Repairing Olympus 14-42mm R (bad cable? instruction?)
Started Jan 26, 2014 | Questions
John_of_LA Senior Member • Posts: 2,058
Hi,
My friend's lens, already off warranty. The cameras won't properly recognize the lens, they either see as it is not extend or not recognize the lens at all. Olympus Thailand said it probably the bad cable and wants to charge a lot for fixing it (~$180!). So, I'd like to try fixing it for her. Any suggestion?
Jeff Tokayer Veteran Member • Posts: 6,289
Re: Repairing Olympus 14-42mm R (bad cable? instruction?)
Try cleaning the contacts with an eraser. Otherwise, replace it with one of the many on Kijiji for $80.
My nickel, since the penny is being discontinued...
Jeff.
markintosh13
markintosh13 Veteran Member • Posts: 4,951
Does the camera recognize other lenses?
Have you checked the pins / cleaned the lens contacts?
I would buy a replacement (if I really used a kit lens very much, which I don't) off ebay for about $50 - 70 usd before bothering with off-warranty work at those rates. Given that the lens seems to add only about $50 to the price of a body...
Maybe this is a good excuse to go lens shopping.
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
Heck. . . I'm using this as an excuse to go lens shopping for myself.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
s_grins
s_grins Forum Pro • Posts: 14,011
John_of_LA wrote:
Hi,
Sure you can try to fix it by yourself. Buying a new or used replacement lens is not very expensive.
Sorry to say, but I do not think you can fix the problem. It could be a faulty cable, and it could be faulty identification chip (at the end of the cable). Anyway, you need spare part.
But, if you can find a aftermarket chip and cable for the lens, things look different.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
markintosh13
I'll see if I can come up a reason you'd accept as an excuse to go lens shopping for me as well while you're out...
n3eg
n3eg Veteran Member • Posts: 3,316
If you're going to throw it out anyway, you might try opening the rear end with a #00 Philips screwdriver (put it on a paper plate first to reduce loss of screws) and see if any of the flex cable connectors have popped up and released the flex contacts.  Be careful - those flex cables tear easily - try not to panic when you see how tiny everything is, and get your tweezers.  Of course, try cleaning the contacts first before opening anything.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
