canon EOS-1D X Canon EOS-1D X Mark II Canon EOS-1D X Mark III Fujifilm GFX 100S Canon EF 35mm F1.4L USM +28 more
Canon EF 300mm f/2.8L IS II USM Canon EOS-1D Canon EOS-1D X
tvstaff
OP tvstaff Veteran Member • Posts: 3,264
Canon f/2.8 300 mm - CPL vs. No CPL ???????
Thank you,
TV
Has anyone shot water sports using the canon 52mm drop in CPL with a 300 or 400mm lens?
Can you tell me your feelings?
Can you post a few shots?
I thinking of using on to shoot kitesurfing.
Thank you,
TV
Feel Always Humble - "FAH" - You'll Learn More
joger
joger Veteran Member • Posts: 7,513
Re: Canon f/2.8 300 mm - CPL vs. No CPL ???????
Thank you,
TV
Thank you,
TV
Hi TV
I own the 300 f/2.8 L IS USM II but I don't own the 52 mm CPL - the only thing that come to my mind is that it consumes roughly 2 stops of light - sometimes that can be critical.
Other that that i really love the lens and the sharpness - a polarizing filter will probably lower the possible quality a bit - but not by much - since the 52 CPL is compare to the lens really cheap just buy it - what wait?  Your 1Dx plus the 300 f/2.8 L IS USM II cost roughly 60x the polarizing filter
And the 2nd use of the filter could be as an ND filter als well - that's the reason why I am intending to buy one in the next couple of months.
__________________________________
isn’t it funny, a ship that leaks from the top
ISO 9000 definition of quality: 'Degree to which a set of inherent characteristic fulfills requirements'
I am the classic “Windows by Day, Mac by Night user'
“The horizon of many people is a circle with zero radius which they call their point of view.” Albert Einstein
if you start to fight with a pig you'll end up mud-wrestling - the only difference is the pig will like it
 joger's gear list:joger's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony FE 50mm F1.2 GM Sony FE 14mm F1.8 GM +12 more
expro Senior Member • Posts: 2,274
not much help but I have not used cpl with my 300 as it tends to oversaturate and can cause banding in flat skies... this was a while ago though and I have not revisited.
I see you shoot your water stuff in strong light so would think this is even more likely to happen for you.....
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Schwany
Schwany Forum Pro • Posts: 10,169
I had one in a 600f/4 I and did not like it. The loss of light was significant for what I was doing, and it really messed with the background highlights on water. Made them look like hundreds of little fuzzy snowflakes. It also did not seem to focus properly at longer distances. With that said I am of the opinion the one I had was not functioning properly (or I was not functioning properly), because I could not take a shot I liked with it in the lens.
The CPL that you can spin with the external thumb wheel is a very cool looking piece though. You may have better luck with one on the 300f/2.8 II.
Additional useless information: I inadvertently sold the CPL drop in filter in a 500f/4. I forgot it was in there. Oddly, the guy that bought my 500f/4 called me about 8 months after buying the lens to ask if I would trade him for a standard gel filter that comes in all the lenses that have the 52mm drop in filter arrangement. I never got back to him.
Tossed most of them. This one shows the fuzzy snow flake effect on the background highlights. Maybe that is cool. I just don't care for it.
Thank you,
TV
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
tvstaff
Thank you,
TV
BINGO! Got my answer and a bird with snowflakes to prove it! <ROFL>
THANKS Schwany!  This place would be so lacking without your references, acumen and honesty!!!
Best regards,
Tony
