The right wide-angle zoom
Started Feb 6, 2014 | Questions
fansmanship New Member • Posts: 4
Hey everyone. First time posting on the forum, so bear with me.
I shoot sports and action a lot - basketball, etc...
I have two Canon bodies (70D and T3i) and am looking at a better wide angle lens. Here are the lenses I have:
18-55 kit lens
70-200 2.8
50mm 1.8
85mm 1.8
I'm thinking to sell the 85mm 1.8 and buying a better wide-angle (2.8) lens where the AF is going to work fast enough for sports like basketball.
As I see it, I have 2 or 3 options if I'm not going with a Canon 24-70 (since I don't have over $2000 to spend).
1) 18-55 f 2.8. It's not an L series lens but seems like the AF would be quick enough? and price is $850-$900 range... which is doable.
2) Tamron 24-70 VC 2.8. I know it's Tamron's run at Canon's 24-70, but what does the AF look like on this one? I've never bought a Tamron lens and I'm sure it looks fine comparatively for my taste, but I'm definitely concerned about the function of the AF in comparison to a canon...
3) Canon 16-35 2.8. This is an L series lens and might be out of my price range, but how big a difference would it make compared to the other two?
OK, I'm up for people weighing in on any of the above or other ideas. A full frame camera is somewhere in my future, but it is probably quite a ways off at this point. Any suggestions would be appreciated!
photonius Veteran Member • Posts: 6,895
Re: The right wide-angle zoom
18-55 kit lens
70-200 2.8
50mm 1.8
85mm 1.8
presumably you mean the Canon 17-55 f2.8 IS (there is a sigma 18-50 f2.8 lens).
It's top notch, your best bet.
That's a standard lens for FF. it's not very wide at all on crop, why don't you try your 18-55 at 24mm to see how much you loose at the wide end. But maybe it's the focal length you want?
unless you go FF, the 17-55 IS is the right choice for crop.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Abu Mahendra Veteran Member • Posts: 5,312
Will you be shooting at the rim only, or up and and down the court also?
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Odd, I shoot basketball with the 85mm f/1.8 and it focuses fine. In fact, that would be my recommended basketball lens for full frame, though maybe a 50mm would work better with a crop camera. I also shoot with the 70-200 f/2.8 for floor action.
But to answer your question, the 16-35 is a real meat-and-potatoes photojournalist lens, though too wide for normal basketball shots. The 24-70 f/2.8L II might also work well on crop cameras--it is incredibly sharp, flare resistant and fast focusing.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
OP fansmanship New Member • Posts: 4
Some of both. I would like to have one body with the longer lens for up and down the court and another with a shorter lens for inside of the 3-point line, where most of the action takes place....
To your point, one of the better photogs I know says that the 70-200 on a full frame is ideal for basketball. The problem, I guess, is that I have a non full-frame, so it's more like a 110-320 or so...
Great. One additional question as I read responses then too. Am I correct to think that the EFS lenses DON'T work on full-frame? If this is the case, does their zoom also need to be thought of as 1.6 magnification (despite the fact that they're seemingly made for a cropped chip)?
Here's an example of a shot that has me asking my question in the first place. Among other things that I'm probably not doing right composition-wise (including shooting landscape), just not wide enough to show more of the play/players. This was a sports-center top-10 play I shot from the baseline at the corner and it was probably aimed a little high, among other things. I feel like a slightly wider option would have given me more room for error and the ability to crop a little later if I needed to for a play like this...
18-55 kit lens
70-200 2.8
50mm 1.8
85mm 1.8
Yes. this is what I mean. Obviously it wouldn't work with FF body. Does that also mean that the 17-55 will give me 17-55 with cropped sensor (since it's made for those cameras) or would it still by 1.6x?
Yes. I'm pretty confident in the Tamron the more I read about it, but your point is well-made about the zoom. I suppose I could test it using my kit lens (depending on your answer to my question above). What do people know about the AF capabilities of the Tamron? Should I be worried?
Thanks again everyone for the insight!
It so, you could consider the Tokina 11-16 f2.8 for at the rim. Set it to manual focus at 5 meters (16 feet). At 16mm (26 FF equivalent) and f/2.8, everything between 2.5 meters (8 feet) and infinity will be In focus.
That's worst-case. Stop down or go wider, and you get even greater DoF.
peterharvey Contributing Member • Posts: 930
18-55 kit lens
70-200 2.8
50mm 1.8
85mm 1.8
The lens has a focal length.
Whenever we use the smaller APS-C size sensor, we must multiply by a crop zoom factor of 1.6; this gives us the focal length in full frame equivalent.
When we use a full frame sensor, we don't have to multiply by anything at all.
Have a look at this YouTube 4-way comparison between the EF-S 17-55 f2.8 3x zoom, Sigma 17-35 f1.8 2x zoom, Sigma 17-50 3x zoom f2.8 and the Tamron 17-50 3x zoom f2.8.
Note that all these lenses have wide apertures of f/2.8, but their zoom ranges have been greatly diminished down to just 3x zoom, where a typical EF-S 15-85 has a small f/3.5-5.6 aperture, but has some 6x zoom range.
Note too how the Sigma 17-35 f/1.8 only has 2x zoom range, but has an even bigger aperture of f/1.8.
Thus, the wider the aperture, the shorter or shallower the zoom range.
A prime lens has really big apertures like f/1.4 or even f/1.2, but it has only the single focal length.
Life is a compromise...
 peterharvey's gear list:peterharvey's gear list
Sony RX100 Canon EOS 70D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm f/2.8 Macro USM +7 more
There is a zoom lens for Crop sensor Cameras with constant F1.8 aperture with 18mm at the wide end.
Is that a single focal length prime of 18 mm with an F/1.8 aperture? Who makes that may I ask? I find that there are a real shortage of primes for APS-C sensors.
peterharvey wrote:
18-55 kit lens
70-200 2.8
50mm 1.8
85mm 1.8
Ooops, here's the YouTube 4-way comparison I promised: http://youtu.be/T3UfbsdfUu8
No, Peter, I am talking about a ZOOM lens for Crop sensor cameras with constant f1.8 aperture throughout its om range!
Methinks the OP needs fast and/or wide, and for that, on Crop, there are only two lenses. I'll give you a hint. Only I have mentioned or alluded to both.
Oh, I know what you mean; we'll let him guess then...
Klaus dk
Klaus dk Veteran Member • Posts: 9,760
You are correct, the EF-S lenses has a smaller image circle and will not be able to fill the frame of a FF camera - and I believe they cannot be mounted on one either unless you tweak them.
EF and EF-S lenses are always marked with the actual focal length. An EF-S lens at 50 mm will give the same field of view as an EF lens at 50 mm. On an APS-C camera, that will be the same field of view as you would get with an 80 mm lens on FF, but the crop factor for APS-C is always the same.
On compacts, you will sometimes see the equivalent (to FF) focal length, but not so on APS-C.
If you think the 70-200 mm is a bit long on you crop camera, you might like the Sigma 50-150 f/2.8 - APS-C only, though.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
The Sigma 18-35mm f1.8 (crop only) zoom. Based on tests it's excellent, basically a replacement for primes in that range. But it's also pretty big.
Tell us more, photonious...
it's been reviewed right here, not long ago
http://www.dpreview.com/lensreviews/sigma-18-35-1-8
