RawDigger Histogram Question . .
Started Jan 27, 2014 | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 18,359
. . aimed at Iliah Borg.
On the main screen (for an SD9 X3F file) it shows max RGB data numbers up to 11,000+ for bright highlights - this normal for early Sigma X3F files.
But the histogram for the whole image shows hard clipping at the magic number of 4096. The image itself is not hard clipped.
I have tried HI and LO res. images. I have reset all preferences to defaults. No change.
Example:
Anybody know what's happening? Makes no sense to me
Thanks,
"Engage Brain before operating Keyboard!"
Ted
Panasonic Lumix DMC-LX1 Panasonic Lumix DMC-G1 Sigma SD9 Sigma SD15 Panasonic Lumix DC-G9 +14 more
Iliah Borg Forum Pro • Posts: 27,922
Re: RawDigger Histogram Question . .
Please try this. Uncheck "auto" under "Linear X axis". Enter some small value in the min field of the Range. Check "auto" back.
xpatUSA
OP xpatUSA Forum Pro • Posts: 18,359
Thanks for the quick reply, Iliah.
It didn't make any different, sad to say,
I have vague memories that it didn't used to do that. Should I re-install it?
Ted
Can you please send me a raw file? I will try to repeat the situation.
xpatUSA
I put one (2.7MB) in your folder here:
http://kronometric.org/phot/xfer/4Iliah/extRecept.X3F
Using RD V 1.0.2 build 279 (x32), Research Edition, License Activated.
Thanks for the help so far!
Ted
xpatUSA
Got it, thank you.
Good. I'm on Windows XP Pro, SP3, if that's of any help . . .
Ted
xpatUSA
Got it, thank you.
Just found out that the problem is with shots made by either of my SD9s.
The SD10 raw histograms are as expected with number up to around 10,000, no limiting.
Ted
xpatUSA
The problem has been resolved by RawDigger. They told me:
"This issue is already fixed in upcoming 1.0.3 release (not yet available to public, because we need time to test other changes)."
Ted
xpatUSA
For the record, I've tried a pre-release build and the problem is gone.
Thanks, Alex & Iliah!
Ted
Thank you for letting us know, and sorry for the trouble.
