D800 autofocus problems with 2x teleconverter
Started Jan 26, 2014 | Questions
DHNPhoto New Member • Posts: 2
I have a Nikon D800 and having no luck with focus when using a 2x teleconverter. I've tried both Sigma and Tamron 2x teleconverters on the following lenses. Sigma 70-200 2.8 (non OS version), Tamron 70-200 2.8 VC version, Sigma 120-300 2.8 (non OS version), Sigma 150mm 2.8 macro (non OS version). It will never lock focus, it just pumps back and forth forever hunting. They all work fine without the 2x. My older D300 worked fine with all of these combinations. Any suggestions?
WIMorrison Senior Member • Posts: 1,846
Re: D800 autofocus problems with 2x teleconverter
I had an issue with my Sigma 180mm macro lens and it transpired it was the lens software which Sigma said could not be made compatible with the d800 on the older lenses.
might be worth giving them a call, Sigma UK were very helpful to me.
Iain Morrison LRPS CPAGB
wimorrison.co.uk
 WIMorrison's gear list:WIMorrison's gear list
Nikon D7000 Nikon D800E Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +13 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 20,111
It is not rare for there to be an AF issue using some independent lenses etc on recent camera bodies.
Usually the solution is to get the independent lenses re chipped with new electronics. Some older items cannot be re chipped.
My similar Nikon lenses and converters autofocus fine.
Leonard Shepherd
Great images are often of good subjects.
If they are great images does what lens, body or technique was used matter more than the skill of the photographer?
Nikon D810 Nikon D500 Nikon D850 Nikon Z7 Nikon AF-S Nikkor 14-24mm f/2.8G ED +28 more
Luis Materon New Member • Posts: 1
I have exactly the same problem with the 2x teleconverter using a NIKON D800 and a 300 mm 1:4 D.  Focus does not lock.  However, I have better luck with the 1.4x teleconverter. I will appreciate to know why the 2x does not focus.
BirgerH
BirgerH Veteran Member • Posts: 5,904
Hi.
One reason might be, that your 300mm f:4 becomes a 600mm f:8 - which makes the AF system (and the metering system) unstable.
BirgerH.
 BirgerH's gear list:BirgerH's gear list
Nikon D90 Nikon D7000 Nikon D800
theonetruepath Senior Member • Posts: 1,737
Any suggestions?
Yeah... buy a D850. 2x converters barely work with cameras that are really good at AF. A D800 is only passably good at AF.
 theonetruepath's gear list:theonetruepath's gear list
Nikon D810 Nikon D850 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF Micro-Nikkor 200mm f/4D ED-IF +4 more
larrywilson
larrywilson Veteran Member • Posts: 7,017
Using a tc 2.0 converter on an f4.0 lens will make the auto focus slow and unstable.  I sold my tc 2.0 long ago.  The 2.0 converter will work better on an f2.8 lens.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D850 Nikon AF-S Nikkor 70-200mm F4G ED VR Nikon AF-S Nikkor 500mm F4E FL ED VR Tamron SP 85mm F1.8 Di VC USD Tamron SP 150-600mm F5-6.3 Di VC USD G2 +6 more
ianw2 Regular Member • Posts: 120
At f8 only the central autofocus points work. Perhaps this could be the problem for some who are having difficulty. I would also expect autofocus at f8 to be somewhat problematic in low light.
Ian Wiese
ianwiese.wordpress.com
