My 17-40 always shows 40mm in Lightroom...
Started Feb 3, 2014 | Discussions
zalle Contributing Member • Posts: 898
I opened my 17-40 because it had a loose screw and the zoom was stiff.
Fixed it, put it back together and it wors, the zoom is still somewhat stiff, but it's not too bad.
The one problem I'm having now is that when I import an image to Lightroom, all apictures at all focus distances show 40mm. Some contact is not working well. What can it be?
I used this guide: http://notabs.org/canon/ef17-40/disassembly.html
Thanks for any help
OP zalle Contributing Member • Posts: 898
Flash only recognizes 40mm as well... NT
No text.
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
Loose connection
The main board is not getting the zoom position information.  One of the connections of the ribbon cables is probably loose.  It should be an analog signal from a potentiometer wiper.
This may affect AF accuracy also.  Without knowing the focal length setting, the lens would not know how far to move to correct for the phase offset the camera is seeing.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
Re: Loose connection - Yes
Hi,
Thanks.
Just opened it again and put it back together carefully, and now it's OK!
Mimik
Mimik Regular Member • Posts: 152
Re: My 17-40 always shows 40mm in Lightroom...
Could be the zoom brush. I damaged mine on my 24-70, after that it only showed 70mm in LR and the focus was very slow and inaccurate. After I got a new zoom brush all was fine again.
