Canon EF 16-35/2.8L II - Hard Focus on Infinity When in Wide 16mm
Started Feb 1, 2014 | Discussions
gusleig
gusleig New Member • Posts: 7
aybe you guys can give me some adivce on this one
I have this amazing lens with my 5D mk3, but lately I noticed becoming very hard to focus on infinity when in the wide side (16mm). Focusing close objects works perfectly.
The lens when auto focusing a distant object like a mountain or something far then some meters, passes by by the infinity mark and stay there stucked so the camera doesn't shoot. I can manual focus on infinity and take the shot perfectly.
With others lens this doesn't happens. I tested with my 40mm, 50mm and the 24-105mm.
What is going on with this lens, or might be the camera?
Thanks in advance
 gusleig's gear list:gusleig's gear list
Canon EOS 5D Mark III Canon EF 16-35mm F2.8L II USM Canon EF 28-105mm f/3.5-4.5 II USM
Canon EF 16-35mm F2.8L II USM Canon EOS 5D
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: Canon EF 16-35/2.8L II - Hard Focus on Infinity When in Wide 16mm
The lens should not get stuck at infinity--I think your lens needs to be repaired.
Most lenses--especially telephotos--focus "beyond infinity." It is a technical feature for lenses to compensate for the lens expanding or contracting in extreme temperatures.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
gusleig
OP gusleig New Member • Posts: 7
Just to clarify, the lens trying to focus goes beyond infinity, but it never gets the focus and stops the camera from taking the picture. If I focus on a closer subject click, then go to the farest view then I can take the picture.
I might take the lens to a Canon service. Just trying to make sure it's not a camera problem.
JoEick Regular Member • Posts: 175
Your lens should not be doing this. Return it or get it repaired.
hotdog321
No, that is a lens problem. Good luck!
