Is it normal for Canon Rebels (T5i) to have creeky hand grips? Do you have one?
Started Feb 5, 2014 | Discussions
Cameranoobie Senior Member • Posts: 2,936
Im going to exchange mine today as I noticed over the past 2 weeks the top half of the hand grip has become creeky. It's the sound of plastic on plastic. It's kind of a clicking and creaking that I can feel in the handle when I grab and/or move the camera by the grip, which is a pain because the sounds is quite audible and makes the camera feel less solid.
I might be a bit OCD over this since it doesnt affect the functionality of the camera at all, but it bothers me each time i pick up the camera.  Just curious is this is a common problem on the T5is?  Hope my new one doesnt get this.
From what I see, there is no way to pop the hand grip off and stuff some padding inside the grip for more insulation.  Usually handgrips are easily removed on DSLRs but i guess not with Rebels.
Does anyone else have or seen creeky handgrips on rebels?  Id imagine, they only get worse over time, hence why im changing mine.
 Cameranoobie's gear list:Cameranoobie's gear list
Sony RX10 IV Nikon D500 Sony a6400 Nikon Z7 II GoPro Hero9 Black +17 more
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
EvanRS16 Forum Member • Posts: 58
Re: Is it normal for Canon Rebels (T5i) to have creeky hand grips? Do you have one?
I experienced a very similar issue with my T4i (practically the same as the T5i).  The first T4i body I had did not squeak, but it was affected by the rubber grip recall, so I swapped it at Best Buy as soon as they received a new batch.  That second T4i made a very audible and annoying creaking sound when I held the top half of the grip, between the IR sensor and the lip underneath the shutter button.  It bothered me enough to exchange it for a third T4i, which fortunately has been perfect for over a year now.
 EvanRS16's gear list:EvanRS16's gear list
Sony RX100 Sony a7 III Sony FE 55mm F1.8 Tamron 28-200mm F2.8-5.6 Sony FE 28-60mm F4-5.6 +2 more
Hank3152
Hank3152 Forum Pro • Posts: 13,499
That's pretty much common with any Rebel, some worse than others, and for a few, none at all. When you upgrade to the next level of prosumer bodies like the 70D or 6D that will be a non-issue.
I remember my first, the XTi creeked every time I handled it, but the replacement 40D was solid and built like a tank......
"Five out of four people have trouble with fractions."
Hank
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm F2.8L Macro IS USM +5 more
OP Cameranoobie Senior Member • Posts: 2,936
Interesting.  Wonder why this is a common problem on Rebels.  Is there no way to just pop the grip off and stick some foam down there or something?
Do you know why its a common problem with Rebels?  Cheap hand grip material?
Whats this Canon hand grip recall that people talk about?
crashpc Veteran Member • Posts: 7,240
I must be lucky. Didn´t heard of this problem, never happened to me.
Why does he do it?
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Digirame Forum Pro • Posts: 41,857
I have two Canon T2i (550D) cameras.  I've never had a problem like that.  Both of mine feel really solid and strongly built.
Ed P Senior Member • Posts: 1,000
Ditto for my T1i, which feels better (more solid) than the T5i and the 70D I tested a few weeks ago. The T1i feels more like the 50D (which definitely feels more solid than the newer models, to me).
 Ed P's gear list:Ed P's gear list
Canon EOS 500D Canon EOS M50 Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II Canon EF-S 55-250mm f/4-5.6 IS II +2 more
treecrabwill New Member • Posts: 5
It must be the same for the t7. It is happening to me, so I will just ignore it.
 treecrabwill's gear list:treecrabwill's gear list
Canon EOS Rebel T7 Fujifilm X-S10 Canon EF 85mm F1.8 USM Canon EF 75-300mm f/4.0-5.6 III Canon EF-S 18-55mm f/3.5-5.6 IS II +2 more
karl mohr Senior Member • Posts: 1,678
I have noticed that a little bit from my 1.5 year old 80D, and a little bit on my daughter's 80D.  My 60D and 70D don't do it.
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
