I didn't need a new camera at all , but I got a DP1x because I wanted one
Started Feb 9, 2014 | Discussions
smarter Contributing Member • Posts: 541
Camera buying addiction is a serious disease. With my current cameras I have most bases covered. I have compact, mirrorless, DSLR and several lenses.
Despite that I kept urging to buy a Sigma DP camera just because of the famous Foveon sensor quality. I know Sigma DP's are no speed demons and they have some quirks. Tonight I finally bought my first Sigma DP on Ebay, A barely used DP1x .
I can't wait to try it. I have read different opinions about the DP1 series. Some say the DP1x is not as good as the former versions. What is the opinion over here?
 smarter's gear list:smarter's gear list
Fujifilm XQ2 Ricoh GR II Olympus E-M1 Fujifilm X-Pro2 Olympus PEN-F +11 more
Sigma DP1 Sigma DP1x
Johan Borg Senior Member • Posts: 2,570
Re: I didn't need a new camera at all , but I got a DP1x because I wanted one
With the DP1x you probably want to be more careful about overexposure than with the earlier and later DP1 models. Also, with that particular model I suggest to shoot with color mode set to Neutral since it will give more predictable metering/results. Otherwise, just go out and enjoy!
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,074
Some people thought the highlights could blow a little more easily in the DP-1x.
However, that is offset by very significant handling improvements of the DP-1x over the original DP-1. So I would say overall you are way better off getting a DP-1x as a starter camera than the DP-1, which was slower and I'm not sure even had the QS menu.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
digi2ap Contributing Member • Posts: 679
I really loved having the DP1/2X cameras for a couple of years. Yes, you need to expose for the highlights and despite the AFE you probably will stick to ISO 100 and below, as I did. The output is really lovely for the web and good for printing especially if the output is a book e.g. a reasonable sized print. Despite having tried the Merrill's I still reckon the previous generation has a certain something - enjoy!
www.anthonypalmer.me
 digi2ap's gear list:digi2ap's gear list
Sigma dp1 Quattro Sigma SD1 Merrill Sigma 10-20mm F3.5 EX DC HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
OP smarter Contributing Member • Posts: 541
Yesterday I received my DP1x. It looks brand new and there were only 120 pictures taken with it.
I charged the battery and took the camera with me to work today to take some test shots. In operation it's a very sluggish and slow camera, but the controls are very straightforward. It's obvious to me that this is a special tool, not a backup camera for general use. So far I like the first results:
jande9
jande9 Senior Member • Posts: 1,175
I got a DP1s 2 years ago and I have enjoyed the small size and great quality. Keep it at ISO200 and shoot RAW and you will find that the camera does very well with highlights. ISO in this camera doesn't affect sensor gain, it justs adjusts the exposure and the gain is made up in SPP.
Quick shipping!
 jande9's gear list:jande9's gear list
Sigma DP1s Sigma DP2 Merrill Pentax K-x Sony Alpha NEX-7
(unknown member) Senior Member • Posts: 1,857
The DP1s is different to the Dp1x/SD15 with AFE (Analog Front End).
Which one is considered the better camera? DP1s or DP1x?
I would say, both are great, the DP1x is more modern, colors are more neutral, but you have to be a bit more careful exposing because highlights (especially brown/red) can blow out earlier.
(Skin tones in harsh sunlight for example)
Maceo
Manzur Fahim
Manzur Fahim Senior Member • Posts: 1,710
Hmm I bought a DP2M for the same reason, the excellent sensor. Not sure what to do with all these camera
 Manzur Fahim's gear list:Manzur Fahim's gear list
Sigma sd Quattro Fujifilm GFX 50S Fujifilm GF 110mm F2 Sigma DP2 Merrill Nikon D810 +4 more
PrebenR Veteran Member • Posts: 3,529
I have both. DP1x is much better when it comes to the controls at least. Colours between DP1x and DP1s are different, but which is better depends on taste DP1x has better sharpness and less noise.
Lightwriting with Sigma
So far I really like my DP1x Despite it's flaws in operation, speed and the very restricted ISO values. It's a specialty camera for certain occasions and I will treat it this way.
I like the Sigma look of the few pictures I took very much. I bought a DP2S tonight on Ebay to complement my Dp1x. I already enjoy My Pentax K-01 + Sigma 30mm 1.4 so basically I didn't need a Dp2 at all. I was just too curious to try it out for the € 180 I paid for my DP2s.
