Frustrated with a problematic 7D
Started Jan 13, 2014 | Discussions
Ralf J. Regular Member • Posts: 195
I got a Maxxum 7D, and yesterday.  Shot 86 shots with it, and was pretty pleased.
Brought it home and charged the battery. Started it up again, and to my surprise, the shutter will no longer fire!  Everything else seems to work, but when I depress the shutter button to take a photo, it just doesn't trip it.
I have read on the web that this is a common problem, and a design flaw which SONY was repairing for free.  I called SONY and they told me to take a hike, as they ended any Minolta repairs in 2011, recommending for me to check ca.konicaminolta.com.
That site had Prceision camera listed; I gave them a call and they also told me to take a hike as they no longer repair Minolta cameras :-(.
Am I out of options?  I really like this camera, and thought would be shooting with it a long time.
Please let me know your feedback.
Canon EOS 7D Konica Minolta Maxxum 7D (Dynax 7D / Alpha-7 Digital)
EvilOne
EvilOne Forum Pro • Posts: 14,627
Re: Frustrated with a problematic 7D
Your 7 D is ten years old. KM has been out of the camera business for a long time. there are no parts available to fix this camera. Even if there were. Precision Camera  would charge you 300 dollars for the fix. You can buy another 7D for less than that. But it too will be subject e to failure with no cure.
I have a perfectly functional 7D with grip and KM flash  and every accessory with all the boxes and paper work. I spent 300 dollars back 8 years ago to have mine fixed before Sony took over KM and After the warranty was over. Once the fix was announced Sony sent me a check to cover the repairs. I would not sell my 7D for 800 dollars. There is no camera out there that produces such wonderful colors. That's why I keep it.. its not as much fun as my Sony A700 or my Sony A77 but those colors are simply amazing. I take it out and shoot it every couple of months and only wish I could get the same breathtaking color for my other cameras.. I shoot Raw and use Lightroom and cant get the same colors with the Sony's as I get with my 7D right out of the camera..
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
OP Ralf J. Regular Member • Posts: 195
Thanks for responding, i came back from work yesterday, and it started working again.  From what i have been reading, it wont be long lived, but at least i am able to shoot with it now.
it certainly will not be a main camera With this malady, even though i would like it to
Renato1 Veteran Member • Posts: 3,385
What you describe isn't the First Frame Black problem that was being fixed for free (at least it's not what I recall). That problem was annoying, but one could take more shots eventually after turning it off.
There was another problem with the Anti-shake dying, which caused major repair issues.
I do recollect that there was some procedure for other 7D issues mentioned here years ago, but I can't remember them. Unfortunately, it's a needle in the haystack problem trying to find them.
What happens when you go to CCD cleaning mode where the mirror is meant to flip up? Have you tried shooting with the Anti-shake turned off and on?
Renato
EXX
EXX Senior Member • Posts: 1,204
BTW, I read somewhere (IIRC it was on the forum of dyxum.com, but I am not sure), that the First Black Frame error can be temporary cured by shaking the camera for a minute or so. The shake will put the mechanics in such a way that it works again for some time, I guess.
 EXX's gear list:EXX's gear list
Konica Minolta DiMAGE A2 Sony SLT-A55 Sony a77 II Sony DT 18-55mm F3.5-5.6 SAM Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +18 more
MichaelSolna Veteran Member • Posts: 3,474
I have one that I have tried that cure on. It worked a couple of times.
EvilOne
The problem with the first frame black, is the shutter mechanism. The reason I know this is when I sent my camera. Because it did what yours did and finally stopped working. I sent it in after warranty and I paid almo0st 300.00 dollars for the repair. when Sony took over KM they sent me a check for the repair, because it was deemed a manufacturing defect. The Fix was to replace the Shutter and the connection cable. Note my repair order from 2006. They replaced the shutter mec. and associated parts, as stated in the repair invoice for parts replaced. Sony told me it was the covered manufacturing defect repair which the covered for 4 years. They returned the money I spent out of pocket.
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
Agree not at all what FSB or FFB was (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Lyle From Canada Senior Member • Posts: 1,512
Re: Agree not at all what FSB or FFB was (nt)
When the shutter locks up and you get a black frame that freezes the camera:
1 - shut the camera off and remove lens
2 - turn it back on
3 - go into the menu and locate the "clean ccd" option
4 - select yes
5 - lightly touch the louvered curtain that is sitting over the sensor. It should sitting open when touched.
6 - shut off the camera and reattach the lens
It should work fine now. I find as long as I use mine daily it seems tip be ok. Regardless this always fixes the problem
Fuji x-pro1 with 14, 18, 23, 35, 60, 55-200, fuji x100s and WA adapter, fuji x10
marc petzold
marc petzold Senior Member • Posts: 1,974
that's unfortunately the well known "ERROR:58"....i hope my 7D will last for many years still, even with today's only 6 MP, i love the design & haptics of that DSLR quite much, it'sa living legend already, and turns 10 years old this year, too!
 marc petzold's gear list:marc petzold's gear list
Canon EOS 5D Canon EOS 40D Nikon 1 V1 Fujifilm X-E1 Sony a7 +57 more
Sonnarman
Sonnarman Contributing Member • Posts: 518
Yay for KMT?DP Review, and thanks very much Lyle for your 'bones 'n' braces' approach to the FFB issue.
Yes, I know all the arguments why one should not bother - too old, too worn, too ... whatever!
And yes they both succumbed to the FFB issue. Coming back to this work-around has brought both back to life.
MY 7D's are now almost ten years old, yes. They have idiosyncrasies and sometimes make me lust after others, but the colour rendition and atmosphere in a good high-res file produces images that make me feel good, and those I share them with more than happy to hang their 24x30 inch prints alongside images no more impressive that have been sourced from much more expensive kit.
So I will raise a glass to Canada. And make some more 7D images this week. (Even if my A77 cries foul!)
Cheers, and thanks again.
Sonnarman
 Sonnarman's gear list:Sonnarman's gear list
Konica Minolta Maxxum 7D Sony SLT-A77 Fujifilm X-E2S Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T*
marc petzold
2 - turn it back on
4 - select yes
According to Konica Minolta ages ago, it's a hardware issue, so it can't really being simply fixed by that way - how often does the in-famous "Error 58" comes back that way to your 7D?
Marc
Sonnarman
I have been through the whole process...Shutter replaced FOC by Sony Repair here in New Zealand. Then after three years one more time, but advised there might not be another chance.
Discovered (when it inevitably occurred again, about two years ago) that by shutting down, removing battery and then applying power again it would suddenly re-awake after  one or two frames. Leaving it powered down for a  few weeks brought it to a dead end, or so I thought.
After finding this trick I tried it, the camera works, like as if nothing was ever wrong, and if I power it on every two days or so, it seems to be going just like new again. I have no idea what is going on save perhaps some static accumulation on a part within. (I do use antistat wristband when getting anywhere near the front curtain.
Cheers
Sonnarman
Anglicum New Member • Posts: 3
Hi Raif J
i too have the same problem with my 5d I've had it a good few years but hardly used it  but now I have the time  the shutter refuses to work I've posted on here  but had no response I've also contacted Konica Minolta direct via email but had no respoce  did you get any joy ? Have you managed to get yours repaired? Please let me know as this is driving me nuts
cheers anglicum
Sonnarman
Sonnarman
Sonolta Shooter
Sonolta Shooter Senior Member • Posts: 1,317
FFB workaround is on Dyxum.  I have a perfectly good 7D listed in the classifieds BTW.  K-M authorised repair agents are listed on the KM website.  Bear in mind new parts are no longer made, so any repairer cannot put a warranty on the repair if they use used parts (taken from another body for example) though I hear the agent in Bremen have parts, so it may be worth sending them an email and asking for a costing and to confirm if they still hold spare parts, though the cost to do this is likely to exceed the value of the camera, so have you considered buying a Sony A100-A750 APS-C which have no FFB issues, though the A100 and A700 are the only two that have mag-alloy chassis as the 7D and retain the DoF button, though the A700 has a CMOS sensor as opposed to CCD and I think this is the sensible option.
Alphamale
 Sonolta Shooter's gear list:Sonolta Shooter's gear list
Sony Alpha DSLR-A850 Sigma 10-20mm F3.5 EX DC HSM Nik Sharpener Pro Topaz Adjust Topaz Clean +18 more
GuyMcKie Contributing Member • Posts: 618
Could also be a problem with the internal battery. I had the same problem wit a fully charged battery. After a day the camera worked again. But I had to set the date date and time again.
MFT576 New Member • Posts: 1
I have had the same problem,  I simply let it "warm up" and fiddle with a few functions, then after about 5 minutes it would work perfectly.
Now however,  I can't get the damn thing to power on at all.   It worked fine yesterday,  then last night after down loading some pictures,  it stopped working even after swapping several fully charged batteries.  Anyone have any ideas for this new problem or is my 7D screwed?
Maoby
Maoby Veteran Member • Posts: 5,471
I have here a recipe that works for me
Charge the battery
Turn on the camera
Leave it on, and no longer touch the camera for a few hours
Then disassemble the lens,(Do not touch anything else) and put the lens back in place.
Test your camera, mine is working again.
Never turn your camera off
Good luck!
 Maoby's gear list:Maoby's gear list
Olympus E-10 Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II N Canon EOS-1Ds +81 more
thedancer Regular Member • Posts: 205
This solution is something I have to try on my problematic 7D. Everything seems perfect 100% working, but once the button is pressed only a black image is found. (Even in clear daylight  )
E.Dancer
