The 85L II is pure indulgence
Started Jan 18, 2014 | User reviews
keithinmelbourne
keithinmelbourne Senior Member • Posts: 1,026
The 85L was a lens I lusted for over 3 years. I bought the 85 f1.8 which was (is) a great performer for the money. Certainly it is faster to focus, accurate, lighter and works decently on a range of Canon bodies. The 85L is none of these things. It is heavy, costly, only seems to work decently on pro bodies and is difficult to use at maximum aperture. Nevertheless, it is one of a kind. Sharp, reasonably fast to focus to a 1D series body and often renders sublime results. I don't use this lens a huge amount, but I do love using it. All I can say is: the 85L is an incredible indulgence, but everyone needs a little luxury every now and again. Why not photographers?
 keithinmelbourne's gear list:keithinmelbourne's gear list
Olympus TG-5 Sony a9 Leica M10-R Sony a1 Sony a7R V +20 more
Canon EF 85mm F1.2L II USM
Telephoto prime lens • Canon EF • 1056B002
Announced: Feb 21, 2006
keithinmelbourne's score
5.0
Average community score
4.7
Canon EF 85mm F1.2L II USM Canon EOS-1D
sempervivum Forum Member • Posts: 59
Re: The 85L II is pure indulgence
Correct. While shooting portraits in natural environment I use mostly the 135L. Focuses faster, and more consistent; gives greater magnifucation at minimal focusing distance, has more convenient working distance for tight portraits, has less CA...
But from time to time the 85L gives results that simly nother lens can...
Yours Truly,
sempervivum
mevbo Senior Member • Posts: 1,221
I absolutely love mine and we'll never part with it.
 mevbo's gear list:mevbo's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 2x III Canon EF 24-70mm F2.8L II USM +3 more
Blake Cook
Blake Cook Veteran Member • Posts: 3,129
You haven't really experience the pleasure of the 85L II until you put it on the 1Dx. It absolutely transforms the lens. Lens AF speed and accuracy is improved to the point where I have photographed BIF at short range, volleyball and other indoor sports. Previously I used it on a 1DIV and 5DIII. neither were close to the 1Dx experience.
Of note, the lens is not much faster below about  3ft because the AF rotational movement is so large but beyond that length speed is not an issue.
Blake in Vancouver
Canon and Zeiss Stuff. Mac Stuff & annoying PC & Windows stuff.
 Blake Cook's gear list:Blake Cook's gear list
Canon EOS 5D Canon EOS 7D Mark II Canon EOS-1D X Mark II Canon EOS 5D Mark IV Canon EOS-1D X Mark III +14 more
MarcosV Veteran Member • Posts: 6,522
Yours Truly,
sempervivum
For me, it became the order you end up buying the 85L and 135L.  In the beginning I was shooting more indoors, so the order was 70-200/2.8L IS II, 85L, and 135L.
 MarcosV's gear list:MarcosV's gear list
Sony RX100 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm +28 more
CanonKen Senior Member • Posts: 2,936
I played with this lens for the first time a month ago.
Oh
My
God
What a gem.  I knew it would be big and heavy, but I was not prepared for what I saw.  Just a solid chunk of beautiful glass front and rear.  Ultra-bright, and just something special about it.  I cannot imagine what Canon would do for a III version (other than add an extra $1,000 on the price).
 CanonKen's gear list:CanonKen's gear list
Canon EOS 5D Mark IV Sony a6400 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Sony E 50mm F1.8 OSS +5 more
Scott Larson Veteran Member • Posts: 7,505
Or you could use the f1.8 version on a cheaper camera like I do.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
studioduplateau
studioduplateau Junior Member • Posts: 40
I have it and honestly, I prefer the results from the Canon 70-200mm f2.8L II IS
The 85L is not as sharp plus there are more aberrations than the 70-200L
Believe in the power of creativity
pgeorges Regular Member • Posts: 269
The 85L is better when shooting at f1.2 though
 pgeorges's gear list:pgeorges's gear list
Sony a7R III Sony a7 III Sony FE 90mm F2.8 macro Sony FE 85mm F1.4 GM Tamron 28-75mm F2.8 III +2 more
On what body. This is not what I have seen. Have you ma'd the lens?
Blake Cook
A good point. f/1.8 is not f/1.2 but AF is so much better on newer bodies the erratic AF  of the 85 f/1.8 may rejuvenate a lens that only had that as a fault.
Blake in Vancouver
songeun7 Contributing Member • Posts: 610
The 85L II lens is indeed special lens but....  I recently sold it and bought 100 f2.0 and Fuji X-100s with that money. I couldn't be happier.
 songeun7's gear list:songeun7's gear list
Sony FE 55mm F1.8 Canon G7 X II Ricoh GR IIIx Sony a9 Sony FE 35mm F2.8 +2 more
Which I have never found a need for. I find f1.4-r1.8 risky except for carefully posed shots.
Yes, I've seen lots of photos with the subject's nose out of focus. I'm not really into that.
jasrockett
jasrockett New Member • Posts: 13
I found the 50 f1.2 focus was completly diffrent on my 1Dx as compaired to my 1DmIV. On the 1Dx it didn't hunt around so I would believe the 85 f1.2 would react the same when used on a 1Dx. Some photos please...
 jasrockett's gear list:jasrockett's gear list
Canon EOS-1D X Canon EF 50mm f/1.2L USM Canon EF 16-35mm F2.8L II USM Canon EF 180mm f/3.5L Macro USM Canon EF 70-200mm F2.8L IS II USM +2 more
It's a shame that Canon was never able to get these lenses working that well on the crummy old 1D Mark IV.
canon person Senior Member • Posts: 1,586
To Keith:
I looked at EVERY ONE of your images on your website, and I am speechless!!!!!!! Each image takes my breath away!!! WOW! I am SO VERY JEALOUS. You are extremely talented. Thanks for sharing.
Canon Person
 canon person's gear list:canon person's gear list
Hasselblad X1D
keithinmelbourne
OP keithinmelbourne Senior Member • Posts: 1,026
Re: To Keith:
Blush! Thanks for the comments. Photography is renewed hobby for me. I used to have a darkroom, which I closed down because I couldn't justify having all those chemicals around. I didn't take any photos for about 20 years. Digital reawakened my interest, so I am learning photography all over again. I have probably over-invested in equipment, but it's all I spend my spare cash on, so I'm not too worried about that. I'm glad you enjoyed some of my shots.
keithinmelbourne
I get that, but I reckon if I were to do that, some time in the future I would still want to buy the 85L all over again.
Sigh! Such are the problems of the First World!
keithinmelbourne
What Scott? Not even full length portraits? The 85L's ability at middle distances can create some very fetching, 3D-like, images. I agree that f1.2 for head shots has a limited value, but even if you stop the 85L down to f2 or f2.8, its rendering is still quite distinctive.
If I always knew that I would be taking nothing but full length posed photos at middle distance for an entire event, yeah, sure. This just shows what limited use the lens is.
It looks no different to me than the 85mm f1.8 at those apertures. Why risk losing candid shots because the AF motor is so slow?
