NX10 - NX11 backup batteries
Started Feb 4, 2014 | Discussions
(unknown member) Contributing Member • Posts: 947
I have 1 NX10 / 2 NX11's which work fine. The issue now as they are years old, is replacing the internal battery. All 3 cameras lose their customer user settings / dates- time zones etc when the battery is changed. It seems the same issue as an old PC- the internal PCB battery backup has failed.
Anybody any ideas how to change this?
The degree of technical knowledge of the fanboi owner is inversely proportional to the size of his ego.
Samsung NX10 Samsung NX11
hootsmon
hootsmon Contributing Member • Posts: 903
Re: NX10 - NX11 backup batteries
  • You'll need to study this NX10 Service Manual
  • The internal PCB battery is mounted on the motherboard (refer schematic p7-2)
  • I skimmed the manual, and to me it looks like you'll probably need to disassemble the camera fairly completely, just in order to access the PCB battery holder.  And even when you get that far. there's a slim chance the battery may be soldered in place?
  • To be honest this disassembly looks somewhat daunting.  So my suggestion would be to attempt it only if you've got nothing to lose (ie. the body is a paperweight already).
@jaberwok, Having said that, I sure hope you do try it, and if you do then please take some pictures!!!
Good luck
 hootsmon's gear list:hootsmon's gear list
Samsung NX11 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 85mm F1.4 ED SSA +1 more
OP (unknown member) Contributing Member • Posts: 947
Good luck
Ah! Thanks for that. This one looks like a no-brainer. I tried to disassemble an NX10 before to repair the broken remote switch. I got so far and gave up.
Looks like I'll have to live with wonky dates (default is 1-1-2011) and Korean time.
Thanks mate.
