E-M1 Wireless Remote Shutter Release - Inexpensive
Started Jan 23, 2014 | Discussions
Florida Nature Photographer Veteran Member • Posts: 8,862
There were a couple of threads, which I can't seem to find, on this subject a while back.
To summarize, the Olympus Smartphone app works fine as a wireless shutter release EXCEPT if you want to do HDR bracketing.
At least for the moment you need a normal remote shutter release for that. In one of the threads I can't find there were a number of options mentioned the best being this $65.95 one.
I didn't like that option so I did some more research and contacted the company that made the release I used for my FZ-200.
Bottom line, this $19.99 release arrived yesterday and it works great on my E-M1!
If someone wants to link in the other threads here that would probably be convenient for some folks. It would also bump the thread so more have a chance to see this.
 Florida Nature Photographer's gear list:Florida Nature Photographer's gear list
Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 12-40mm F2.8 Pro Topaz Adjust +3 more
Olympus E-M1
Bobo Hodls
Bobo Hodls Forum Pro • Posts: 40,433
Re: E-M1 Wireless Remote Shutter Release - Inexpensive
Thanks for that.   I don't have that need often, but I know it's due a few times a year - at at that price, why not?
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bobo Hodls's gear list:Bobo Hodls's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T4
bdmoody Junior Member • Posts: 26
Thanks just placed order
 bdmoody's gear list:bdmoody's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +1 more
Weegee
Weegee Veteran Member • Posts: 3,032
Will that work with my OM-D EM-5?
It doesn't seem to mention it.
Oly E10 Contributing Member • Posts: 657
Thought I'd investigate the $19.99 remote that you quoted above and available from
Amazon.com. Thought I'd give Amazon.ca (Canada) a look to see if they stocked
the same item, and yes indeed they do, asking price $47.67 Cdn.
Wow, sorry Amazon, no will buy. Amazed at the difference.
I'll see if it's available elsewhere in Canada, but cheaper.
Thanks for the heads-up re the remote anyway.
Peter in Canada.
 Oly E10's gear list:Oly E10's gear list
Olympus E-1 Olympus E-5 Olympus E-M1 Olympus PEN-F Olympus Zuiko Digital ED 14-35mm 1:2.0 SWD +3 more
OP Florida Nature Photographer Veteran Member • Posts: 8,862
Re: Will that work with my OM-D EM-5?
I have confidence that it does but if you want to be sure ask them...
Rainbowjiam@gmail.com
"Is the Pixel RW-221 Wireless Shutter Remote for Olympus Camera
http://www.rainbowimaging.biz/shop/product.php?id_product=716
compatible with the Olympus E-M5 camera which uses the RM-UC1?"
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
The plug needs care....., maybe.
I use the Hahnel Giga Pro T Mk1 and now there's a Mk2 .
These remote devices work for all Pens/OM-D except the E-PL1, it has no ability to shoot from the remote connections in the USB port.
All these remote devices face the possibility that the USB plus is a too firm fit and is hard to push in and often the plug falls apart on extraction. The ends of the plus may need a little bit of filing to reduce to the "perfect" 6.35mm (1/4 inch) or a whisker less.
My Hahnel was a bit bigger and jammed, repaired the plug and alerted Hahnel and they sent two spare cables, both were wrong size so filed them down as well to fit nicely, no more problems.
What the Hahnel originally measured, jammed horribly.
Now what it should be....
This is the Olympus USB cable.
I filed the ends of the Hahnel plug until it fitted smoothly, only took a few strokes with a fine metal file, measured about the same as the USB cable when finished.
I have seen threads where the Pixel brand plug also gave problems, so be careful.
Regards.... Guy
Re: The plug needs care....., maybe.
Thanks for the warning Guy. I received an email confirmation from them that it was compatible with the E-M1 before I ordered and mine worked fine.
Certainly fair cause for a return/exchange if it doesn't work for someone else.
Bobo Hodls
Thanks. You're quite a. . .
. . . Guy.
[cracking myself up]
Seriously, good tip, much appreciated.
...Bob, NYC
Guy Parsons
Re: Thanks. You're quite a. . .
Bob Tullis wrote:
. . . Guy.
No problemo. I learn something every time I get involved in a question. And if that leads to helping someone else later, then all the better.
It's just that when I first blithely shoved the Hahnel plug into the E-PL5 it felt a bit tight. When I extracted it the inner bit came away and the outer metal shell stayed in the camera. Yikes, heart stopping moment.
Used fine pliers to extract it and a bit of careful reassembly made it good, then I bothered to measure it and the official USB cable to find that difference. Told Hahnel in Ireland and they alerted engineering and sent me two new cables (both too big), but no idea if anything changed. Easy fixed with a file anyway.
One thing to watch with these radio remotes are the batteries, they die easily because they probably draw a whisker of current all the time while monitoring the on switch. Twice now I've been caught with dead batteries, first in the receiver and then in the transmitter. Carry spares and also find some way to disable the battery if easy to do so. I try and slip some thin plastic in to disable the battery compartment, pull out the plastic and it's ready to go, I do that for flashes mostly but any battery driven gadget needs the same treatment.
Regards.... Guy
I ran into this problem myself with the version made for my FZ200. I always blamed it on me stupidly leaving the transmitter on. Whatever the reason I carry a spare set of AAA batteries in my photography backpack to protect me from this issue.
Bobo Hodls
Guy Parsons wrote:
Bob Tullis wrote:
. . . Guy.
More good advice, Guy.   I've been thinking about the flash, lightning trigger, and this - in that I don't use them often enough.   I thought to cut paper to store in the battery compartment, to slip between contacts to stop the trickle, but more so to stop leakage potential when stored unused.   I ruined one flash by forgetting I left batteries in it, that way.   If I know I won't pick up the device again for months I'll unload it -  but then out of sight, out of mind. . .
...Bob, NYC
Guy Parsons
Batteries
Don't use paper, use some suitable plastic instead. I use bits of some of that junk plastic that surrounds most things you buy now.
Using paper I found that there is still some electrical activity to the extent that some electrolysis effects were happening and marking the flash and battery contacts and also was obvious on the paper.
Regards.... Guy
baxters Veteran Member • Posts: 5,319
Oly E10 wrote:
Thought I'd investigate the $19.99 remote that you quoted above and available froAmazon.com. Thought I'd give Amazon.ca (Canada) a look to see if they stocked the same item, and yes indeed they do, asking price $47.67 Cdn.
Wow, sorry Amazon, no will buy. Amazed at the difference. I'll see if it's available elsewhere in Canada, but cheaper.
Search for  "Oppilas remote Olympus" on your ebay.ca  and you find them for around $22 CDN.
Don't have Amazon prime and would get charge several bucks for shipping, so I just ordered one off ebay  USA with free shipping for $20.
Hope mine works. I figure with these cheap remotes, they gave a 20% failure rate.
 baxters's gear list:baxters's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
daddyo Forum Pro • Posts: 12,670
Yes, it works with the E-M5 also...
I've been using one of these for a couple years now -- you can't beat it for the price. It will work with any Olympus that uses the 'plug in' style shutter release.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
I remember reading the Amazon comments for the FZ200 version and a number of the "failures" ended up being just not hooking it up quite right.
Stuart Senior Member • Posts: 1,374
Were you able to set this up without ability to read the instructions, reportedly in an Asian language ?
I just went and got them. They are Asian and English but primarily photos of what you should do.
I expect to be around if you can't figure it out.
I was, literally, just out in the back yard using it to get some golden hour birds. It was working fine.
I came in put it in my camera bag and saw your message.
