Memory card speed.
Started Jan 21, 2014 | Discussions
(unknown member) Contributing Member • Posts: 947
Memory card speed.
Anybody having write speed issues with high capacity SD cards?
I'm finding that with my NX20 the bigger the card the slower the camera writes. I use 32 / 64Gb high speed cards and a series of 3 bracketed RAW shots (9 images) locks the camera for 40 seconds. Use a 4Gb card rated at the same speed and the processing time is 18 seconds.
The obvious solution is to use the smaller card but what is the problem? I also note the NX11's don't have the same problem and are noticeably faster..smaller image files?
Solution to buy an NX30?
Thoughts?
Samsung NX11 Samsung NX20 Samsung NX30
viking79
viking79 Forum Pro • Posts: 14,157
Re: Memory card speed.
What type of card are they?  are both the 4 GB and 64 GB cards the same write speed (class 10 doesn't mean much except for video, minimum sustained transfer rate).
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP (unknown member) Contributing Member • Posts: 947
Eric
Same brand, same speed.
