Testing some lenses 14mm - 50mm
Started Feb 11, 2014 | Discussions
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
It was an ugly day outside, so I spent some time testing the lenses I have on hand in the 14-50mm range.
  • OM 35/2.8 (old SC version)
  • OM 50/1.8 (new MC/MIJ version0
  • ZD 35/3.5 macro
  • ZD 14-42
  • ZD 40-150
  • MZD 12-50
  • MZD 14-42
  • MZD 40-150
  • Bower 7.5/3.5 fisheye (for fun)
The first thing that became apparent is that my big thumbs are still not used to the small buttons on the E-M5 - many mistakes using the way controller on the back, and the info button is nearly impossible to get first time. I'd love to get my hands on an E-M1 and E-M10 to compare.
Still checking over the results, but a few surprises...
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
zuikowesty
OP zuikowesty Veteran Member • Posts: 4,158
35-40mm FL compared
  • ZD 35/3.5 macro
  • ZD 14-42
  • ZD 40-150
  • MZD 12-50
  • MZD 14-42
  • MZD 40-150
First I have compared the OM 35, ZD 35, ZD 14-42 & MZD 14-42, MZD 12-50 at 35mm, and the two 40-150s at 40mm on the same bookshelf.
The OM 35 is soft and glows nicely at f/2.8 as expected, but sharpens up nicely by f/5.6, and has the 2nd highest centre sharpness of the lot at f/5.6, with the corners still very respectable. Not bad for a lens bought new in 1976 that has been through a lot, including a sand filled focus helicoid, and sells for next to nothing on eBay.
The MZD 40-150 is slightly sharper in the centre from f/4 to f/8, but the OM 35 beats it on edge sharpness, so it is 2nd overall.
The rest (at f/5.6) fall in order: ZD 35 macro, ZD 14-42, ZD 40-150, MZD 12-50, MZD 14-42.
Hardly a scientific test, and I will try to post some 1:1 samples. I was quite surprised at the 35 macro placing 3rd, and the big difference between the new and old 40-150s at the 40mm end. Also a bit disappointing that the new 14-42 is so soft compared to the ZD version, and the twitchy zoom on the new 14-42 was annoying as well (IS was off).
Next I will compare at 14mm.
