BP-1030 / BP-1130 Charger Questions
Started Jan 22, 2014 | Questions
Bryan M
Bryan M Contributing Member • Posts: 956
My NX210 uses the BP-1030 battery and includes a charger. As I understand it the NX300 does not include a charger. My question, will my NX210 charger accept and charge the BP-1130 batteries.
Thinking about upgrades here in the near future.
Bryan
www.bcmcue.com
 Bryan M's gear list:Bryan M's gear list
Nikon D750 Nikon Z6 Tamron SP 70-300mm F4-5.6 Di VC USD Tamron SP 70-200 F2.8 G2 Nikon Z 14-30mm F4 +2 more
Samsung NX210 Samsung NX300
NewForce Senior Member • Posts: 1,263
Re: BP-1030 / BP-1130 Charger Questions
Bryan, the answer is no.
I have NX210 BP1030 battle charger, but it wouldn't charge BP1130 batt.
Alternately NX300 body and travel charger can charge both BP1030 and BP1130 batts.
Kenny
seph Regular Member • Posts: 188
Hi,
Genuine Samsung charger will prevent you from using it with different batteries. To solve this, I've bough t a cheap chinese one on ebay, called "MTB DV-BP10430".  It can be used with both BP1030 and 1130 batteries flawlessy.
 seph's gear list:seph's gear list
Fujifilm XF10 Nikon Z6 Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AP-F 70-300mm F4.5-5.6E Nikon Z 24-70mm F4
No exactly seph. Samsung newer BC3NX01 NX series battery charger does charge both BP1030 and BP1130 batts.
Kenny
I didn't knew a new one was available. It's not too exensive, the one I found on ebay costs only $9.
tjobbe
tjobbe Senior Member • Posts: 1,430
the new one is avail and bundled here with the NX310 so yes, there is one that Samsung supplies but not with the NX300
The alternate one (German amazon lists them as PATONA) is charging both 1130 and 1030 as well and is capable to interpret the chips from the original BP1030/1130 so the color schema of the light is retained properly
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
mrpics Forum Member • Posts: 99
I can only support this!
And if you get the bundle with batteries, mine came with two of 1030mA capacity.
They don't last quite as long as the originals, but come quite close. Also the charger comes with a nice short power cable which I find handy if you travel a lot.
 mrpics's gear list:mrpics's gear list
Samsung NX100 Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +4 more
DinoSaurusje New Member • Posts: 9
LS,
purchase a Pixo-C3 and you can charge every Li-on accu and more, very useful.
arbuz Senior Member • Posts: 2,247
seph wrote:
Hi,
This is a correct answer. Samsung charger for NX200 will not charge battery 1130.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Bryan M
OP Bryan M Contributing Member • Posts: 956
Thanks for the replies everyone!
Bryan
www.bcmcue.com
