HSM vs SDM vs Screw Drive
Started Feb 4, 2014 | Discussions
edspen Regular Member • Posts: 195
After playing the what focuses best game with my gear, I pondered this : All the mechanical linkages in screw drives (body motor, gears, couplings, lens couplings, lens gears, etc.) have their individual tolerances when made. These have to add up to focusing inaccuracy. Electrically coupled lenses have less mechanical play, so wouldn't they have more accurate focusing ability ? When the camera sensor shows you're in focus how close is it really ? And, the hunting that some lenses love to do, is that due to loose tolerances ?
Ed
(unknown member) Forum Member • Posts: 91
Re: HSM vs SDM vs Screw Drive
An interesting question which i have no answer to and would love to hear peoples comments about it, however focus hunting is one thing i believe it is not, it often is due to low contrast of AF subject, and if the focus hunts anyway, from what i've seen it hunts so much that it is way beyond any mechanical tolerance level.
Oh and i i wonder about the old AF lenses without AF override, is there play in the manual focus mechanism at all like there is in most ultrasonic lenses, or is the play in ultrasonic lenses purely in the manual focus ring, or the interior mechanics.
If there is no play in the older AF lenses, that might prove there is some design reason, so that the play is minimized due to no ultrasonic motor.
chary zp Senior Member • Posts: 1,464
It doesn't have to add up to any focusing inaccuracy at all. Imagine a bicycle with a loose chain and the reverse-pedalling brake. I don't know what is the proper term for it, but with the "simple" bikes you do not have a "gear changer" but you pedal forward, you go forward. You stop pedalling and you go forward by inertia. You pedal backward and you brake the bike. Now...
The chain is loose. In perfectly tight chain you pedal forward and the wheel moves immediately. Thats sportsmen's bikes, like for bike football. No room for tolerances, no room for loose chain. On the other hand, an old lady in a village doesn't have top grade bike. So, with a loose chain you pedal a little and only the chain tightens, the wheel doesn't move, and when the chain is fully tightened, the wheel starts to move. Thus, motor, gears and coupling tolerances. You want to brake and the loose chain has to tighten up the other direction, so you pedal backwards and for a short while nothing happens but the chain tightens in the other direction. But after that the brake engages. Thus, focusing backwards and forwards, hunting there and back, looking for ideal focus. The tolerances just make the motor move a bit more than necessary until all the tolerances are tightened. And the motor only moves until the focusing circuit tells it to stop. So, in fact after the fist move, when the motor only tightens the tolerances, the focusing circuit still tells it to move since there is no change in detected contrast.
With my well set screw driven lenses I never had problem to focus precisely, provided the contrast was good and the light was good enough for the given aperture.
 chary zp's gear list:chary zp's gear list
Nikon D90 Nikon D200 Nikon D7100 Nikon D500 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR +11 more
OpticsEngineer Veteran Member • Posts: 6,352
Interesting question.   My experience is my screw drive lenses have the same focus accuracy as my motor drive lenses. (Sony SAM and SAM II vs screw drive and Pentax SDM versus screw drive)
For a few Pentax lenses, some people have had intermittent problems with SDM drive and have had them converted to screw drive (by firmware) and have reported good results.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +22 more
