Samyang 8mm fisheye: rear-mounted filter?
Started Feb 6, 2014 | Discussions
epozar Contributing Member • Posts: 826
I need a strong ND filter, say 6-10 stops.
Unfortunately Kodak Wratten 96 series gelatine filters are getting very expensive ($60+) - is there an alternative? Thin glass filter 37mm?
Yes I know there is no filter holder behind this lens, but I will improvize for a day-long shooting.
 epozar's gear list:epozar's gear list
Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro
NancyP Veteran Member • Posts: 6,161
Re: Samyang 8mm fisheye: rear-mounted filter?
If the lens does not protrude in back of the flange, you might be able to rig something. The mirror needs room, but there are examples of filters fitted across the flange. Astronomix makes such a clip-in filter, and the Sigma SD1 has a removable IR filter in that location. It might be simpler to rig something in a compact, as mirror fouling is not an issue.
http://www.astronomik.com/en/  for the clip-in kind.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
OP epozar Contributing Member • Posts: 826
Interesting site and idea
However these are *not* ND filters.. and rather expensive also.
