Nx300- how to improve low light performance?
Started Jan 14, 2014 | Questions
Nxfan23 New Member • Posts: 3
Hi everyone,
I have an nx300 with 20-50 kit lens. The outdoor/ lighted shots have been great but the indoor shots have been very poor. for indoor portraits the pictures have been blurry and the subjects are not properly focused on. (terrible when subject slightly moves) Also upon examining the photos on a computer they are overly grainy and show heavy noise reduction at iso1600 and 3200. I have not been using the flash due to many of the portraits being of a small infant. I have tried several shooting modes auto, program, aperture but nothing looks good.  Because of the low light performance I am thinking of movimg away from samsung cameras.
Any advice? will a 30mm f2 or 18-50 ois lens be better?
Thank you in advance!
Samsung NX300
pixelpushing
pixelpushing Veteran Member • Posts: 3,279
Re: Nx300- how to improve low light performance?
1600-3200 ISO will show noise reduction and/or grain and artifacts on any camera, to varying degrees. How much depends on settings and of course the camera.
My experience with the NX300 is nil as yet, but I've owned an NX200 and NX100. Both turned in very good low light, high ISO results with a modicum of post processing in Lightroom. The chroma noise is easily drawn out with little to no visible loss of readable detail, and I for one have no issue with a bit of luma grain in my shots. Unless you're needing to view a small cropped area of your image at 100%, it shouldn't really matter.
That said, you're using a good but non-stabilized lens and trying to take images of moving subjects indoors with low lighting. Without buying a lens in the f2.0 aperture range or faster, you're going to need to boost ISO and learn some post processing techniques via RAW. There are some tips for shooting moving subjects here that may help. One big thing is to learn how to hold your camera so that it's better braced against you, and another is getting good at tracking your subject and anticipating movement.
I for one have no qualms with shooting cameras like the NX series, my 60D, A57 etc. up to 3200 as long as I don't mind spending a few minutes with each shot in LR. I'm not entirely sure how well the 300 handles JPEG but I know the 100 and 200 were quite poor when it came to higher ISO noise handling. Even my A57 was only so-so at this... Best I've used would be the X100 (in terms of straight unedited JPEG at high ISO) but there you have a whole other set of compromises and such - not the least of which being a fixed lens.
I'd suggest the 30mm f2, as it's fairly bright and not too close (though not really wide)... And there's always my favorite solution, tracking down a good price on a vintage prime like the Pentax SMC Super Takumar f1.4 50mm and get a Pentax K adapter for about 12 bucks. It'd be manual focus, but AF in dim light can be spotty anyway, and with a vintage bright prime you'd be able to take pretty fast shutter at an ISO range more like 400-800. Stop it down to f1.8 and those Super Taks are pretty sharp. That, and you'd also get some sweet artsy bokeh and flare around lights and such at night with the aperture opened up.
This is a Pentax 50mm 1.4 I found just last month at a camera swap meet locally for a mere 20 bucks. A cheap M42 adapter and it works just fine, and looks quite cool on the camera. KEEP IN MIND that any lens with a big aperture of f2.0 or greater shot wide open in this way will make for paper-thin plane of focus, so it will be hard to keep moving children in that field... So you're back to either investing in a decent flash with a diffuser or turning up the lighting
 pixelpushing's gear list:pixelpushing's gear list
Sony a7R III Tamron 24mm F2.8 Di III OSD Samsung Galaxy Note9 Apple iPad Pro
Raw Jaw
Raw Jaw Senior Member • Posts: 2,662
Nxfan23 wrote:
Hi everyone,
Get yourself the off camera flash cord from China that is NX 300 compatible.
Stick you SEF08a on it and set your ISO to 100 and you will get great images of your child.
Wave the flash around with your hand for various effects, I assure you that you will be amazed at the images, clarity and colors you capture.
viking79
viking79 Forum Pro • Posts: 14,157
Nxfan23 wrote:
Hi everyone,
Mostly how you are using it, you have to add light, photography is the capture of light and if you don't have much it makes it really difficult.  Taking photos in improper light = bad pictures with any camera.
You could get a 45mm f/1.8, the lens lets in much more light (about 8 times), but it won't add contrast and will have very shallow depth of field at f/1.8.  The only way to add light contrast is to add light or find better natural light.
In the middle of the day find a north facing window and you will get very diffuse light.  During other parts of the day pick a window away from the sun.  During the night, get brighter lights and position them closer to the baby.  Ceiling lights are terrible.
Direct flash usually looks terrible, you want bounce flash.  You can get the larger Metz 44-AF1, which lets you swivel the flash behind and bounce it off a ceiling or wall, or the cable for taking your flash off camera as someone else suggested.
You can also add off camera lights, probably want at least 75 watts not very far from the baby, careful not to get it too close, especially if it is a hot bulb, and they have a way of grabbing light stands and trying to pull them over
I see a lot of new photographers complaining about focus performance, low light performance, etc, and my advice is to not take pictures in those conditions.  Find the proper lighting.  You will find that with some fill light in the face you can still shoot ISO 1600 or 3200.  As for the motion blur you might try shooting in S mode with 1/100 of a second or so, if it is too dark at 1/100 and ISO 3200 you need more light (either larger aperture lens or brighter light).
I do think a brighter (larger aperture) lens would help, the 30mm f/2 or 45mm f/1.8 (I prefer the latter for babies), but more important is getting the light right.  The larger aperture will help you keep the ISO down a little and to balance ambient light more effectively if using flash.
Eric
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
nster Regular Member • Posts: 114
First rule is shooting in RAW, it makes a world of difference when dealing with noise
Secondly, if the subject is mostly static, consider manually focusing or using the manual focus assist thingy where it automatically focuses when you're at half shutter and you can fine tune it manually.
Third, you may have to shoot slightly under-exposed, try Aperture priority to the most open aperture (lowest f number) and set exposure slightly under 0 and use Lightroom to adjust the exposure later. Using such an open aperture will give you very small depth of field making it important to get the focus just right
The 30mm f2 would definitively help, the 45mm f1.8 would be good too. I use the SEF20a flash and put a white elastic diffuser thing and bounce it off the wall or ceiling but I can understand not wanting to do that. For ideal low-light performance obviously a Full Frame DSLR with good ISO control and a fast FF lens would destroy the samsung NX series like a Nikon D600 or something or even a APS-C DSLR like the D5300 or wtv should work much better at higher ISOs.
arbuz Senior Member • Posts: 2,247
Nxfan23 wrote:
Hi everyone,
Most of the pictures I shoot are indoors in artificial light, no flash (my family, especially kids, in the evening after work). I'm happy with the results. Proper focus is the key. 20-50mm is both dark and acquire focus very slowly so it's very likely that person moved a bit after camera confirmed focus and before it captured the picture. 18-50 OIS would be better because of OIS but only for static subjects. The best results I get from 45mm - it's both fast focusing and bright. You cannot make proper picture of running kid in dark room but for reasonable scene with limited movement it's fine. The same for 30mm - bright but focuses slower. Still good.
The other possibility is that camera sets long exposure time and picture is shaken. I find it very likely because 20-50 is very dark on long end (5.6) so for ISO 1600 I would not expect exposre 1/125.
First I recommend switching to S mode (on top dial - not auto, P or A, they're not good here) and setting time for 125ms. Take a few pictures of static objects. Make sure that there is no underexposure (red indicator at the bottom should be in the middle). This will give you sharp picture. If you find it blurry then upload the picture and check your noise reduction settings in camera, can be too aggressive.
If you get a sharp picture then consider 30mm or 45mm.  You will be able to shot in much darker conditions with times like 1/125ms. which I consider reasonable minimum for not completely static scene.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
OP Nxfan23 New Member • Posts: 3
Thank you for all the replies. I will definitely look into using the shutter priority mode and look into making a makeshift diffuser for the kit flash.  I will also look into using raw mode and see if I can get better shots following postmod
Thank you for the replies and advice. I hope I can get some good pictures tonight.
jennyrae Senior Member • Posts: 2,690
if blurry, I think you shoot in very poor light. this make shutter open really long time and make pictures blurry.  this is not camera fault but need to improve  know how of camera.
many options to take better pictures.
NX300 jpeg is really good quality. with no flash, set iso manually to 8,000 iso when really poor light. disable noise reduction to off or set to low. underexpose by 1EV to improve shutter, this may improve sharpness. if hit 1/80 already or 1/125, then this is ok shutter speed if person is stationary. no sudden fast movement. if able to shoot at 1/200, it is best even with movement but make sure exposure is only underexposed by -1EV and do not become too dark for picture.
my opinion, if want to get best picture quality, light is essential with any camera.
as mentioned, use off-angle flash. use raw for better picture quality adjustment. also able you to shoot best picture quality possible which is lowest iso at 100.
shark81 Regular Member • Posts: 145
The 30mm will probably be a better focal range indoors than 45mm. Granted I don't own the 45 but you can set your kit lens to that focal length to test it out. The 30mm has made my indoor shots much better. Learning the shortcut to adjust white balance has helped as well. Also make sure to use the af/mf hybrid feature.
Try to focus on something with high contrast to have your camera focus faster. Use high focus peaking. While pressing shutter halfway twist the manual focus ring. Take it off zoom mode. Increase your iso indoor. Get proper white balance. Kids will be tough to catch still indoors. 30 is great. Just a tad slow but is the overall prime lens of preference on this forum due to form factor, iq, and focal length. Soon i hope to get a 45mm as well. A fast prime will help your indoor shots.
 shark81's gear list:shark81's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung Galaxy S4
also agree on using better lens. 30mm give 1.5 to 3 stop extra exposure. if poster shooting at 1/30 with 20-50 depending on open aperture (50mm is very bad because very slow at f5.6 open, better use and fix at 20mm for best exposure) , 30mm lens at f2 will shoot at 1/80 (compared at 20mm) - 1/250 (compared at 50mm). very fast and very good for lowlight. this is big advantage of prime 30mm aside from best picture quality.
ttbek Veteran Member • Posts: 4,869
I know you guys hear this a lot from me, but FD to NX adapter + FD 50mm 1.8 is a very good budget solution to this (main downside being that you have to manual focus). This won't work for super dark of course, but will let you shoot moderately lit rooms at night quite easily. I also really like the Samsung 30mm for this. Flash is nice as well, but has it's own downsides (my brothers got pretty sick of the bright light before holidays were over...). I've been looking a bit more into flash myself and nx200USER1 was kind enough to link me to this one that supports Samsung's TTL here: http://www.ebay.com/sch/i.html?_odkw=nx+off+cameraflash+extender&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.Xnx+off+camera+flash+extender&_nkw=nx+off+camera+flash+extender&_sacat=0
Also, Samsung has a new and quite powerful flash coming soon.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
nx200USER1 Senior Member • Posts: 1,097
the 18-55mm (compare to 20-50mm) kit lens has OIS, but I couldn't say how much of an F stop advantage the OIS may get you.
Dave Gibbs Regular Member • Posts: 438
FD to NX adapter + FD 50mm 1.8 would this be autofocus
http://www.flickr.com/photos/108602759@N03/
 Dave Gibbs's gear list:Dave Gibbs's gear list
Samsung NX300 Samsung NX 50-200mm F4-5.6 OIS
Right. If using the 20-50 lens indoors then you are better off shooting at the 20mm range at f3.5 rather than 50mm at f5.6.  Unless the room is super light you are much better off not zooming in low light with moving subjects/no tripod, etc.  The 30mm @ f2 will prevent most of the blurring due to slow shutter speed, but you will still have some out of focus shots.  But still, it will be a big improvement.
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
To the OP - I know what you mean...
To begin with, I really like the NX300 and despite some of its quirks, it is capable of superb imagery with a wonderfully rich color tonality.  But to my dismay - which I'll have to find a work-around - I've discovered that high ISO pics of let's say from 2000 and above, just don't cut it with what one would expect of current day APS-C sensors.  I did a personal shoot a month or more ago in which I had little choice (very dim lighting) but to capture everything at ISO 2500 - 3200. I shot in RAW, assuming that any noise could easily be removed in Lightroom 5.3.
But converting/processing those files was one of the worst experiences I could remember when dealing with an image workflow.  Much of the noise was of such a caliber that it was difficult (sometimes impossible to remove).  I had to rely on extremely heavy Chrominance and color noise reduction - which in effect made the images look glassy (painterly effect).  I was not a happy camper and posted as much awhile back.  So now - I use the NX300 for only up to ISO 1600 - 2000.  My go-to high ISO cameras now are the Fuji X-E1 (up to ISO 6400), and the Olympus E-M5 (up to ISO 4000).
But again, you tend to learn of each camera's limitations - and they all have them.  But no, the NX300 should not be viewed as a great ISO camera.  But for everything else, I've found this camera to have a wonderful feel, let alone some gorgeous imagery.
Have a great one....
Bernd (Ben) W. Herrmann
North Carolina, USA
link
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: To the OP - I know what you mean...
I totally agree with your findings, that's why I don't feel ready to buy nx30 if it has the same low light performance (or not significantly better) of nx300 and I'll rather waith for a new sensor to use with the nice nx lenses I have.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
alex_virt Veteran Member • Posts: 3,044
The 18-55 OIS won't help, because you shoot moving subjects. 30mm/2 or 45mm/1.8 would help but not by much. The best solution would be GN42 flash with Gary Fong Cloud diffuser. A bit too big for a small camera, but it will give you excellent results at low ISO.
my experience with NX is thrive with highlight or strong light. with NX use, it is standard practice to expose to right by +1-1.5EV. really better compare with other cameras in strong lighting, and behind when poor light, but acceptable. best quality, overexpose by 1 then pull back exposure.
Nope, manual only, part of why it's so cheap.  It's a much easier manual than even with the native lenses though because it is an old lens designed to be used this way.  That is, the focus ring is super smooth.  With the focus peaking on the NX300 it is really much easier to use than one might at first think.
I'm going to disagree with you right here those two lenses help tremendously, even for moving subjects.  It might not seem like it at first, because maybe you're thinking that well, the lower f-stop will help with the brightness, but then shutter speed is still pretty low.  But consider shooting with flash right, with f/2 you're able to get quite a lot more brightness out of even the kit flash.  It's not perfect of course (shallower DOF) but you can partially offset this by moving back a bit more (due to the greater brightness).  I agree with your best solution (or something like that, maybe waiting for the new flash, or maybe one of the more moderate flashes would be sufficient for Dave), I just think you're underrating the difference those faster lenses make.
