F20M and F43m Flashes with A7 wireless setup so limited?
Started Jan 25, 2014 | Discussions
zither Regular Member • Posts: 240
I was trying to use F20M on my A7 as the trigger for F43m. The F43m is only triggered when set A7 to WL flash mode. But at the same time, the F20M will NOT contribute to the exposure no matter what flash comp I set on A7 body. When I set A7 flash mode reguler/slow/rear/ modes, the F43m will not be triggered at all. The F43m setting like RMT1 or RMT2 doesn't change anything.
So overall, the F20m can only serve as pure trigger, and I still just got one light source from a different position. Plus my RX100II cannot trigger F43m at all with either build-in flash or F20m mounted.
I mean seriously?? My cheap Youngnuo flash can be triggered on all above situations with or without exposure contribution from build-in flash. And the price is 1/6 of F43m.
Hmm.....If I'm not setting anything wrong, I'd really think of getting anther Youngnuo and sell the F43m.
 zither's gear list:zither's gear list
Sony RX100 IV Sony a7R II Sony FE 55mm F1.8 Fujifilm XF 10-24mm F4 R OIS Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +1 more
Sony a7 Sony RX100
LoneReaction Contributing Member • Posts: 681
Re: F20M and F43m Flashes with A7 wireless setup so limited?
The difference between the Yongnuos and sony flashes are TTL. If you don't use TTL at all, then the Yongnuos are a much cheaper option. Still nice to have one TTL capable flash for quick on-camera shooting though. The F20M lets you have off-camera TTL.
 LoneReaction's gear list:LoneReaction's gear list
Sony a7R III Sony FE 55mm F1.8 Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.4 GM Sony FE 16-35mm F2.8 +4 more
Pone4330 New Member • Posts: 14
Try turning off HSS on the F43m
 Pone4330's gear list:Pone4330's gear list
Sony Alpha NEX-3N Sony a7 Samyang 14mm F2.8 IF ED MC Aspherical Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS
OP zither Regular Member • Posts: 240
Can you provide more details? I don't see why HSS is directly related to wireless flash mode
