Imac late 2013, Maverick, w/ fusion drive, possible usb problems.
Started Jan 12, 2014 | Discussions
Bob Randall Forum Member • Posts: 97
I recently purchased an iMac, late 2013 with 3tb fusion drive. In searching forums regarding a usb connection issue I may have, I notice many threads relating to a consistent issue with usb on this model.
This a pasted quote from Peter McLaren as posted in the Apple Support Community:
"For those still wrestling with USB bus freezes with iMac Late 2013 with Fusion drive and Mavericks, and who don't want to have to wait till OSX 10.9.2, I have found the utlity posted at this link way back on October 25th solves the problem:
http://www.enttec.com/support-center/kb/article/108-OS_X_Mavericks_(10.9)_-_IMPO RTANT
Not sure why this link has not been posted on this thread before!
As you will note from the associated page the author claims that Apple wrote their own USB driver in Mavericks and it has issues. The utility disables it, and reverts to a standard driver.
I have been running for 48 hours with this driver fix installed with zero issues. Previously with a USB hub connected to my iMac I would get an hour or so at best before a USB freeze.
As other have reported the issue is the USB bus. The CPU itself does not crash; the iMac is still accessible via screenshare or fileshare while the bus is frozen, but it does take a restart to clear the USB bus freeze.
Hope this helps relieve some frustration while we all wait for OSX 10.9.2."
This "solution" reverts the usb3 port back to a usb2 until the fix comes.  I have not done this nor will I as I don't want to mess with something that may not be an issue for me.  There are many threads regarding usb and connection issues but the one consistent one relates to only late 2013, iMac, Maverick's with fusion drives.
It is not my attempt to induce concerns, but there are just too many threads regarding this model with this issue.  I have not found any threads relating to this observation on dpreview so thought it may be helpful to bring forward.  No fear mongering intended, I just think that we are a curious bunch and should be aware.
 Bob Randall's gear list:Bob Randall's gear list
Sony RX100 Sony RX1 Nikon Df Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +3 more
brycesteiner
brycesteiner Senior Member • Posts: 1,617
Re: Imac late 2013, Maverick, w/ fusion drive, possible usb problems.
Are you having this issue or another? I'm not certain by the post. Is your fusion drive on the USB bus or is that not relevant to the problem?
I have a MBA with USB 3 and it hasn't had any problem with USB 3. I don't have a fusion drive though, only a SSD.
Make it a Great day!
 brycesteiner's gear list:brycesteiner's gear list
Olympus E-510 Olympus E-30 Olympus OM-D E-M5 Olympus E-M5 II Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +6 more
Bob Randall OP Forum Member • Posts: 97
I had a small problem with a Spyder 3 and the usb connection. As a result, I searched for similar problems and notice a trend regarding only the iMac late 2013 model that had a fusion drive and was running Maverick. There have been many returns of this model with the exchanged units having exactly the same problem.
You can read about it here:
Massive problem with audio interface: Apple Support Communities
and here:
Forum - Main Forums : Mac Music - Sound On Sound
Audio problems with new iMac Fusion Drive - MacRumors Forums
Potential audio problem with new iMacs - Page 3 - Gearslutz.com
Some have reverted to Mountain Lion, problem resolved.
Reverted to usb 2 drivers, problem solved.  A few have booted from another source with no problem.
vockman Regular Member • Posts: 369
I was just going on this forum now to post my problems with my new 2013 Maverick 27" I7 Imac with fusion drive.
I have experienced intermittent problems with SD cards not being read properly and needing a repair, freezes when transferring files from the SD card onto the internal drive or an external usb 3 enclosure with SATA drives. Also Sleep/wake and accidental ejection problems with my external USB drive. Then I also have to clear these ghost files from the freezed copy attempts from the destination folder or Lightroom says it is looking for the previews.
So far the only thing I have found that helps is copy only 300-400 files at a time. Freezing seems to occur most when transferring 500+ files
As you said there are all sorts of complaints about similar issues on forums with different variations, including issues with WD drives, so your explanation makes the most sense: There is a global USB 3 bus issue within the mac.
So I am probably wasting my time thinking it is a problem with either the internal sd card slot or my external USB3 sata drive enclosure.
I don't see why it would be fusion drive related, it sounds like it is either a Maverick or firmware issue. However I do notice inconsistencies in the time it takes for the fusion drive to wake up.
If others can confirm this issue and offer solutions that would be great.
IT FREAKS ME OUT TO TAKE A CARD FROM A SHOOT AND GET A FREEZE WHEN DOWNLOADING THE ORIGINAL RAW FILES. WHAT IF THE CARD GETS DAMAGED?
ALSO THE TIME TO SECURELY TRANSFER THE INFO UNDER THESE CIRCUMSTANCES IS MAKING MY NEW COMPUTER BARELY MORE EFFICIENT THAN MY OLD ONE AND I AM RISKING LOOSING DATA!
Tom_N Forum Pro • Posts: 10,672
Many SD / SDHC / SDXC cards have write-protect switches.  These are not binding on the computer or card reader, but you could put your cards into "write-protect" mode before putting them into the iMac and hope that the iMac would honor it.
I may consider locking the SD card thanks
I have noticed apple had some fix for a usb issue for those who bought the 2013 imac in the short period it was sold with Mountain Lion installed:
http://support.apple.com/kb/DL1700
brycesteiner
and here:
The only reason I kept Mavericks on the one computer was just to see when the problems would be fixed.
I can easily see it being the new OS. Most of these issues didn't occur with the previous Mountain Lion. I like the new features, but I have to have the other stuff working too. Devices working are more important than added features.
You have had some of the same issues that I was researching.  My sd card that was in the iMac slot would become "unmounted" and I would get the warning message and also my usb spyder would randomly lose connection.
The fusion drive is a constant much like Maverick is.  The straight SSD model or a partitioned model does not experience the same common problems that were talking about here.
mujana Veteran Member • Posts: 3,809
Some hope? Maybe Mavericks?
and here:
posted on Gearslutz.com......today:
"Just to chime in here I had the exact same issue with a new iMac and a 1TB fusion drive, Mavericks and a Scarlett 2i2 USB interface. Since moving to the 10.9.2 beta the issue has gone!
So just to reassure folks 10.9.2 should fix it. One little note, initially after moving to 10.9.2 the issue remained, but if you're using a Scarlett interface you need to use the class compliant drivers. Once I switch to those all was good."
 mujana's gear list:mujana's gear list
Sigma DP3 Merrill Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8
Re: Some hope? Maybe Mavericks?
Thanks for the info about 10.9.2. It gives me some hope that just a little more patience and the problem will fix itself. I will wait until it is an official release.
What you are saying about the fusion drive somehow being the culprit is interesting. I suppose if 10.9.2 doesn't fix the issue I will go to apple and get an SSD drive.
Can others confirm that without the fusion drive there are no USB bus issues?
Googling for information about the 10.9.2 update I came upon a link to an apple forum asking if 10.9.2 will fix driver issues and when clicking on the link got a page an unauthorized access message from the apple web site. Kind of cryptic....
Charles Fisher Forum Member • Posts: 99
I have a 27-inch, late 2013 iMac with a 1TB fusion drive. I was having some strange system freezes which I attributed to using USB 3.0 hubs. I changed to an Anker 7-port USB 3.0 hub and my problems have disappeared. An advantage to the Anker hub is that it has two additional ports for charging smartphones and tablets.
I have read that there are problems on the use of USB 3.0 hubs that affect PCs as well as Macs. One issue is the amount power that is available for peripherals that require it. The Anker hub has a relatively large "brick" and can supply up to 48 W of power.
Chuck, retired near Barcelona
See profile ('Plan') for equipment and software.
 Charles Fisher's gear list:Charles Fisher's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Olympus 14-150 F4-5.6 II
Interesting, but there seems to be some issues with the internal USB3 bus/hub in conjunction with different USB3 peripherals (including a hub in your case) and maybe the type and amount of data being transferred.
In my case, I seem to not have problems if I only copy about 300 raw files at a time from my SD card slot to my external USB3 drives and if I always eject my USB external drives and turn it off before i put my computer to sleep.
But transferring higher numbers of files freezes the bus
letting my external drives fall asleep with the Imac can lead to slow waking up or accidental ejection.
brycesteiner
Are you limited if you transfer the problems to an internal drive?
bravozulu Contributing Member • Posts: 897
Tom hit it on the head. I have a 2013 (late) 27" iMac. Because you have to reach around to insert or remove an SD card on the back of the machine, you are exerting a sideways thrust on the card. In about 30% percent of my card uses, the lock switch get dislodged and set to LOCK.
No fun. You just need to go slow and be careful.
 bravozulu's gear list:bravozulu's gear list
Nikon D7000 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF-Nikkor 80-200mm f/2.8D ED +5 more
Yes, I am now more careful inserting the card not only because of the switch on the card but because the way the slot is designed does allow the card to go in crooked and then straighten out possibly after some of the contacts have made a connection. Perhaps this straightening of the card after it has made some contact cause a mounting problem. So now I really try to straighten the card very carefully before reaches the contact points so everything makes contact at the same time. I have to say when it works it is amazingly fast!
and
Yes I did have 2 bus freezes trying to copy 700 raw files to the internal disk.
but I also had one occasion where I transferred that many with no problems.
Andy Hewitt Veteran Member • Posts: 3,072
I have a Late 2013 iMac, but with a standard hard drive, and also suffer with USB3 issues - which were summarily dismissed in this forum as other equipment problems.
On mine the issues is random disconnects after waking from sleep. A little Googling finds that this isn't actually limited to Macs, but also pops up on Windows boxes too.
You can simply drop to USB2 speed by using a USB2 cable.
FWIW, I gave up for now, and use a Thunderbolt to FW800 adapter, which is working perfectly well.
Andy Hewitt
Using FujiFilm HS50EXR and Apple iMac 27" 3.2GHz
 Andy Hewitt's gear list:Andy Hewitt's gear list
Nikon D5100 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Topaz Adjust Apple iPhone 5c +3 more
