NX300 early impressions
Started Jan 23, 2014 | Discussions
pixelpushing
OP pixelpushing Veteran Member • Posts: 3,279
Re: Some context: Buffer numbers.
tecnoworld wrote:
Where are fuji x-a1 (and brothers) and the older nex7? I don't consider fixed lens cameras to be competitors to nx.
I don't see why not. Just because they have a fixed lens doesn't mean they aren't comparable, or similar in performance and application. I didn't include X-A1 because IR doesn't have buffer figures for that. I did include the X-Pro1, a higher end model.
For me everything below 8-9 frames in raw is very poor. For you it may be different and I don't want to change your mind.
I think if an 8 or lower frame buffer is very poor to you, you're going to be unhappy with any but a very select few models, most of which cost far more than the NX300.
And, given the sales, if samsung does not get the best in everything (and by a large margin) they won't ever sell decently.
Not sure what this means...
 pixelpushing's gear list:pixelpushing's gear list
Sony a7R III Tamron 24mm F2.8 Di III OSD Samsung Galaxy Note9 Apple iPad Pro
KimberlyC
KimberlyC Veteran Member • Posts: 7,107
Re: NX300 early impressions
A very informative and enjoyable read, hope you continue to love the camera!
 KimberlyC's gear list:KimberlyC's gear list
Nikon D7000 Samsung NX210 Samsung NX30 Olympus E-PL7 Olympus E-M5 II
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Fixed lens cameras and ilc are directed towards different kind of consumers or they are 'complementary' sometimes, but I don't see them as alternatives. This is proven by the fact that a lot of dslr users also own a flc, while they don't have a mirrorless ilc. Besides many users will feel that having just one fl is very different than having many.
I don't see x-pro1 in your list. Anyway x-a1 can do, if I remember well, 10 raw+jpg.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
wstruth
wstruth Regular Member • Posts: 336
tjobbe wrote:
arbuz wrote:
pixelpushing wrote:
CONS: I'm starting to think the NX300 gives up a smidge of sharpness to the previous gen model(s).
I like your review. Regarding above - I must say I have sometimes similar impression. I shot both NX30 and NX300 and occasionally I think low ISO is better on NX20. I have never done any test though so I cannot confirm. certainly noise reduction on high ISO has different patter on these both cameras.
the measurements of the NX200 indicates that they oversharpend the JPEG way more than in the NX20 and NX300 hence he impression is backed up by facts.
Nevertheless oversharpening is artificial and if you really liked the look of the NX200 you need to shoot raw and push the slider in LR
I personally develop my RAW's in LR as well with some oversharping but mainly for edges only
I also believe that the NX300 default noise reduction is set too high in JPEG (even though the camera says it is the "Normal" setting). I couldn't believe that my 20 megapixel OOC JPGS's were softer than ones from my 16 megaixel Pentax, so when I checked the noise reduction I set it to Off. they are better now, but Raw still gives me the sharpest image.
 wstruth's gear list:wstruth's gear list
Ricoh GR II Canon G9 X Canon G7 X II Pentax K-1 Pentax KP +5 more
patrisilva
patrisilva Junior Member • Posts: 28
Hi, I have the NX300 for about 6 months. I was able to get a deal with the camera plus two zooms (18-55 and 50-200), after that I bought the 16, the 30 and recently the 60.
I have used the zooms in many occasions, and usually, kit zooms are known for not being a good lens, but I can assure that these two are very good. Before buying the nx300 I had the Sony Nex 5R, with the same zooms range (sony's 55-210), for what my eyes can see, the samsung's lens are much better. The 30 is famous for being a good lens, but noisy, the 60 is a macro lens, that I use for macro shots and portrait (the 45 is known to be very good). As for the 16 (as the 30) is quite small, many complain about is quality, I like it, of course there is a good amount of distortion.
So,  I am rather happy with the nx300, many complain about the lack of evf, I prefer to use the lcd, the most annoying thing is the lack of a flash in the body, you have to attach it, but I find it not pratical. The image quality is good, jpegs are good, but you can get a better result with RAW (huge files). In low light situations, the results are not so great, Fuji cameras seem to have a edge in this case. But for the price I have paid, I have just great things to say about.
 patrisilva's gear list:patrisilva's gear list
Fujifilm X-M1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake +1 more
MrSaffron New Member • Posts: 11
Had my NX300 and 45mm lens for 2 days and pleased, come from a NX1000 with 20-50mm lens. Managed to get a warehouse deal at £360 which was so cheap that I decided to skip waiting.
Burst and continuous is a lot better on the NX300 and the shutter speed with the f1.8 is pretty amazing, need to upload a chunk of pictures, once I've reviewed and picked a few samples.
Probably could have done this with the NX1000 but have started to get some nice cloud/sun pictures with F22 and also looking forward to a nice clear still night as the one or two night shots look promising.
I may be a little odd, as the flash is no real issue for me, I tend to leave it attached and it does not get in the way, perhaps as I've had years of using screens for shooting too the lack of EVF is less of an issue.
The touchscreen editing works nicely, especially as you can add the various effects afterwards, which speeds up shooting. Not as good as using pixlr express or similar on a tablet can see me sitting over a cup of tea when out in the summer, cropping up some shots and emailing them from camera.
WISHLIST
FTP option in WiFI, then can configure it to use my own hosted space, nice unlimited storage. Or failing that Flickr.
More control in remote viewfinder and less lag would make it useful, and option to stream but leave camera controls running. Can then use the mobile phone as a viewing screen when shooting videos.
PROBLEMS
The 45mm lens is a fast focus lens, but in a relatively dark indoor scene autofocus can still fail, need to get more used to manual focus I guess.
Now looking at the 50-200mm and 18-55mm lens
A backpack bag to carry the growing number of bits
Need to look at extension tubes for macro, as have got used to point and shoots that handle focus at as   little as 5cm, which with the NX IQ would give some stunning flower, insect shots.
shark81 Regular Member • Posts: 145
Lack of flash bothers me too, but I only want a pop up flash if they allow it to tilt... like that seen on the Fuji X-a1.
 shark81's gear list:shark81's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung Galaxy S4
