Problem with Firefox 26.0 !
Started Feb 11, 2014 | Discussions
JP Scherrer
JP Scherrer Forum Pro • Posts: 10,633
Hi !
I updated Firefox in both my DESKTOP and LAPTOP, which both run under Windows 7 / 64 bits.
Here's my LAPTOP screen-copy (without the RED rectangle, of course):
...and here's my DESKTOP screen-copy:
See ?? On the DESKTOP, the black rectangle containing several apps doesn't show !
I searched for the differences in TOOLS > OPTIONS, but didn't find any !
I guess it must be some keys combinaison that hide/show that window, but I don't know wich one... Can someone help me out ???
Many thanks in advance !
J-P.
Photo Galeries at http://www.pbase.com/scherrer
Spherical Panoramas (360x180 degrees) at http://www.360cities.net/profile/jps
Equipment list in profile
 JP Scherrer's gear list:JP Scherrer's gear list
Nikon 1 V1 Nikon 1 J1 Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +7 more
Pictus
Pictus Veteran Member • Posts: 6,326
Re: Problem with Firefox 26.0 !
Try CTRL 0 it will change the screen size the default, CTRL+ make bigger and CTRL- smaller or CTRL mouse scroll wheel.
Zone8 Forum Pro • Posts: 17,276
From my personal viewpoint ....
JP Scherrer wrote:  Hi !  I updated Firefox in both my DESKTOP and LAPTOP, which both run under Windows 7 / 64 bits.
... all versions of Firefox have been definitely with problems since square one.
However, their Thunderbird, when configured properly for personal mail work, is superb.
Zone8: Although I am a handsome genius, when I stand in front of a mirror, I vaguely recognise the ugly idjit standing on the other side!
LINK: For B+W with Epson 1400 (and other models) using black ink only PLUS other useful tips:
http://www.photosnowdonia.co.uk/ZPS/epson1400-B&W.htm
Cleaning DSLR Sensors, including Kodak DSLR Factory Cleaning method:
http://www.photosnowdonia.co.uk/ZPS/KodakDCS-sensorcleaning.htm (Includes links to "bassotto's" images)
Solving back/front focus problems on Sigma and most other DSLRs
http://www.photosnowdonia.co.uk/ZPS/backfocus.htm
PDF format list of lenses you can print or download - covers Italian Flag YES/NO for DCS 14n but applies to others. http://www.photosnowdonia.co.uk/ZPS/ItiFlagLensList.pdf
ericN2
ericN2 Forum Pro • Posts: 17,106
A sheer guess.. but worth a look..
Check on the top-line Menu-VIEW drop-down and see if there is any difference between the two in regard to what is ticked to show..  Could be you have such as a Toolbar ticked to show on one but not the other maybe...
/eric
Staffordshire, UK
abelits
abelits Contributing Member • Posts: 773
JP Scherrer wrote:
Hi !
J-P.
Your laptop's browser reports User-Agent as Internet Explorer, so Google returns Internet Explorer version of its menu. On the desktop Firefox reports itself correctly -- this is how Google home page is supposed to look like.
 abelits's gear list:abelits's gear list
Fujifilm X-Pro1 Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
Jim Cockfield Forum Pro • Posts: 16,342
check for google toolbar addons (extensions).
You're probably looking at a toolbar that's really an extension (probably one of your add-ons if you look under Tools>Addons (check both extensions and plugins).
Or, it could be that you have your User Agent String set to report a different Internet Browser (versus the real browser you're using). I use an extension called PrefBar I use for that purpose (where I have custom User Agent strings setup so I can pick the Operating System and Browser I want to report to web sites). Get that extension here:
https://addons.mozilla.org/en-US/firefox/addon/prefbar/
See this post on the subject of setting up User Agent Strings in it:
http://www.dpreview.com/forums/post/51982117
There are many extensions that let you do the same thing. However, if you report a different User Agent String to a web site, you can expect to "break" many features that web site may have (how a browser uses the javascript a site calls for posting or editing in forums, etc.), especially if you try to do something like report you're using Internet Explorer instead of Firefox (it's best to report that you're using a browser with the same type of rendering engine if you do change your User Agent string to something else)
But, if it's an extension giving you that toolbar instead, it's my understanding that the google toolbar for Firefox is no longer compatible with newer versions of Firefox. You can find numerous posts on that subject. It's a discontinued product now, as you can see from this page about it:
https://www.google.com/intl/en/toolbar/ff/index.html
But, you may be able to find alternatives for it (other third party extensinos for Firefox). Or, you could just setup bookmarks on your Bookmarks toolbar instead.
Or, if you really want to "jump through hoops", you could use options like discontinuing the compatibility checks for newer addons, etc.
http://en.kioskea.net/faq/26496-install-google-toolbar-on-the-latest-version-of-firefox#google-toolbar-is-not-working-after-updating-firefox
You can either do that using settings under about:config, or you can get an extension for that purpose. For example, this one:
https://addons.mozilla.org/en-US/firefox/addon/checkcompatibility/
But, when you disable compatibility checks, you may have problems with some extensions (because they really are not fully compatible with newer Firefox versions in many cases). The Google Toolbar probably falls into that category (interferes with some Firefox features in newer FF versions).
If you're sure you upgraded both computers to Firefox 26, and one still has the toolbar working and the other does not, you probably have something installed that disabled compatibility checks on the machine that still has the toolbar installed (and or you just have a User Agent String set reporting a different version of Firefox to Google).
But, I've seen posts from others that it causes problems with newer Firefox releases anyway. So, I'd suggest using using the Firefox bookmarks toolbar if you want shortcuts to specific Google apps (Gmail, Youtube, etc.). That's what I do anymore (use the Firefox bookmarks toolbar for one click access to those web sties).
Of course, you can easily just go to Google.com and click on the Apps icon on that page (the icon with 3 rows and 3 columns of square black dots) and select the App you want from the menu that comes up.
JimC
CAcreeks
CAcreeks Forum Pro • Posts: 13,083
Firefox 27 just appeared
JP, I hope others have correctly diagnosed your problem.
Firefox 27 appeared a few days ago. It is supposed to be faster and more secure. Here are the release notes:
http://www.mozilla.org/en-US/firefox/27.0/releasenotes/
