GX7 sensor vs. EM5 or EM1 sensor
Started Feb 5, 2014 | Discussions
Enir4 Senior Member • Posts: 2,468
What is supposed to be the difference between these two sensors regarding rendering or IQ?
Enrique
 Enir4's gear list:Enir4's gear list
Sony RX100 VI Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +1 more
Olympus E-M1 Panasonic Lumix DMC-GX7
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Re: GX7 sensor vs. EM5 or EM1 sensor
Really, they are so close to each other than you can consider they deliver the same IQ.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
Jim T Veteran Member • Posts: 4,293
Worrying about the sensor performance is no longer relevant. It's apparently all about Shutter Shock now
Seriously, IMO the glass in front of the sensor or the eyeball behind the sensors are more important.
Enrique
 Jim T's gear list:Jim T's gear list
Sony Cyber-shot DSC-TX10 Olympus Tough TG-1 iHS Panasonic Lumix DMC-GH1 Olympus PEN E-PL2 Panasonic Lumix DMC-GF3 +12 more
Ulric Veteran Member • Posts: 4,559
Enrique
My take from personal experience: GM1 (same sensor as GX7) has similar amounts of noise in low light as E-M5, but the noise is "nicer" looking. And there are as far as I've seen no signs of banding when using the Panasonic 20/1.7 on the GM1.
Both sensors are very good and I wouldn't choose one over the other based on IQ.
The E-M1 uses a different sensor.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
How they're wielded.  Output is comparable in practice, for still anyway.   Feature sets, styling and controls is where they significantly differ.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
(unknown member) Veteran Member • Posts: 9,509
Enrique
http://www.dxomark.com/Cameras/Compare/Side-by-side/Olympus-OM-D-E-M1-versus-Panasonic-Lumix-DMC-GX7-versus-Olympus-OM-D-E-M5___909_901_793
I prefer the Gx7 of these three, others will have a different choice.
techiecool Regular Member • Posts: 427
Does the real world GX7 vs OMD sensor perform more favorable in low light vs DxO
Andrew MM Forum Member • Posts: 59
What about DR on high contrast shots?  According to DPR and DXO, the dynamic range is considerably higher on the EM5 vs the GM1 (closer with t he GX7).  Plus the curves are much more gentle that reduces clipping.  You have both cameras...any thoughts?
 Andrew MM's gear list:Andrew MM's gear list
Panasonic Lumix DMC-ZS15 Panasonic Lumix DMC-LX7 Sony RX100 III
Probably not (but I have a FF Sony A7 for low light).
It is still pretty good in low light though and the AF works at -4 EV! (metering is less).....I just like the GX7 over the Oly's.
Thanks. I've been debating em10 vs gx7 back and forth. i'm more than likely going gx7. seems like i'd get better video, no hump vs oly's better jpeg colors, ibis for video. the price difference would allow me to add a prime sooner...low light i can't swing the sony a7 lol. not with the cost of diapers piling up ha
DxO reports a much larger difference between the GM1 and GX7 than is reasonable for two cameras with the same sensor. With no independent verification, I think it is wise to ignore dubious results.
Live blinkies, the single most important feature in nailing exposure, are unfortunately only available on Olympus cameras. I think that's much more important than any sensor difference between these cameras.
Jorginho Forum Pro • Posts: 15,370
I am not sure about that..
The sensor read out, the circuiry of the GM1 might be different. Also: it is only the dynamic range of course. The other paramters are identical. But the DR is significantly lower.
What is more important is that the DxO consistently (now) reports that the same lens perfoms worse on the GX7 and it is a significant difference....I would try to look into that more but it seems difficult to assess....and then we can argue: if it is so difficult, it may be significant in numbers but not so meaningfull in reallife...
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
paul cool
paul cool Veteran Member • Posts: 3,137
Re: I am not sure about that..
May sound strange but another forum posted that omd em1 uses a panasonic sensor ?
So if true you can bet that the gh4 will be the next latest and greatest  cam for stills and video m43 division
http://chipworks.force.com/catalog/ProductDetails?sku=OLY-E-M1_Pri-Camera
 paul cool's gear list:paul cool's gear list
Sony a7R III Sony a1 Sony FE 70-200mm F2.8 GM OSS Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD +3 more
Yes, or the measurements may simply be off.
That is interesting.
Is that code a unique code designated to panasonic?
Zensu11
Zensu11 Senior Member • Posts: 1,542
I've read on several forums that all the OM-D series sensors are Sony. I also think that Olympus is adding focus peaking to all the OM-D series because Sony has gone into partnership with Olympus and Olympus will be adding a focus peaking feature to the E-M5 via a new firmware update soon.
paul cool
well omd-em5 and gh3 are sony  not sure as to omd em1 source
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
And now we know that it is ... Panasonic did it again !
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
ruud44
ruud44 New Member • Posts: 11
Well Zenzu11, I was looking back......where did you get/got the information of firmware update and focuspeaking?
Now it's 2020 and version 2.3 latest with still no focuspeaking.
Do you have the EM5 as I have? We are both waiting among others for the 'peaking' of Olympus technicians if they will hack our systems...
